Dinghy Tow
Discussion in 'Towing' started by jbrown, Oct 1, 2009.
  1. Oct 1, 2009 at 7:46 AM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    I have a 2003 Tacoma 4x4 manual transmission that I would like to tow behind a motorhome. The Toyota Owners Manual says that it is not to be dinghy towed. Can someone tell me why, and how I can make it towable? Thanks
  2. Oct 1, 2009 at 7:55 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Don't quote me on this...but it might have a lot to do with the drivetrain/transfer case etc.
    Talk to a dealership or a reputable RV place about it or consult your dealer for more info.
    I know in the Jeep world - folks will remove front & rear driveshafts from the vehicle to ensure safety in preventing drivetrain damage.
  3. Oct 2, 2009 at 8:17 AM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    Janster, thanks for your reply.
    We live in a remote area and there are no Toyota dealers nearby. When we get to a city with a dealer I'll stop in.
    I heard that it might be a problem with the drivetrain/transfer case, but I don't understand why if I put the maunual transmission in netural that should be a issue.
    If that is still the case it seems like a lot of trouble to remove the drive shafts. There should be eaiser remedy.
  4. Oct 4, 2009 at 5:04 AM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    The transfer case on a 4x4 does not completely disengage. It has some shafts that turn constantly if the wheels are turning. THe only way to protect the transfer case is to disconnect the drive shafts on both front and rear.
  5. Oct 5, 2009 at 12:38 PM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    Thansks JDCPA. Does it make a difference if the the transfer case is manual or electronic? I checked an aftermarket vendor, Remco, who makes drive shaft disconnect couplings, and they told me that if my Tacoma has a manual transmission and a manual 4x4 transfer case that it is towable as is. Their losing a sale by telling I can tow my Tacoma as is.
  6. Oct 6, 2009 at 4:37 AM
    JDCPA
    Jim
    SW FL
    Different manufacturers may do things differently. The Jeep transfer case fully disengages and you can flat tow the vehicle with no modifications. Some other trucks keep turning shafts whenever the front wheels are turning. I don't know about the Toyota unit but would think the dealer has that information. If they tell me not to tow it I wouldn't tow it.
    Think about getting a two wheel doll and using that to tow the Toyota. That way the front wheels would be off the ground and putting the transmission in neutral would disenge the rear wheels.
  7. Oct 6, 2009 at 5:07 AM
    Justin723
    Justin723 Dont judge me
    Justin
    Phoenix AZ
    02 Tacoma TRD
    Performance- bored .20 over, Doug Thorely Headers, Magnaflow Exhaust, and K&N cold air intake. Exterior- Trail Gear Solid Axle Swap, ARB compressor, high pinion 4.88 with ARB locker, 4.88 TRD Locker in the rear. Interior- 2 10inch JL W1 subs, Alpine MRX-V70 amp, Alpine type R SPR 17C 6x6 speaker in the back, Focal 165 VR with crossover tweeter up front, and Weather Tech floor mats.
    You guys dont think it has anything to do with the automatic hubs?
  8. Oct 6, 2009 at 5:12 AM
    Fire931
    Fire931 Well-Known Member Vendor
    VA
    00 4Runner
    i thought that as long as you had the manual tcase... in other words no buttons at all... just you could put it in neutral and flat tow it.... but it had to be the fully manual tcase with the j shifter and no buttons...
  9. Oct 6, 2009 at 9:35 AM
    Justin723
    Justin
    Phoenix AZ
    02 Tacoma TRD
    I really dont know, but if i had to guess it would have to be dew to the hubs always being engaged.
  10. Oct 6, 2009 at 9:37 AM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    This would make sense to me, although the front hubs would still be engaged (unless you have lock-outs)
    For the electronic T-case I remember reading that you DO actually have to disconnect the driveshaft before Dinghy or Flat towing.
  11. Oct 6, 2009 at 9:40 AM
    Fire931
    VA
    00 4Runner
    yea on electronic t cases there is no way to put it into neutral so you cant flat tow w/o unhooking driveshafts.. but on the manual tcase you can throw it in neutral and away you go. as far as the hubs.. the ADD is disengaged so its the exact same stuff spinning as if you were driving it normal... so there should be no difference.
  12. Oct 6, 2009 at 9:42 AM
    TacoNut
    Adam
    Denver, Co
    That makes more sense.... THX:)
  13. Oct 6, 2009 at 12:02 PM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    I have 4 different transfer case modes; L4, H2, H4 and N (Neutral). When I put it in N there is no power to the wheels. If this is not for towing what use is it?
  14. Oct 6, 2009 at 12:32 PM
    Fire931
    VA
    00 4Runner
    so you have the standard j shift manual tcase... in that case i see no reason why you cant flat tow it, just make sure the tcase is in neutral and i would probably put the tranny in neutral as well if its a manual..
  15. Oct 6, 2009 at 12:39 PM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    Thanks, that makes sense, however I've just been on the phone with Toyota and they still say that it can't be flat towed. I asked them what the purpose was of the neutral position in the transfer case (no power to the wheels) and they can't give me a answer.
  16. Oct 6, 2009 at 12:40 PM
    Fire931
    VA
    00 4Runner
    seems to me in the older owners manuals it used to have a section on flat towing and stated just what i said... tcase in neutral tranny in neutral....
  17. Oct 7, 2009 at 5:16 AM
    JDCPA
    Jim
    SW FL
    The purpose of a neutral position on the transfer case is to disengage the power from the drive train and allow you to shift to high or low range. It does not disengage the entire drivetrain on the front on many transfer cases and I WOULD NOT flat tow the vehicle for any distance if Toyota is telling you not to. You are just asking for trouble. And you will probably void any remaining warranty on the transmission and transfer case.
  18. Oct 7, 2009 at 7:04 AM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    Thanks, then to be safe and disconnect the driveshaft is it necessary to disconnect it at both ends, or could I just disconnect it at the rear and create some kind of bracket to suspend it while it's flat towed?
  19. Oct 7, 2009 at 7:28 AM
    j4x4ar3
    j4x4ar3 Well-Known Member
    Jay
    Austin, TX
    05 DC 4x4 - TRD Off Road - White
    Round Step Bars, Bed Mat, Cargo Bars, Rocky Mounts bike mount, JVC MP3 Head Unit, TRD Cat Back Exhaust, Rigid Industries front and rear light pods, dual HAM radio with remote mount heads.
  20. Oct 7, 2009 at 7:46 AM
    jbrown
    jbrown [OP] Member
    Joel
    Mammoth Lakes, CA
    2003 Tacoma TRD 4x4
    I've spoken to the people at Remco, and they told me that I absolutely can flat tow, my 4x4 with manual trans and manual transfer case, without any modifications. They said they are losing a sale my telling me this and that Toyota is wrong. This is what makes this so confusing.
