Dipstick broken inside tube, help!
Discussion in '4 Cylinder' started by marksnet, Mar 29, 2015.
  1. Mar 29, 2015 at 3:56 PM
    marksnet
    marksnet [OP] New Member
    Hey,
    I just bought a used 2007 tacoma 4x4 access cab 2.7l. I went to check the oil today and there appears to be a piece of the plastic end of the dipstick handle stuck in the tube down about 1" down from the top. there is a visible slot where you can still pass the dipstick through but I am unable to get an accurate reading on the dipstick as it smears as it comes through. and requires a significant amount of force to insert/ pull. There should not be anything 1" down from the top of the tube correct? I have tried to pull it out with a cutoff allen key but didn't want to pull to hard in case it is meant to be there! Has anyone replaced the entire tube?
    Thanks,
    Mark
  2. Mar 29, 2015 at 4:08 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe a paperclip unfolded with the ends just turned over a touch to grip the underside or a fairly long thin screw might catch it enough to pull out.
  3. Mar 30, 2015 at 7:14 PM
    marksnet
    I tried cutting off a 1.5mm jet allen key and pulling it up but it would not budge. I ended up removing the dipstick housing and drilling out the plastic upside down and cleaning it thoroughly. the tube was simple to get out I just had to undo one nut and hit it up from the bottom with a long flat head screwdriver. I am not sure how the previous owner managed to snap the dipstick off where it did but i did not need any new parts and I can now read my dipstick!
  4. Apr 6, 2015 at 3:46 AM
    scootn2nature
    scootn2nature ttora member since 2001
    orinda
    2000 2.7l sr5
    bentup sliders, tjm t17, badland rear,custom leafsprings, fabtech performance co's,
    take it the one bolt off pullit straight out and turn it upside down
    installation in reverse order check the o ring
    buy new muffler bearings too since they escape during this process noooo Im
    joken
  5. Apr 20, 2015 at 6:34 PM
    knuckleduster271
    knuckleduster271 Well-Known Member
    Baron Longrod Von Hug€nschlong
    ohio
    98 sr5 xtra cab
    881's, 5100's, soft 8's, elocker, matrix seats, smittybilt xrc8.
    Use an air compressor to force air into the crank case, it will fly out. Ive done a few this way.
  6. Apr 22, 2015 at 11:53 AM
    Hublocker
    Hublocker Well-Known Member
    I turned down a truck last month with that problem.
  7. Apr 22, 2015 at 11:54 AM
    Taco me elmo
    Taco me elmo Here, Eat some paint. Drink some Bleach.
    Tophat bobcat
    North of South, East of West
    Slow polished TuRD
    Anti theft 5-Speed
    Turn truck upside down and shake. :D
