Dip stick
Discussion in '4 Cylinder' started by DanGer, May 23, 2009.
  1. Jun 10, 2009 at 3:38 PM
    Pster
    Pster Well-Known Member
    Charlotte, NC
    2006 Tacoma 4x4
    Bak Flip bed cover, shorty antenna, Peripheral iPod interface, Garmin 750 mount, add'l bed tie down rings, Westin nerf bars, hitch safe, tailgate lock, Ideal 1 3/4" turn-key clamp to secure tailgate from removal, Spare tire security cable, spare tire stainless air hose extender, Fumoto oil drain valve, Amp Research Bed X-Tender w/Schlage Cable Lock, bed mat, Redline hood struts
    Interesting....I've drained my engine for hours, with dipstick out, oil cap off and filter removed - in other words, not a drop of oil left in it. Refilled, replaced filter and I have NEVER been able to get more than 5.5 qts back in mine without going WAY over the HIGH FILL line on the dip shit.
  2. Jun 10, 2009 at 3:45 PM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    When my truck was new the oil registered above the fill mark by about 1/4 inch so I figure that's the correct level. However, I've been putting 5.5 quarts in which puts it at the full mark. It's better to be slightly low on oil than overfilling it. JMO.
  3. Jun 10, 2009 at 3:49 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    I would go by the book. The 6.1qts is not just pulled out their ass, and their is no difference between one 2.7 and another that would cause a difference in oil levels (other than using a long filter which the factory specs do not pertain to). The dip stick is what it is, a bent metal rod that dips into the oil pan giving a general indication of oil level.
    If you don't feel like buying 7qts to get that extra .1, 6qts will more then suffice. You also have to consider residual oil that is still inside of the engine. with that said, I fill her up with 6 qts and call it done. (w/ factory short filter)
  4. Jun 10, 2009 at 4:06 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    I agree with everything you said. It's just frustrating, because I've owned over 20 vehicles including other Toyotas, and this is the only one where the dipstick reading doesn't match the fill requirements. My 1994 Corolla that my daughter drives registers perfect on the dipstick.
  5. Jun 10, 2009 at 4:19 PM
    PSJ
    PSJ Prerunners Work
    Sebastian Inlet
    09 Access Cab Prerunner
    Rear Leaf spring TSB, Bilstein 5100's all around w/ front set at 1.75", 265/75R/16 Mickey Thompson Baja STZ's, Trailer hitch w/custom wiring, AFE drop in dry filter, Rear Diff breather mod, Debadged truck, customized stock TRD wheel center caps, added factory fog lights, bed mat, door sills, tinted windows
    I guess Toyota can not be perfect at everything!
    Puzzles me too, as many vehicles when filled with the proper amount of oil read perfectly on the high level mark...:confused:
  6. Jun 16, 2009 at 11:15 AM
    jrws6
    jrws6 Well-Known Member
    Western North Carolina
    07, Dodge Ram 35004x4 Cummins Turbo Diesel 6M
    This is kind of like the tootsie pop commerical.
    How many licks does it take to get to the center of a tootsie pop? 1, 2, 3....
    The world my never know. :)
    I guess we should all call our local quikky lube and ask them. JK :)
  7. Jun 16, 2009 at 11:20 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Same here, manual says 6.1 including the filter. I bought K&N hp1002 & 6 qts of oil. Presoaked the filter with new oil b4 puttin it on & just poured the other 5.5 in the motor. Level is 1/4" or so above full dot on dipstick. Stick should match manual requirements - yet another small fail for manufacturing/design process. I will be saving a half a quart of last bottle next time.
  8. Jun 16, 2009 at 11:53 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    With the price of oil, this is a MAJOR FAIL on the part of Toyota.
  9. Jun 17, 2009 at 8:18 PM
    JonnyReb
    JonnyReb Member
    N.C.
    96 Tacoma,
    This may not apply to the year model taco n question but in my 96 manual, they confuse quarts with imperial quarts, and vice versus. They have them backward. So long as i go with the lesser amount of fluid capacity(a japanese imperial quart?) it works out fine...J
  10. Jun 17, 2009 at 8:41 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Everyone on here realizes the V6 and 4 banger have different capacities....Right???
