Dip stick
Discussion in '4 Cylinder' started by DanGer, May 23, 2009.
  1. Jul 2, 2009 at 4:21 PM
    #81
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I've done 2 oil changes on my '09 2.7....warm oil and 10 minutes drain time. Both times 5.5 qts put it right on the money. With nearly every car/truck I've owned a 1/2 quart less than the actual capacity seem to put the level where it was needed....at least by the dipstick anyway.
  2. Jul 2, 2009 at 5:49 PM
    #82
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    I said screw it, I dont even use oil any more.
    smalldog likes this.
  3. Jul 4, 2009 at 3:21 PM
    #83
    kilgoja
    kilgoja Well-Known Member
    Alabama
    2009 regular cab 4x4 2.7L (silver)
    :mudding:
    every other car i've ever owned took exactly what the manual says and what the full line on the dipstick says...they were the same amount even on my old 1988 toyota truck...so this is screwed up big time
  4. Jul 5, 2009 at 3:57 PM
    #84
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    5.5 quarts does it for my truck also. It a lot easier to add a 1/4 qt. than to take it out. Pretty sure the 6.1 is for a dry fill, after a engine teardown or a new engine.
  5. Oct 9, 2009 at 8:09 AM
    #85
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    Not to beat this in the ground, but i usually put in 5qts, start the engine and fill accordingly as Toyota states. My problem with this dipstick is that even after cleaning off the oil, when i re-insert the stick, pull it back out, i always have oil residue way up the stick?...
    It's very difficult to accurately measure the oil level. I use Mobil 1.
    Oh, and this is my first post. Hello and thanks for all the good information.
    Best,
    Paul
  6. Oct 9, 2009 at 2:19 PM
    #86
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Welcome Paul!!
    Yeah, these dipsticks suck. I've been so tempted to look for an aftermarket 'something' but I just haven't had the time.
  7. Oct 9, 2009 at 4:01 PM
    #87
    91r100gs
    Dan
    Kansas City area
    Paul, even after mine sits all night it still has residue from the dipstick tube. But on mine the other side is usually clean and reads correctly.
    Dan
  8. Oct 10, 2009 at 10:34 AM
    #88
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    dont want to start new thread. i got a questions, changed my oil in my 2.7 prerunner and didnt notice until now its 4.6 quarts refill with filter change.
    i put 5 quarts in should i take some out :confused:
  9. Oct 10, 2009 at 10:41 AM
    #89
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    A 2008 2.7 uses 6.1 quarts. However, the dipstick will show full at about 5.5, so you probably need to add some.
  10. Oct 10, 2009 at 10:47 AM
    #90
    08pretaco
    az
    for the 4x4 or prerunner the oil capacity says its lower. take a look in the manual. but its werid cause it under the 4.0
    it surpases the full dot on the dipstick by alot with 5 quarts
  11. Oct 10, 2009 at 11:00 AM
    #91
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    That is incorrect, bud. The owners manual clearly states 6.1 qts. The oil capacity does not differ from 4x4 to pre-runner. Make sure you are not looking at imperial qts. or some other measurement. The 2.7 engine is the same regardless of pre-runner, 4x4, or base-model, hence the same oil capacity.
  12. Oct 10, 2009 at 11:20 AM
    #92
    08pretaco
    az
    Ill take a pic of what my manual says when I get off work tonight but for now ill put the last quart in there to be at 6 quarts in my car
  13. Oct 10, 2009 at 11:22 AM
    #93
    SC4333
    Grant
    FL
    Its up to you, but I usually fill it up with 5.5qts, start it up and let it run for about 30 seconds, then i'll turn it off and let it sit for a couple minutes. I then check the dip stick and fill as needed.
  14. Oct 10, 2009 at 11:25 AM
    #94
    08pretaco
    az
    I did that and it looked like it was way past the line even after driving for 30 miles I just checked and still looks way full. Ill put the last quart in
  15. Oct 10, 2009 at 3:47 PM
    #95
    crawl
    crawl Well-Known Member
    Greg
    Valencia, CA
    2010 reg cab 4x4 sr5
    keep in mind that if you don't completely drain the pan, you could be overfilling if you're adding the spec'd amount per the manual. make sure you're on a level surface or on a slight decline towards the drain bolt to ensure full drainage. also make sure you're on a level surface when reading the dipstick. my oil level was almost a half-inch above the full mark the day I brought it home from the dealer.
  16. Jun 4, 2014 at 2:45 PM
    #96
    1db2
    1db2 Member
    Dominick
    San Jose, CA
    I called the service department in San Jose, CA today because I put 6 qts of oil in my 2.7L 2012 Tacoma a few days ago only to measure a quart over on the dipstick the next day when cold. The mechanic I spoke with said the same thing as the Toyota reply via email on post #75
    http://www.tacomaworld.com/forum/4-cylinder/38422-dip-stick-4.html
    He said to put in 5 qts and then go by the dipstick for additional fill. He told me the owners manual is giving information on the initial fill for a completely dry engine and some oil always remains in the 2.7L.
    In 40 years of mechanical work I've never seen any discrepancy like this in an owners manual for an engine that Toyota uses all over the world and for many years. I drained a quart out. It's hard to believe the inadequate information given in the manual but I'm clear now. It makes perfect logical sense that the dipstick is the bottom line on an engine with this history though.
  17. Jun 24, 2014 at 1:46 PM
    #97
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Holy old thread revival Batman! :p
    Has anyone added ONLY 5qt with a new filter, run the engine, and checked the level? I am extremely curious what the level was.
  18. Jun 26, 2014 at 8:58 PM
    #98
    Indy
    Indy Master of all I survey.
    Besides the thread from the dead.... Wow.
    Im amazed at the number of people so concerned with having the exact by the books amount of fluid in the engine. I must be the only person that wants a level somewhere between the 2 dots and thats it. Its not an f1 engine, as long as their is oil in it, your fine.
  19. Jun 27, 2014 at 9:09 AM
    #99
    DGXR
    Friend
    Sacramento, CA
    100% agreed. The area between the marks indicates a "safe" level. It's not any more safe at the F mark than it is anywhere between the marks.
  20. Jun 27, 2014 at 4:31 PM
    #100
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I know this is a old thread but I thought I would throw in my 2 cents. From day one of owning my truck the oil level has been above the full mark, and I have put all the miles on the odo. When I took it in for the first couple free oil fills the tech told me "yes" it was high but not a problem. Started doing my own oil changes and when going by the book the oil is above the line. It really concerned me but at 25000 miles I have seen no ill effects and after doing some research I'm not sure how well I can even trust the dipstick to begin with. On the next change I will put in the 5 qts. To start but it really pisses me off frankly how much the stick smears. Most likely I will throw in what the book calls for and slam the hood.
