Diode Dynamics - Smart-Tap CF18 Relay
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Bruce988jl, Jan 24, 2017.
  1. Apr 6, 2017 at 6:16 PM
    #81
    WetTaco
    WetTaco Well-Known Member
    Louis
    Northern California
    2012 DCLB 4x4
    For real!! If they did I want one
  2. May 7, 2017 at 10:30 AM
    #82
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Ok i have a 2011 TRD OR, when purchased it had DRL installed. I found some one to change out DRL it ems to revert to non DRL. (non DRL Flasher + some cap thing) Today i looked to see what flasher i had..... to my amazement... I Have an 8pin flasher.... guess im going to order the smart flasher..
    the thread
    https://www.tacomaworld.com/threads/05-drl-daytime-running-lights-install-oem.1475/
    Good info
    https://www.tacomaworld.com/threads...-lights-install-oem.1475/page-20#post-6069816
    DRL parts uninstalled
    DRL parts installed
    Norton and OneFastGeek like this.
  3. May 7, 2017 at 11:48 AM
    #83
    Bruce988jl
    Bruce988jl [OP] Well-Known Member
    Southern NH
    08 Tacoma Dbl Cab TRD Off-Road & 05 Mitsubishi Evo
    Awesome find - I'll have to look into it on my friend's tacoma.
  4. May 7, 2017 at 12:28 PM
    #84
    Muddinfun
    Muddinfun Well-Known Member
    Yep, that's all you have to do to disable the DRL and install the Diode Dynamics flasher. The Smart Tap flasher does a lot of cool things. I did it on my '06. The part# for the grey plastic jumper block is 82671-30360. It's about $8 from the dealer. Then if you want real park lights(the ones next to the grille) install a 3rd wire in the socket and connect it to the corner marker lights.
    Norton, Bruce988jl[OP] and BenMara like this.
  5. Jun 29, 2017 at 1:13 AM
    #85
    Glocker23
    Glocker23 Drive fast take chances
    CT
    2012 DCSB Sport
    Debadged, Tonneau cover, Grillcraft MX grill, OKLED 20" light bar in grill, Aero AT2525 muffler
    damn I wish they would get this to work with my 2012 DRLs It would be amazing
  6. Jun 29, 2017 at 6:48 AM
    #86
    Pistolpetetacotreat
    Pistolpetetacotreat Well-Known Member
    West coast
    2011 DCLB sport
    OME 3" w/ front top spacer Leds BR mounted on retractable tonneau Cbi bump 285's
    Stupid question but when you say DRL are we talking the orange markers right beside the front grill? Or does that mean the headlights on low?
  7. Jun 29, 2017 at 7:42 AM
    #87
    Muddinfun
    The Daytime Running Lights are the turnsignals lit constantly. The sockets have park light and turn signal terminals, but only the turnsignal terminals are wired up.
    Norton likes this.
  8. Jul 5, 2017 at 12:24 AM
    #88
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    So all I need to do to disable my DRL unplug the Y harness. Then plug in the diode dynamic flasher to make it work?
  9. Jul 5, 2017 at 2:37 AM
    #89
    Muddinfun
    That and buy and plug in the above mentioned grey plastic jumper block.
  10. Jul 5, 2017 at 7:39 AM
    #90
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    Ok cool thanks
  11. Jul 19, 2017 at 3:24 PM
    #91
    RecklessTLS
    RecklessTLS Well-Known Member
    Rowdy
    Ft Collins, Colorado / Texas Native
    2009 Tacoma DCSB TRD Offroad 4.0
    TRD CAI and Exhaust,ECGS bushing, Blistien 6112 Fronts at 2.5, SPC upper arms, Bilstien 5160 Rear with 2in AAL, Interior light mod, Back up camera anytime Mod, Overhead Console Temp/Compass Fix. Leather Interior with heated seats, Weathertech floor liners, Ultraguage, Oil catch can, Smart Tap, More to come
    Which third wire is this?
  12. Jul 19, 2017 at 3:25 PM
    #92
    RecklessTLS
    Rowdy
    And does anyone have the wiring diagram of the grey jumper?
  13. Jul 19, 2017 at 3:55 PM
    #93
    Muddinfun
    The front turn signal sockets have 3 terminals, but the wiring harness that plugs into them, only have 2 wires. The 3rd terminal is for the dim filament in the bulb.
    The grey plastic jumper block is just a hunk of plastic with metal pieces that connect terminals together. There is no wiring. You just plug it in.
  14. Jul 19, 2017 at 3:57 PM
    #94
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
  15. Jul 19, 2017 at 4:04 PM
    #95
    RecklessTLS
    Rowdy
    I guess ill have to look it up to see what you are talking about with the 3rd wire. I was trying to save myself a buck and wire my own jumper.
  16. Jul 19, 2017 at 4:17 PM
    #96
    Muddinfun
    You can probably sell the DTRL harness and flasher for more than $8 to somebody that actually wants DTRL. (Canadians)
    whatstcp and Bruce988jl[OP] like this.
  17. Aug 27, 2017 at 6:07 PM
    #97
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Kinda want this. My DRL's can be shut off though. Where's the flasher located so I can check?
  18. Aug 27, 2017 at 6:12 PM
    #98
    Muddinfun
    Back of the fuse block. Post #82 above^. 1st pic is the parts for no DRL. The 2nd pic is the parts for with DRL. If you want to use the Diode Dynamics flasher, you need the grey jumper cap shown in the 1st pic. It's about $8 from the Toyota dealer.
  19. Oct 13, 2018 at 2:12 AM
    #99
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Just bought the regular led flasher to work with my led signal bulbs. Really wishing I bought this. Looks so cool!
  20. Oct 13, 2018 at 9:25 AM
    #100
    Muddinfun
    So, it's only about $10 down the drain. Buy the Smart Tap flasher and go on with life. I just bought a $29 thingy that it turns out I don't need.
    The 2 coolest things about the Smart Tap flasher are the wig wag hazards and the night time illumination after locking the doors. I have been beside the freeway with the wig wags on and I can definitely say the people slow down more for alternating lights. The night time illumination is really nice if you have to walk a little ways in the dark, especially with really bright LEDs.