    5.5 for the V6, and around 6.1 for the 2.7
  11. Jun 17, 2009 at 8:45 PM
    fletch aka
    fletch aka www.BeLikeBrit.org
    Gary
    Left Coast
    09 Magnetic Gray TRD OffRoad
    TRD cat back exhaust, TRD Cold Air Intake, differential breather mod' Hellwig rear sway bar, 16x8 TRD Ivan Stewart's, Michelin LTX A/T2, DTRL Stealth Mode Mod, custom "Texas Edition" shift knob, Sock's "Classic" bedside decals, MetalMiller custom grill emblem, 20% front tinted windows, tinted taillights, Viper alarm, ScanGauge II, Flyzeye Designs V2W Tacoma Interior LED lighting, de-mud flapped, de-badged, extra D-rings under bed bolts, WeatherTech ED floor mats, G4 Elite Fold a Cover ,Toyota bed mat, tailgate theft deterrent device and absolutely no plasti-dip!
    Wow, deep breath...in out in out. :D
  12. Jun 18, 2009 at 4:56 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Yes, 2.7 here, 6 qts including filter put it over the full mark on the stick. Gonna pretend I have the 6 doing oil changes from here on out, lol. Maybe I just have the v6 dipstick instead of the 4 cyl dipstick. I bet Toyota put the wrong stick on the wrong motor, lol.
  13. Jun 18, 2009 at 10:16 AM
    mdbrjb
    mdbrjb Member
    Spartanburg, SC
    05 PreRunner SR5
    Cruise Control, Fog Lamps, Tonneau Cover, KYB Shocks, ScanGauge II, AFE ProDry, Prodigy Brake Controller
    Hi,
    I'm another one that has never been able to put in more than 5.5 quarts. Usually more like 5.25.
    Here's my take on the dip stick theory.
    First, if the 2.7 is anything like other engines that I've taken apart there is going to be some oil that just doesn't drain out no matter how long you wait. There are usually small areas that retain oil and only can be drained by taking apart the engine. How much oil does this represent? Don't really know, but it has to be at least .1 to .25 of a quart.
    Then there is the dip stick.
    All that I've ever read says that over-filling is worse than under-filling. With this in mind, I go by the dipstick.
    Logic is that if the dipstick is correct, but I put in enough oil to go over the high mark then I've over filled it. But if the dipstick is wrong and I use the high mark then I might be a little low. Low is better than high so I just use the marks on the dipstick. This combined with the fact that I'm putting in at least 5.25 quarts would mean that if the dipstick is wrong and there isn't any retained oil still in the block, that the engine is down about .75 (worst case) of a quart. No harm done.
    My guess is that the dipstick is pretty close to correct and that the only time the engine takes the listed capacity is after a tear-down.
    Bob
  14. Jun 18, 2009 at 10:21 AM
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Bob, I go with you. I put a Fumoto valve on my truck so that if I do ever accidentally overfill it, I can drain some very easily.
  15. Jun 18, 2009 at 10:43 AM
    #35
    mdbrjb
    mdbrjb Member
    Spartanburg, SC
    05 PreRunner SR5
    Hi Pster!
    Tell me about the Fumoto valve. Does it hang down at all? I don't usually off-road, but sometimes campground roads can be kind of rough.
    Sounds like something I might want.
    Bob
  16. Jun 18, 2009 at 11:03 AM
    #36
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    http://www.fumotousa.com/
    I have the newer type with the extension to attach a drain tube to, it does not stick down very much, the regular valve even less so.
    Phil
  17. Jun 18, 2009 at 2:34 PM
    #37
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I can't remember the part number for what I have. There's a little tab on the other side that you flip to drain it. Oil comes straight out the bottom on mine.
  18. Jun 18, 2009 at 2:55 PM
    #38
    mdbrjb
    mdbrjb Member
    Spartanburg, SC
    05 PreRunner SR5
    Thanks Phil and Janster! Think I'll get one!
    Bob
  19. Jun 18, 2009 at 3:44 PM
    #39
    Pster
    Charlotte, NC
    2006 Tacoma 4x4
    Make sure you get the right one. I e-mailed them just to make sure and they responded asap. Buy the 5/8" wire clamp to secure the valve lever - keeps it from accidentally being opened. I bought mine from these guys:
    http://www.lubricationspecialist.co...x?fileid=105&gclid=COX0zYLylJsCFRKAxgodD3ZEtA
    I think it is the F-103, or the F-103N with the drain hose nipple.
  20. Jun 18, 2009 at 4:35 PM
    #40
    mdbrjb
    mdbrjb Member
    Spartanburg, SC
    05 PreRunner SR5
    Hey Phil,
    Just placed the order! Thanks for your help!
