Diode Dynamics Backlight Harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by illnevertell10, Jan 8, 2023.
  1. Jan 8, 2023 at 9:22 AM
    illnevertell10
    illnevertell10 [OP] Member
    Tocamo likes this.
  2. Jan 8, 2023 at 9:37 AM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    Damnit. I misread the title of this thread. I thought it said "BLACKLIGHT". I was like "Oh shit, now there's a bad-ass mod. It'll be like I'm back in college!"
    Coldpunk likes this.
  3. Jan 8, 2023 at 12:18 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    From their website,
    This harness is completely plug-and-play. Simply connect it inline between the vehicle harness and headlight harness and then connect the female spade connector to the male spade connector on the fog light wire adapter. No need to tap any wires to power the backlight!
  4. Jan 8, 2023 at 12:41 PM
    illnevertell10
    Right, I saw that. Not seeing where it would actually go in between the vehicle harness and the headlight harness.
    AmateurTaco1313 likes this.
  5. Jan 8, 2023 at 12:59 PM
    Technique
    Alex
    Utah
    It's plug and play, so you'll find your headlight cable, unplug it and then put the harness you bought from DD in between. Both the harness coming from the vehicle and the headlight cable should plug in to the harness you purchased.
    That's my understanding from the instructions they gave.
  6. Jan 8, 2023 at 1:24 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I thought this was a tailight kit....
  7. Jan 8, 2023 at 1:29 PM
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    That harness is for the halogen projector headlights with the L shaped DRL. You have the OEM 2020+ headlights, they have a completely different plug.
    daveeasa likes this.
  8. Jan 8, 2023 at 1:35 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    That is cool, if I am understanding the wiring correctly that harness allows the backlight to be on automatically with the DRL. I have an older harness, so I had to buy a seperate kit with relay and switch to toggle between backlight and fog.
    Your fogs should have the 2 pin to 4 pin harness and the wire with the red plug. The harness you have plugs in between the headlights and the harness going to the headlamp. Then the wire with the plug should plug into the wire on the 2 to 4 pin harness. This way the backlighting is on with the DRL and then the fogs come on as normal.
    i am not 100% but I believe this is how it should work
    Edit , I missed the LED lamps you have. Not sure if it would work like Chris said. I’ll take the, if not :D
  9. Jan 8, 2023 at 1:40 PM
    Technique
    Alex
    Utah
    Good point. I didn't even notice that part of the original post lol.
    If that's the case, Diode Dynamics needs to specify on their website it doesn't work on OEM LED headlights.
  10. Jan 8, 2023 at 2:30 PM
    illnevertell10
    Thanks Chris! Was losing my mind and I agree, it should specify on the website.
  11. Jan 8, 2023 at 2:36 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    Any chance you’re looking to sell the harness?
    I have the DD SS3 max fogs and didn’t want to splice wires to do the backlighting.
  12. Jan 8, 2023 at 5:54 PM
    illnevertell10
    Sure I’ll sell since I can’t use it. I already contacted DD for an RMA.
  13. Jan 8, 2023 at 6:04 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Unfortunately, unless you swapped in your OEM LED headlamps, this harness will not work for you. You will have the single connector on the back of the headlamp.
    You would have two options, splice into the original harness... not really recommended... or talk to @daveeasa and see if he might be able to assist you in a break out harness to allow plug and play.
    t2c likes this.
  14. Jan 8, 2023 at 6:35 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Paul said he was gonna get this out there. Nice to see it available. Note it won’t fire off DRL, based on what I’m reading. Just parking light.
    For LED from the factory trucks you can do a single LED T harness and dual DD SS3 harness or dual LED T’s and pair of single SS3’s. That’s the FBC menu options.
    or just pretend no backlight, cheaper and easier.
    drizzoh and Speedfreak like this.
  15. Jan 8, 2023 at 6:38 PM
    daveeasa
    David
    PNW
    Also, @Diode Dynamics , you definitely should update the product info to note it’s only compatible with trucks that came from the factory with halogen headlights. That’s an important distinction to make to avoid confusion.
    HueyMech, Taco22trdor, t2c and 7 others like this.
  16. Jan 9, 2023 at 6:04 AM
    shwilly
    shwilly Well-Known Member
    When do parking lights fire?
  17. Jan 9, 2023 at 7:04 AM
    daveeasa
    David
    PNW
    On the stalk after DRL or when stalk is Auto and ambient light sensor indicates darkness.
    Speedfreak likes this.
  18. Jan 14, 2023 at 2:05 PM
    Texmax
    Texmax Well-Known Member
    Randall
    Aubrey, Tx
    2017 SR5 4X4
    3AAAA12E-0FEA-42B3-BF84-175E45B22456.jpg Just got my harness. Whats up with the spade connector? This is what I have hanging off the fog for the backlight
  19. Jan 14, 2023 at 2:48 PM
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    Amen to that….
  20. Jan 14, 2023 at 4:42 PM
    daveeasa
    David
    PNW
    The backlight has a 1 pos amp female connector. Hence to supply that you would either use a 1 pos male to bare wire or or spade or something plug and play which provides a 1 pos amp male.
