diode
Discussion in 'Technical Chat' started by brutalguyracing, Dec 12, 2009.
  1. Dec 12, 2009 at 6:26 PM
    brutalguyracing
    brutalguyracing [OP] BIG DADDY
    F.U> GUYZ
    broken mods
    how do i install a diode in a wire circuit????
    do i solder one end to my 14 gauge wire and solder the other end to a relay?? or how is it done?
    this will be for a reverse light circuit
    just dont know how to go abount installing the diode 3amp 400 volt
  2. Dec 13, 2009 at 11:53 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    no takers????
  3. Dec 13, 2009 at 11:56 AM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
    Where's Chris4x4 when we need em??...Whos turn was it to watch him :laugh:
  4. Dec 13, 2009 at 5:49 PM
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    a diode allows current one way, but not the other. ensure you pay attention to polarity when you install...notice the |< designation...the current flows in the direction of the arrow, and is prevented from flowing the opposite way.
    does this help...
  5. Dec 14, 2009 at 3:30 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    yes i am aware of that but do i just solder the wire from the diode to the 14 gauge wire i am using then solder the other end to the relay???? to install them???
  6. Dec 14, 2009 at 6:41 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    have fun getting a good solder joint on the relay end....you'll most likely end up w/ a cold soldier.
    with that said, dont soldier directly to the relay. have at least a little wire on either end of the diode. its also easiest if you have a crimped connector on the relay end, that way you can release or replace it easy.
  7. Dec 14, 2009 at 8:34 AM
    brutalguyracing
    F.U> GUYZ
    broken mods
    sweet thanks for the info....it was just that the lead on the diodes looked alot thinner that the 14 gauge wire im using
  8. Dec 14, 2009 at 9:19 AM
    yosh2000
    CO
    '17 Tundra CM 5.7
    yep, they are, this is the reason you want wire on both ends...and the connector just makes it easier!!
