Diode Dynamics - Smart-Tap CF18 Relay
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Bruce988jl, Jan 24, 2017.
  1. Jan 24, 2017 at 5:21 PM
    Bruce988jl
    Bruce988jl [OP] Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Diode Dynamics has added another awesome accessory for our Tacoma's!
    The SmartTap is a replacement turn signal flasher module compatible with any vehicle using a CF18 (LM449) Flasher. Programming each mode is simple with the help of the included programming guide and the use of existing vehicle controls.
    Tap-to-Signal: One-touch signaling is a convenient way to signal to other drivers when switching lanes. Simply tap the turn signal for a series of signal blinks.
    Arrival and Departure Modes: When the lock or unlock button is pressed, the surrounding area will illuminate for better visibility when approaching or leaving the vehicle at night. The lighting time can be adjusted from 10-90 seconds for additional illumination, or disabled if desired.
    Unique Hazard Functions: The SmartTap™ has built-in strobe, slo-mo and wig-wag hazard functions to help the vehicle stand out when the hazards are on. Apply these functions on their own, together or with the strobe setting for a total of EIGHT unique hazard functions!
    Video of the Hazard features - incandescent bulbs - I'll add more videos when the revamped units come in. (All new units shipped from 2/13/2017 are the second Rev of the unit and have all the minor issues squared away)
    PROGRAMMING VIDEO!
    It has been brought to my attention that this unit will only work with Tacoma's that do not come equipped with DRL's - This unit only works with CF18 equipped vehicles. Tacoma's have two variations and the DRL uses a larger 12-pin relay.
    No DRL - yes this will work
    DRL - No it will not
    Please make sure your vehicle is equipped with CF18 - which is a 8-pin relay that is located under the driverside dash. If you have the 12-pin blinker relay that is different than CF18 and will not work.
    Also LED turn signal bulbs aren't needed for this to work as well.
    To purchase them check out diode's website:
    https://www.diodedynamics.com/accessories/led-flashers.html
  2. Jan 24, 2017 at 5:42 PM
    VaGlock
    VaGlock Well-Known Member
    Kevin
    central virginia
    14 DBLC / Sport / Blue Ribbon Metalic
    Weathertech mats and wind deflectors, Bak Flip cover, CB Radio,Clazzio seat covers,Scan gauge,Uni filter,LED interior lights, Redline hood struts
    Saw this in the 2nd gen what have done thread, and started a thread in the Lighting forum. Not sure if two threads are needed (my mistake). You beat me too it. But this would be a great product for a group buy.
    Cativelense and ChadsPride like this.
  3. Jan 24, 2017 at 5:52 PM
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Ok, where's @ramonortiz55 ?
    Norton and ChadsPride like this.
  4. Jan 24, 2017 at 5:55 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    So cool, subd.
  5. Jan 24, 2017 at 5:57 PM
    taczilla
    Marc
    2016 RAM Rebel
    :thumbsup:
    pwmullen3 and ChadsPride like this.
  6. Jan 24, 2017 at 6:15 PM
    Bruce988jl
    Southern NH
    I'm sorry guys - My rep at D.D. told me that I am bound to their pricing and if I discount anything I lose my vendor account with them. Therefore there will not be a group buy for these. You guys can either buy direct from them or through me - eitherway you will still get your part.
    I'm really sorry I couldn't be of more assistance. :frusty::frusty:
    Norton, Old School and ChadsPride like this.
  7. Jan 24, 2017 at 6:20 PM
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
  8. Jan 24, 2017 at 6:21 PM
    Bruce988jl
    Southern NH
    :ballchain:
    ChadsPride likes this.
  9. Jan 24, 2017 at 6:42 PM
    Thyces
    Thyces 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    Looks pretty cool. I could have sworn flashing reds is illegal most places though....
    o_O
  10. Jan 24, 2017 at 6:43 PM
    Bruce988jl
    Southern NH
    Where I'm from you can only have amber/white flashing in front. Red behind the vehicle is fine.
  11. Jan 24, 2017 at 6:45 PM
    mach1man001
    Rob
    Bellingham, MA
    2024 Tundra Limited
  12. Jan 24, 2017 at 6:45 PM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Hmmm I'll have to check that here also. Thanks for the info.
    ChadsPride and Bruce988jl[OP] like this.
  13. Jan 24, 2017 at 8:23 PM
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
    Has anyone actually installed one of these in a Tacoma yet? Or verified that the Tacoma uses a CF18 style relay for the blinkers? I'm interested in ordering one but only if I can verify fitment.
  14. Jan 24, 2017 at 8:33 PM
    Bruce988jl
    Southern NH
    It is indeed a CF18 - as far as function unfortunately these were released while I as out of town so I have one sitting at my shop just no way to install it since I'm away. I have sold about 10 units so far so I hope someone chimes in with video footage. My buddy has it installed already on his STI and it functions perfectly as described.
  15. Jan 24, 2017 at 8:44 PM
    WetTaco
    Louis
    Northern California
    2012 DCLB 4x4
    Perfect, after I see a video installed on a Tacoma I will order one
  16. Jan 24, 2017 at 10:34 PM
    Mach375
    Mach375 Habitual Violator of Wheeling Rule #2
    Sathington "Alowicious Devadander Abercrombie" Willoughby (but you can call me Mud)
    '11 DCLB 4x4 TRD Sport
    Too much to list, but enough to get me in trouble. Repeatedly.
    I'll take one. How do I go about getting my mitts on it?
  17. Jan 24, 2017 at 10:43 PM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Is this available on their website? Tried searching Smart Tap, no go though.
  18. Jan 24, 2017 at 11:00 PM
    DJ 06 Dbl Cab
    DJ 06 Dbl Cab Well-Known Member
    DJ
    Hope Mills NC
    06 Pre-Runner SR5 DCSB
    Sent you a pm
  19. Jan 24, 2017 at 11:13 PM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  20. Jan 24, 2017 at 11:13 PM
    Bruce988jl
    Southern NH
    Shoot me a PM and I can set you up with one!
    Its confusing so it's listed under a normal hyperblink fix as seen here:
    https://www.diodedynamics.com/store...05-2013-toyota-tacoma-led-turn-signal-flasher
    However in the drop down menu it is where you select smart-tap and it adds it up to the proper pricing. The 10$ unit is the base hyperblink fix however it doesn't work with vehicles with DRL. The Smart Tap on the other hand, as I was told by Diode themselves will work with DRL. Make sure that you select the Smart Tap option if you wish to order through the website! (I do not work for Diode I'm only a master vendor for them).
    ChadsPride and adio[QUOTED] like this.
