Dingy Towing My Tacoma ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tengle, Jan 18, 2014.
  1. Jan 18, 2014 at 8:16 PM
    tengle
    tengle [OP] New Member
    2014 Tacoma
    Has anyone towed your Tacoma behind a RV? I recently bought a new
    4cyl, 2wd, 5sp. manual trans. with the intentions of towing it
    behind my RV. What I am concerned about is that the owners
    manual states not to dingy tow (all wheels on the ground) or
    serious damage will occur. The manual makes no exceptions as
    to transmission type, ect. It also doesn't say what or why this damage
    will occur. Any input would be appreciated, but I especially would
    like to hear from someone who has done this. Thank You.
  2. Jan 18, 2014 at 8:17 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    So what's the the questions? Owners manual says no.
  3. Jan 18, 2014 at 10:53 PM
    jmg256
    jmg256 Calmer than you are
    Al Tonter
    TRD Offroad
    Bilstein 5100 front/rear (front at .85), Hayden 678 Trans Cooler, 20% tint, Curt Hitch/Wiring Harness, Weathertech Digital Fit Floor Mats (Black), Wet Okole Seat Covers (Black), Cooper Discoverer ATP 265/75/16, LED Map/Dome lights, ImMrYo bracket, Debadged, Extang Tuff Tonno.
  4. Jan 18, 2014 at 11:06 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Bumper? Is that you? (or your dad)
  5. Jan 19, 2014 at 8:00 AM
    1of7627
    1of7627 Well-Known Member
    Mark
    Post Falls, ID
    '14 DCLB Ltd, '63 Corvair Spyder
    Things I need to tow.
    Toyota doesn't sanction dinghy towing of any Tacoma (per the owners manual), but the manual transmission models are commonly towed. I towed my 1st gen 4X4 for several years and I know of several 2nd gens 4X4's that have been towed long distances without apparent damage. It's up to you if you want to, but don't tell the dealer. (And, don't even think about it with an automatic.)
  6. Jan 19, 2014 at 6:43 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    2nd Gen transfer case is not splash-lubed. Like an automatic trans, it is lubed by a pump on the input.
    I guess it will still work okay with the trans in "N" and the transfer case in 2-Hi
  7. Jan 19, 2014 at 6:55 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Have you thought about maybe towing the RV behind the Tacoma?:)
  8. Jan 19, 2014 at 7:02 PM
    jmg256
    Al Tonter
    TRD Offroad
    Irrelevant...OP has no transfer case...2wd
  9. Jan 19, 2014 at 7:05 PM
    1of7627
    Mark
    Post Falls, ID
    Wow! I don't tow mine (automatic) but my brother-in-law tows his and I'm pretty sure he doesn't put it in 4-Hi. I'll give him the heads up. He's already made two trips from ID to AZ that way (over 1000 miles each way).
  10. Jan 19, 2014 at 7:32 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    See edit...
    2-Hi... not 4-Hi.
  11. Jan 19, 2014 at 8:31 PM
    tengle
    2014 Tacoma
    Me again,
    My Tacoma is a 4cyl., 2wd., 5sp., manual transmission.
    I spoke with a gentleman who has worked for Remco
    (makers of the drive shaft disconnect) for quite awhile. He told
    me that I would be wasting my $'s because my trans. was a
    manual shift. (A company called Superflow out of Des Moines is
    now making the disconnect.)
    Does anyone out there have experience towing a Tacoma
    like mine or personally know someone who does?
    A flat bed trailer or tow dolly isn't a option. Thanks Again.
  12. Jan 20, 2014 at 8:52 AM
    billinwoodland
    billinwoodland Well-Known Member
    Bill
    N. Cal
    I'm planning on towing my 2014 4x4 automatic. As much as I hate the thought of having to deal with a flatbed, I think that will be the route I go. BTW, tons of info on towing behind an RV at RV.net.
