Diode Dynamics Backlight Harness
Discussion in '3rd Gen. Tacomas (2016-2023)' started by illnevertell10, Jan 8, 2023.
  1. Jan 14, 2023 at 5:23 PM
    AmateurTaco1313
    AmateurTaco1313 Next truck will be a Hilux
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    I tried applying the inline backlight harness today and could not figure it out for my ss3 Max fog lights. I’ve been looking for installation videos. I’m also not the best with lighting and didn’t want to go unhooking anything I could on my headlights.
    thanks @illnevertell10 for the harness, brand new.
  2. Jan 14, 2023 at 5:45 PM
    Texmax
    Texmax Well-Known Member
    Randall
    Aubrey, Tx
    2017 SR5 4X4
    I have the plug and play harness from DD made for my Elite fogs. Spade will not plug and play into the connector I have on my fogs.
  3. Jan 14, 2023 at 7:00 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    My understanding of the spade is that it’s a small jumper w spade on one end and male 1 pos amp on the other. And you would disconnect it if supplying 1 pos amp from a plug and play solution. That’s how I make the stuff I sell.
    maybe post a photo? I assume you just need to disconnect the spade stuff? Unless the DD plug and play is to a spade which would be a lot of connections just to get a backlight.
  4. Jan 14, 2023 at 7:10 PM
    illnevertell10
    illnevertell10 [OP] Member
    If you purchased DD fogs with the backlight option they come with a Y wiring harness with a spade and the spade along with the wire taps go together to tap into power. DD fogs without the backlight option don’t come with a Y harness (I have both).
  5. Jan 14, 2023 at 7:17 PM
    illnevertell10
    Dave said it better than me, the plug and play harness goes to the spade.
  6. Mar 11, 2023 at 4:01 PM
    enolen
    enolen Member
    Eddie
    Does anyone who has connected the backlight using DD’s harness have a pic of where it goes? Or a more detailed explanation than what DD provides.
  7. Mar 15, 2023 at 10:51 AM
    AbadTaco
    AbadTaco Member
    Damn I wish I saw this thread before I ordered backlit fogs and the harness. I thought I was going crazy. I don’t really want to splice into my harness either. Has anyone taken power from their OEM LEDs and had any issues?
  8. Mar 15, 2023 at 10:54 AM
    daveeasa
    David
    PNW
    That's the MAX pod, you're safe drawing power from anywhere you can get it when feeding SS3 backlights.
  9. Mar 15, 2023 at 11:34 AM
    hanlan75
    hanlan75 Well-Known Member
    NNJ
    2023 White Taco SR, 2022 MSM Tesla Y P
    Does the DD harness work with the OEM halogens w/ regular DRL, not the ‘L’ LED DRL? like the light found on a SR/SR5?
  10. Mar 15, 2023 at 11:48 AM
    daveeasa
    David
    PNW
    The DD harness I have seen mates with the TRD DRL connector. This would not be present on SR/SR5 trucks. I don't know if they have a product for SR/SR5. We have a thread for this topic, though, as it gets "complicated" since Turn and DRL are a single wire on SR/SR5.
    t2c likes this.
  11. Mar 15, 2023 at 11:52 AM
    hanlan75
    NNJ
    Thanks. So how/where would I tap for the backlight on a SR5?
  12. Mar 15, 2023 at 11:54 AM
    daveeasa
    David
    PNW
    Short answer is the 3 position turn/park/ground connector where DRL rides on turn. But that means backlight flashes with turn and would go off with parking lights, neither of which is entirely planned for. Read the thread, *it's complicated*. The easy button is INJ in your engine bay fuse box using add a fuse but no way to turn that off.
  13. Apr 6, 2023 at 9:55 AM
    Scissors
    Scissors Member
    Mark
    2018 TRD OR 6SPD MT Cement rolling on 2021 TRD PRO take offs
    My truck is an 18 TRD OR with Halogens that I am going to be upgrading next week to OEM LED headlights utilizing the FBC conversion kit. How does the DD plug and play harness interact with the FBC harness?
    Will all of these components place nice in your opinion? Looking to upgrade fogs while I am already installing headlights and want to plan accordingly.
  14. Apr 6, 2023 at 10:00 AM
    daveeasa
    David
    PNW
    The integrated OEM LED conversion harness provides DRL and Park which can then be combined with diodes and sent to a backlight using the SS3 harness.
    https://fbchs.square.site/product/t...true&sa=false&sbp=false&q=false&category_id=4
    and
    https://fbchs.square.site/product/d...-harness/12?cp=true&sa=false&sbp=false&q=true
    You would only have to decide on
    dual grille headlight harnesses with 2x12" single backlight harnesses
    OR
    single grille headlight harness with dual output backlight harness
    The difference there being cost and a wire across the grille.
    t2c likes this.
  15. Apr 6, 2023 at 10:30 AM
    #35
    t2c
    t2c Well-Known Member
    Dave helped me out when I had this issue installing my ss3 max w/ backlight. Dave was super patient with me and helpful and I highly recommend his products. I had an SR5 without the "L" DRL light. Managed to get it done all plug and play. Now when I have lights off, fog lights also go completely off but they act as a blinker in that setting. When I turn it on to auto, back light comes on unless I turn on the fog lights switch. In which case the fogs turn yellow. When I throw it into parking lights, the backlights come on with my DRL (little amber glow towards the inner part of the lights). Then when I turn on my headlights, my fog lights again go into backlight mode, unless ofcourse I turn the fog lights on, in which case they go yellow. I love the look it gives my truck and I'm grateful to both Diode Dynamics & Dave for all their help in getting it done.
  16. Apr 6, 2023 at 10:53 AM
    #36
    Scissors
    Scissors Member
    Mark
    Thank you very much for this information, I will be going dual with 2x12"s. Is the DD Plug and Play harness no longer required for this path?
  17. Apr 6, 2023 at 11:08 AM
    #37
    daveeasa
    David
    PNW
    It would not be required, correct. But you could use it and the base OEM LED conversion harness as a lower cost option. Their pricing on that piece is vastly superior as I believe they had the harness made in a factory so they can offer one pair for $20 whereas the same thing for me takes a bunch of time and costs 5x ish.
  18. Apr 6, 2023 at 11:31 AM
    #38
    Scissors
    Scissors Member
    Mark
    Appreciate the honesty. I am kicking myself for purchasing the base kit already but I would prefer to go the route of utilizing your products.
    One last question as I may sell my base kit, does your DD Plug and Play harness plugs into the male spade connector on the foglight harness that comes with the lights to hook up to factory fog connector?
  19. Apr 6, 2023 at 11:36 AM
    #39
    daveeasa
    David
    PNW
    I can understand the desire for an integrated solution, I feel the same way myself. But, at the same time, it's just wire and terminals so not like it really matters unless you truly care about tidiness for stuff you can't see.
    The DD harness goes to a spade which goes to the amp which feeds the backlight. My stuff goes directly into the AMP. I'll grab a photo.
  20. Apr 6, 2023 at 11:37 AM
    #40
    VTi EG6
    VTi EG6 Well-Known Member
    TX
    2017 Taco TRD Sport
    I upgraded to OEM headlamps w Dave’s harness. Trying to figure out the best solution as well to wire the back light on the elites if I decide to order. Would rather not splice into wires myself.
    OR Im going to just save and wait on the new Baja LED SAE’s that were just released…
    AmateurTaco1313 likes this.
