Dipstick the worst to read after oil change
Discussion in '3rd Gen. Tacomas (2016-2023)' started by EB Group, Jun 21, 2017.
  1. Jul 21, 2024 at 9:31 AM
    #81
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If you think you see the line but aren't sure, try sticking it back in but leave it out a 1/4 inch or so, then pull the stick and see if the line moves down the same distance. It puts the line in a slightly different spot and can help you make sure you're seeing things correctly
    If that makes sense..
  2. Jul 21, 2024 at 10:47 AM
    #82
    bgavin
    bgavin Well-Known Member
    Orangevale, CA
    2023 Tacoma Access Cab, V6, 4WD, A/T, OTT Medium/Spicy
    CURT Mfg front receiver, anti-theft cages around cats
    This sounds like the most workable solution I've read so far.
    The oil in the pan will coat the INSIDE of the plastic tube, and not be subject to picking up oil residue on the walls of the dipstick tube.
