Dinghy Towing
Discussion in 'Towing' started by Cw252337, May 3, 2017.
  1. May 3, 2017 at 12:40 PM
    Cw252337
    Cw252337 [OP] New Member
    Carl
    2017 Sand Tacoma TRD
    None yet
    I have been led to believe that dinghy towing was possible with the proper modifications. Has anyone accomplished this?
  2. May 3, 2017 at 12:41 PM
    AtxLakeTaco
    AtxLakeTaco Texas Toyota Coalition
    Tres
    ATX
    Black DCSB Prerunner
    5100's,887's,etc.
    A prius could tow a dinghy.
  3. May 3, 2017 at 12:42 PM
    AtxLakeTaco
    Tres
    ATX
    5100's,887's,etc.
    Our trucks are capable of towing Mid-sized to large rv's. A dinghy is no problem at all.
  4. May 3, 2017 at 12:42 PM
    Skrain
    Skrain Time is an illusion. Lunchtime doubly so.
    Monticello, Ky
    2009 F.J. Cruiser
    Westin 9 LED Driving Lights.
    Check the owner's manual and it will tell you all about it. usually a trailer is better in the long run no matter what...
  5. May 3, 2017 at 4:17 PM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Dinghy towing is a term RV'ers use to flat tow a vehicle behind the RV.
    Op, I would disconnect the rear driveshaft to dinghy tow. Just tie it up under the truck. Only need to pull the side on the differential. As noted above, the manual should give some info on this.
