Diode Dynamics SS3 Backlight Connectors
Discussion in 'Lighting' started by Foushee, Jun 13, 2022.
  1. Jun 13, 2022 at 10:51 AM
    Foushee
    Foushee [OP] Well-Known Member
    Sean
    Texas
    2018 Inferno TRD OR DCSB MT
    Just getting started.
    I just got a set of the DD SS3 Pro Fogs with the backlight and see in the online specs that the backlights need to tap into the DRL plug. The harness DD sent with the fogs has a red, 1/2" connector for the backlights but tapping into the DRL needs to be done by the customer (they sent those sharkbite-style adapters but I'm not happy using those having seen them cause a short and fire in the past). And after messaging a few individuals that sell harnesses here on TW without getting a response I'm going to dive in a make them myself. It appears the DRL plug matches these parts:
    https://www.bmotorsports.com/shop/p...cts_id/4045?osCsid=otr85kdvsjbb03pfajqgjcuao3
    https://www.bmotorsports.com/shop/p...cts_id/4043?osCsid=otr85kdvsjbb03pfajqgjcuao3
    It appears those plugs are widely sold as O2 sensor adapters and support 16-20AWG wire (I think 18AWG would work for my harness needs), and while I can certainly cut and add a different connector to the DD harness, I would rather just utilized the one already in place. So, does anyone know, from the pictures below, what type of connector this is, and which matching female part I need to add to the harnesses I'm making?
  2. Jun 13, 2022 at 8:13 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    standard 1/4 spade terminals.
    Foushee[OP] likes this.
  3. Jun 13, 2022 at 8:24 PM
    Foushee
    Sean
    Texas
    Thank you
  4. Jun 13, 2022 at 9:32 PM
    caribe makaira
    Caribbean, Puerto Rico
    If your going to add the OEM connectors, why not cut the "insulated" male terminal and double crimp to the terminal for the connector.
    Key-Rei and Foushee[OP] like this.
  5. Jun 13, 2022 at 10:18 PM
    Foushee
    Sean
    Texas
    I was originally going to do just that, but I figured I'd rather not splice into the existing DD harness in case I want to make a change once I eventually replace the bumper.
  6. Aug 4, 2022 at 6:06 PM
    spiced taco
    spiced taco Member
    What did you end up doing in the end out of curiosity? Im trying to wire up mine right now
    Taco22trdor likes this.
  7. Aug 4, 2022 at 10:50 PM
    Foushee
    Sean
    Texas
    I haven't wired mine yet, been stuck on a big project for work and haven't had the time. However, I did buy the components needed to put together a harness that will tie into the DRL for the backlight using the spade connector provided by DD. I'll probably start soldering it this weekend.
  8. Aug 12, 2022 at 10:15 AM
    B Shiloh
    B Shiloh Member
    2018 TRD Sport
    Pretty much stock
    Which wire are you supposed to tap into on the DRL? I have the elite series and want to wire the backlight to my DRL.
  9. Aug 12, 2022 at 10:25 PM
    Foushee
    Sean
    Texas
    What connectors come with the Elites? Here is a diagram I found on here a while back that I'm using for my wiring (sorry I don't recall the OP of the diagram):
    B Shiloh[QUOTED] likes this.
  10. Aug 12, 2022 at 10:31 PM
    caribe makaira
    :smack::rofl::rofl::rofl:
  11. Aug 12, 2022 at 10:40 PM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    @Foushee I'm not sure if you messaged me. I am kind of in and out a lot, so if you did, and I missed it, I apologize. Not sure if you’ve bought parts yet? Feel free to shoot me a PM if you need a hand on anything. The other thing you may want to consider is the DRL circuit on those connectors (position 1) will be powered with the DRL and parking light, but when you turn the low beams on, it is no longer a powered circuit. This isn’t a big deal if you don’t want the backlight in while the headlights are on, but if you do, you’ll need to grab both DRL and parking (position 2 in the above diagram. Those are parking, not turn) and combine them using diodes to prevent cross feed.
  12. Aug 12, 2022 at 10:47 PM
    caribe makaira
  13. Aug 12, 2022 at 10:48 PM
    Puppypunter
    Johnny
    2019 Black SR
    That’s the good stuff! :thumbsup:
  14. Aug 12, 2022 at 11:33 PM
    Foushee
    Sean
    Texas
    Excellent. Thank you for the suggestion, and yes I had PM’d you a while back but no worries, I enjoy figuring these things out (when I have the time).
  15. Aug 13, 2022 at 9:08 AM
    Puppypunter
    Johnny
    2019 Black SR
    Man, so sorry. I kind of come in waves. I know I’m behind, just didn’t realize I was that far behind. Let me know if you need any parts or advice or anything, I’ll try to be more responsive.
  16. Aug 13, 2022 at 11:55 AM
    Foushee
    Sean
    Texas
    No worries man, I've never felt like I'm entitled to a response from any of y'all on here. The fact that TW has such amazing members willing to share information and build one-off custom parts for others is what makes this place great. I appreciate your knowledge and offer to help with wiring questions.
  17. Aug 15, 2022 at 1:32 PM
    My1Yoda
    My1Yoda Well-Known Member
    Alex
    2022 Lunar Rock Tacoma TRD OR
    Recently ordered the ss3 pro with the back lighting amber. Any change if here a harness that is plug and play?
  18. Sep 7, 2022 at 5:42 PM
    mrkothegigolo
    mrkothegigolo Active Member
    I have a 4Runner and just got the SS3 Pro with backlight feature. Would it be the same theory as above if I want the backlight to turn on with DRL as well as headlights? And same question as above. Any harnesses? @Puppypunter I saw you made something for someone on youtube. You still do these? And do you do them for 4Runners?
  19. Sep 17, 2022 at 9:18 AM
    Puppypunter
    Johnny
    2019 Black SR
    I nfortunately don't know the 4Runner that well, but we could probably figure it out easy enough. Shoot me a PM :)
    tfro33 likes this.
  20. Sep 17, 2022 at 9:23 AM
    caribe makaira
    BCC: moi
