Diode Dynamics SSC2 wiring to 8 way switch panel
Discussion in 'Lighting' started by Curtsailor, Oct 27, 2021.
  1. Oct 27, 2021 at 8:19 AM
    Curtsailor
    Curtsailor [OP] New Member
    2020 SR5
    I just received my set of Diode Dynamics SSC2 pods with the included heavy duty wiring harness provided by DD. I have the Cali Raised 8 way switch panel and need help properly wiring the lights so I can control the backlight feature and main light by two separate buttons on the switch. The switch included with the harness only has three wires running to it, where I would need four to properly wire it to the switch board.
    I am no electrician by any stretch of the imagination so any and all help is greatly appreciated!
  2. Feb 24, 2022 at 3:46 PM
    thenshaw808
    thenshaw808 New Member
    Tommy
    2019 Tacoma TRD Off-Road
    Diode Dynamics ss3 fogs, ssc2 ditch, Caliraised 8 switch, KMC 16s, Bilstein 6112
    Im in the same boat. Just installed SSC2s and use the same controller. I am going to wire using the provided harness but cut harness before the relay. Then both positives to one spot on 8 switch and both grounds to matching switch. Then back lit wire to another switch.
    You also can use the supplied harness and cut off the switch leaving the red wire untouched. Since the lights are grounded already to the battery, You only need to supply power to trip the relay.
    Ground is always there and the one ground to each light in the harness grounds both the main and backlight (hence why there are only 3 wires coming out of each pod.
    The biggest thing I am trying to figure out is what size fuse to use.
  3. Feb 25, 2022 at 8:47 AM
    Taco-rado
    Taco-rado Well-Known Member
    Michigan
    2023 TRD SPORT DCSB
  4. Feb 25, 2022 at 11:37 AM
    thenshaw808
    Tommy
    Just got off the phone with both companies.
    Both are in agreement that we can wire the yellow and blue wires from the switch to separate switches on the 8 switch(capping the red wire that is in the middle section of switch) keeping the DD provided relay and harness or cut the harness up before the relay and just use both red and blue wires coming directly from the pods themselves on separate switches. Going to do the second option tomorrow and will make sure to show photos once completed
    TRD2010SpeedwayBlue likes this.
  5. Feb 28, 2022 at 6:46 AM
    DuffyBank
    DuffyBank Well-Known Member
  6. Feb 28, 2022 at 7:38 AM
    GrizzledBastard
    GrizzledBastard OH NO! I've built a Faux Pro!
    Tim
    Central Coast, CA
    '21 TRD OR 4x4 DCLB Super White
    Not enough bandwidth on the internet to list.
    Curious, what is it about that switch that would allow it to work? I have the SSC2 backlit lights using for reverse and want to replace the little round switch 3 position switch with a small toyota switch. Is that A/B switch just 2 separate switches taking up one space or are the a/b interconnected in some way?
  7. Feb 28, 2022 at 3:34 PM
    TRD2010SpeedwayBlue
    TRD2010SpeedwayBlue Well-Known Member
    Brandon
    2010 Speedway Blue TRD Offroad
    ideally you could wire the backlight to the top button and the ditch lights to the bottom button. and it would take up one switch blank.
    I had a 3d printed switch blank to hold the on off switch that came with the ssc2’s made as i like the switch and it’s functionality
    that switch
  8. Feb 28, 2022 at 4:08 PM
    DuffyBank
    The switch will mimic the one on the DD harness but fit a Tacoma switch spot.
  9. Feb 28, 2022 at 4:11 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    If that's the case, then I need it. I wish CH4x4 offer the same so I can customize the print but it's close enough.
  10. Feb 28, 2022 at 4:29 PM
    TRD2010SpeedwayBlue
    Brandon
  11. Feb 28, 2022 at 4:39 PM
    GrizzledBastard
    Tim
    Central Coast, CA
  12. Feb 28, 2022 at 4:45 PM
    DuffyBank
    I used one of their "high/low" switches for my SS3 pods mounted behind my grill. I have it wired so the pods come on with high beam or low beam or off. The switch is on/off/on. My wiring is on(high beam)/off/on(low beam).
    I have an "A/B" switch waiting on my SSc2 lights that I'll have as reverse lights in the back bumper.
  13. Feb 28, 2022 at 4:47 PM
    TRD2010SpeedwayBlue
    Brandon
    how does that differ? i have the diode switch and it’s up for the backlight than you can leave it in the middle to turn all off. and down for the actual lights.
    individual on and off. i’m a tad confused
  14. Feb 28, 2022 at 4:50 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    That's exactly what I'm using it for, the SSC2 Reverse Light pods. Perhaps I'm not wiring correctly but there seems to be no way to connect it so it works the same as the little switch that comes with the DD Harness.
  15. Feb 28, 2022 at 4:55 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    The backlight should work all the time lights are on. Up should allow reverse light to actuate the pods, down should just actuate the SSC2 as Floods regardless of reverse gear activation. I can't get the CH4x4 switch wired to do that.
  16. Feb 28, 2022 at 5:08 PM
    TRD2010SpeedwayBlue
    Brandon
    ah i hear you now forgot you’re using as reverse
    @memario1214 have any insight here??
  17. Feb 28, 2022 at 5:10 PM
    GrizzledBastard
    Tim
    Central Coast, CA
    I have already taken up 15 minutes of his time today on another matter. I prefer not to risk black-balling. :rofl:
    I'll wait till 3 a.m. his time and call him. :boink:
  18. Feb 28, 2022 at 5:23 PM
    DuffyBank
    Maybe this helps. I received some great advice in the aux high beam thread.
    https://www.tacomaworld.com/threads/the-sae-j581-aux-high-beam-thread.696597/page-24#post-26597752
    If you look closely at the wiring diagram for the anytime camera, you can sort much of it as well. Note there are two extra leads + and - for the switch illumination.
  19. Mar 2, 2022 at 3:46 AM
    thenshaw808
    Tommy
    Just wired ssc2’s to my cali raised panel. Ended up cutting the harness and removing both switch and relay. 2 blacks are ground in ground 1 and 2 and both power for ditch light is in 1+. ambers are in 4+. Running a 10 amp fuse for main ditch and 5 on ambers. 7C690689-E525-4DB5-A56C-2E36DEF67273.jpg
  20. Apr 24, 2022 at 9:47 PM
    DaddyYo
    DaddyYo New Member
    Gerry
    2022 OffRoad
    BRAND SPANKING NEW!!
    @thenshaw808 I notice you're using the mounting bracket. did you only use one screw to mount it in the engine bay? how is it holding up? Can you post a picture of this install? thanks
