Dipping vs. Spraying? (painting badges)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCFirefighter, Jul 22, 2010.
  1. Jul 22, 2010 at 3:54 PM
    SCFirefighter
    SCFirefighter [OP] on idiot patrol ;)
    Stephan
    Cary, NC
    Silver 2010 DC TRD Sport 4x4 5'
    MagnaFlow Performance Exhaust, ScanGauge II, Map, dome and license plate LED's, Custom Fire/Rescue decals, Weathertech deflectors, Removed mud flaps, Rear spring TSB, Spidertrax spacers, Tinted windows (5%/27%), Black Tacoma badges, 5100 Billstein x4, ToyTec Coilovers, ToyTec TSB AAL, Devil horns, Hose clamp tailgate mod, OEM bed mat, HomeLink module, Hardwire GPS, Weathertech digital fit floor lines, Front Diff drop, Rear Diff breather mod, 4xInnovation welded sliders, Pioneer AVH-X5800BHS+SiriusXM.
    A friend of mine tried to paint his Tundra badges. I bet he wishes he had a cool Tacoma like me :rolleyes:
    He totally f'd up his badges. Sprayed like my 3yo would, didn't inspect his work, and then put on the clearcoat. It looks horrible.
    I promised I would redo it for him, and I had a thought. (Doesn't happen often; got to go with it when it comes).
    How about dipping badges in a paint bath? I can easily get a test can of black paint for a buck or two and fill up a disposable container with a layer of paint and dip it. Wouldn't that give the perfect streak free drip free cover?
    Any thoughts?
  2. Jul 22, 2010 at 3:58 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    What about run from the paint being pulled by gravity? sounds like a good idea though
  3. Jul 22, 2010 at 4:46 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    a good paint job is all in the prep work
    Spraying gives you more control on how much paint goes on than dipping
    but done right, either should work
  4. Jul 22, 2010 at 4:52 PM
    bailerc
    bailerc Well-Known Member
    Cody
    Fayetteville, NC
    16' MGM Limited
    i painted mine with bedliner , easy and looks amazing
  5. Jul 22, 2010 at 4:58 PM
    SCFirefighter
    Stephan
    Cary, NC
    I sprayed mine. I was just thinking of trying something different. Either way since he botched the original job I'll have to sand them all down now .. ugh
  6. Jul 22, 2010 at 5:09 PM
    Trap
    Trap Well-Known Member
    Indego Ink TRD OR
    Electric Tail Gate Lock, EZ Down + Cable Mod, Galvanized Underbody, DK 9000, CloudRider SS Grill insert. BakFlip HD, Cabin Air Filter mod, Alarm, Zero Rust !
    Best is thin coats so that defeats dipping. Dipping paint will probably screw up. Some coatings might work but paint is a pain.
    His screwed up probably cause the paint is too thick. Thin coats and plenty of drying time between is the key.
  7. Jul 23, 2010 at 7:46 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    +1, I would not pursue dipping, multiple thin coats will work better.
    If you are going with black, should not need to sand all the old paint/clear off, just rough up the clear and start shooting black over it. If there are runs/not-smooth parts of the old paint job then that would need to be smoothed out with sanding though.
  8. Jul 23, 2010 at 8:01 AM
    Beeson
    Beeson Well-Known Member
    Seattle
    '96 Tacoma SR5 4x4
    33" Goodyear Wrangler Duratracs, 15" Unique Steelie rims, Allpro wheel spacers, Heavy Old Man Emu coils, struts, shocks, leaf springs, Daystar 1" spacer, Camburg UCAs, 1" diff drop, NO sway bar, Allpro sliders, Allpro Rear bumper, Bushwacker fender flares, Tire Gate with spare, ARB Deluxe bumper with Hella 700s and 100w bulbs, 100w lights under frame pointed at tires, 50w lights on bumper for reverse, K&N Drycharger with cover, Flowmaster cat-back with custom 2-out exhast, DeeZee tool box, Huskey Liners, 5% window tint, JVC iPhone/CB compatable deck, Bazooka sub, sony speakers, Uniden CB w/4 ft. anntenna, Dixie Horn.
    ^^^^What he said, rough it up with a little sanding, spray thin, and that's it.
  9. Jul 23, 2010 at 8:01 AM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2014 Barcelona Red TRD Off-Road PreRunner
    Clazzio seat covers, KB Voodoo Powder Coated Tailgate Cap, OEM running boards, ImMrYo Rear-View Mirror Lift Bracket, 35% Tinted windows, EGR window vents, color matched door handles and tail gate lift, WeatherTech FloorLiners, OEM bed mat, sound dampening on rear wall and rear doors, on anytime foglight mod
    Pictures my friend ... pictures!
  10. Jul 23, 2010 at 11:59 AM
    06redtacoma
    06redtacoma Well-Known Member
    Alabama
    06 Trd Offroad
    Lifted, Slider, stock rack, rear mounted winch in stock bumper, brush guard, Sound system, ipod to car, tint, wheel spacers, 285 bfg AT,
    what about that liquid dip stuff that's designed to be used on tools? you can buy it at lows i think you can get it in a bunch of colors it may be to thick to still be able to read it. idk worth a try.
  11. Jul 23, 2010 at 12:45 PM
    Trap
    Indego Ink TRD OR
    Like i said some liquids are made to dip this being one. It still does not go on nice though.
    Dipping = thick = weak.
    Strong paint is thin. Paint screws up because people are in a hurry. You can't be in a hurry.
