Dipstick Accuracy
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DSizemore, Oct 6, 2020.
  1. Oct 6, 2020 at 6:01 PM
    DSizemore
    DSizemore [OP] Member
    For all you tech guys, are you finding the oil dipstick to be accurate? I have a 2020 with a six cylinder.
    After a DIY oil and filter change I’m reading a 1/4” above the full mark. 6.2 qts of oil and an OEM filter.
    CMScheid and VB25 like this.
  2. Oct 6, 2020 at 6:04 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Sounds bout right. I just drain it with a filter and dump six in it. I check it once or twice just to verify its not low and never check it again. It's too hard to see haha
  3. Oct 6, 2020 at 6:05 PM
    VB25
    VB25 Well-Known Member
    2018 TRD OR ACLB AT
    I noticed this on my first and second oil change. From now on I’m just buying 6qts since I keep a spare on board. Seems 6 puts it just at or below the full dot on the stick.
    CusterFan, BlackTRD4Me and whatstcp like this.
  4. Oct 6, 2020 at 6:10 PM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    I've not changed my oil yet but I've checked the oil already and it's even that full from the factory.
    davidstacoma and DAS Taco like this.
  5. Oct 6, 2020 at 6:12 PM
    Professor D
    Professor D Ex retired lion tamer
    Gregorny
    Mass
    2019 Toyota Tacoma race car
    Yes
    I go six quarts in my oil no issues think you’re about spot on. Would keep it between 5.5-6 quarts. Will agree the dipstick sucks make sure oil is cold.
  6. Oct 6, 2020 at 6:31 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
    The manual actually recommends you run the engine till warm, shut it off, wait at least 5 minutes, then check the oil level.
    Not sure why the warm part matters, I'd imagine if you let the truck sit overnight you would have the maximum amount of oil in the pan which might make the dipstick read a tad high.
    If you haven't already, maybe try the warm engine, shutoff , wait 5 minutes method and compare?
  7. Oct 6, 2020 at 6:37 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    I never put the entire official recommended oil amounts in either my old gen 1 or my new gen 3. It would have been too much.
    CusterFan and Garyji like this.
  8. Oct 6, 2020 at 6:39 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Thermal expansion/ prime the filter?
    Also, OP, make sure u pull the dipstick out and let it sit before reinserting
    H6G, CusterFan and kahanabob like this.
  9. Oct 6, 2020 at 6:44 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    not an issue
    dipsticks are there to gauge when oil levels are toooooo low
    does more harm then
    its been almost a century since engines were ' splash ' lubricated
    the crank weights & big end rods actually beating the oil in the sump
    true some gets thrown around yet U would have to have near double the sump capacity to engage oil & crank
    a quart either way is no worry
  10. Oct 6, 2020 at 8:15 PM
    Fury
    Fury Well-Known Member
    I add 4.7 liters after draining and changing the filter - start - wait 10 min and check the stick. I then do a full heat cycle before doing a final adjustment to the full mark.
    1 - I did a hot / wait 10 min / check vs a sit overnight / check and found only 1/8 inch difference with the hot being higher of course. Since the difference is so small I check my oil cold after sitting overnight. It is easier to read as well.
    2 - An engine over full is taking a chance on being churned by the crank and getting foamy. Bubbles in the oil stream to any plain bearing is not good. While not as bad as an engine that is low on oil, why chance it by not checking and relying on the stick.
    3 - I check the oil on any engine on a regular basis. My truck is a keeper so it gets checked weekly and before any trip - towing or otherwise.
    Just my 2 cents ...
    Junkhead likes this.
  11. Oct 6, 2020 at 8:39 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    My taco is only 25k miles and the engine oil is so clear that I can barely tells there’s oil on the dipstick. I just drain until it drips and put 6 qts and I’m done. The 0.1 qt is negligible.
    TacoBlancoOffRoad and CusterFan like this.
  12. Oct 6, 2020 at 8:50 PM
    Beancooker
    Beancooker Alea iacta est
    The middle of Arizona
    2021 Jeep Wrangler Rubicon
    Lots, straight from the factory.
    This is the first vehicle that I have had in quite a few years that has a dipstick. My BMW and the Benz didn’t have them.
    Honestly, 7700 miles and I’ve never checked it. Maybe I’ll look in the morning.
  13. Oct 6, 2020 at 9:43 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    I never go by the volume. Too many variables with components to depend on that. That’s why Toyota says to check the dipstick. Also why for the diffs and transfer case oil they say to check the level by hand.
    QwickC likes this.
  14. Oct 7, 2020 at 5:17 AM
    DSizemore
    Thanks for responding guys. I’ve changed my own oil for years and they’ve all read per the mark on the stick when filled to specs. It’s the first change for this truck and although I did check the level a couple times between new and now ( 6000 miles ) I honestly can’t remember if it read a 1/4 over or not. I suppose I now have a baseline, huh.
  15. Oct 7, 2020 at 5:22 AM
    kaijac03
    kaijac03 Well-Known Member
    Kai
    Florida
    2017 Tacoma, TRD Off Road
    Yea, I just go with 6qts. Gets it just under the full mark, with new filter.
  16. Oct 7, 2020 at 5:53 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
    A dipstick ain't rocket surgery. It ain't gotta be precise.
  17. Oct 7, 2020 at 6:11 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Always thought as long as the oil level read between the marks on the dipstick it was properly filled. On my 4.7 tundra it was always a tad over 6 qts.
  18. Oct 7, 2020 at 10:52 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    I was wondering the same thing myself. New 2.7 and looking up the specs, it says with oil/filter change 6.2-something qts of oil.
    (I plan on changing my own when I hit 5K ... Just because it'll make me feel better ... Then letting the dealer do their thing at my 'free' oil/filter change at 10K ..) And I thought '6.2X' quarts of oil? Where did that come from?'
    And I was a bit disappointed at the 6+ quarts of oil ... Especially as a 5 qt. jug of Mobil 1 (Example) is about $25.00 +- , and just a quart is about $8.00 +- ... (Go figure, right?) .... So I'll probably just bite the bullet and buy 3, 5 quart jugs, just to save some $$ on down the line. I'm supposed to get my first 3 oil/filter changes for 'free', so I'll just have oil on hand for afterwards.
    I'm wondering if the 'specs' are assuming you'll always use genuine Toyota filters. (?) ... I've been a big believer in WIX XP filters for decades now, but they.. Like many other brands ... Are not all the same size. The WIX filters are a bit shorter (Not much, but still) than the Toyota filters. And other brands of filters are kinda' all over the place, so far as size also. So maybe that's where the little bit of 'extra' over just a straight 6 qts comes into play?
  19. Oct 7, 2020 at 11:52 AM
    Tacomike18
    J
    I always do my oil changes at 5k miles intervals and buy Mobil 1 0-20 full synthetic and use the Mobil 1 oil spin on filter. I don’t actually drain the oil 100% so putting in 6 qts is ok. I usually pay $60 for oil and filter and do the oil change myself.
    Junkhead and BMH[QUOTED] like this.
  20. Oct 7, 2020 at 1:27 PM
    BMH
    Bruce
    Who makes the Mobil 1 filter? I know that the NAPA 'Gold' filters and (I forget what they're called) the 'top' filters at O'Rielliys' are made by WIX.
    I'm with ya on the 5K oil/filter changes though. I'm 65 and have yet to ever see an engine ruined because the oil/filter was changed too often. :thumbsup:
