Diode Dynamics SS3 Backlight & OEM LED Headlights
Discussion in 'FBC Harness Solutions' started by Jlevitt95, Nov 21, 2023.
  1. Jul 16, 2024 at 8:35 AM
    lstt_b
    lstt_b Member
    2021 Black Tacoma TRD Off-Road 4x4
    Bare with me for my understanding, sorry. So earlier you mention running the morimoto drls and grille lights through one feed. So I imagine this as splicing the grille light wire to the morimoto drl add a fuse wire harness assembly provided by morimoto. Then this combined setup will tap into the INJ fuse. Instead of tapping into the INJ fuse, my question is if I could tap into one of the cab fuses you mentioned instead? So this would be without the halogen T harness
  2. Jul 16, 2024 at 8:39 AM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Yeah, that’s viable too. If you didn’t want to be able to turn off the grille lights.
  3. Jul 16, 2024 at 9:01 AM
    lstt_b
    lstt_b Member
    I would prefer to run the grille lights whenever the truck is turned on, so I'll consider that option as well. I really appreciate your inputs. Thank you for the guidance!
    daveeasa likes this.
