Dipstick
Discussion in '2nd Gen. Tacomas (2005-2015)' started by merkman, Feb 4, 2014.
  1. Feb 4, 2014 at 8:39 AM
    merkman
    merkman [OP] Well-Known Member
    Etna, NH
    2012 green
    The dipstick is the worst dip stick I've come across in my driving life, across a dozen platforms. All I can say is "You've got to be f%^&*ing kidding me"
    Any ideas to make it better?
    thanks for the short rant!
  2. Feb 4, 2014 at 8:44 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ain't it a peach?
  3. Feb 4, 2014 at 8:51 AM
    02Duck
    02Duck manuals make it better
    2018 4WD TRD Off Road 6MT
    TRD Exhaust, Mobtown bolt on sliders and aluminum tailgate reinforcement, Reverse lights changed to yellow turn signals, LED pods added for reverse, ADD W1 oil catch can, Total Chaos bed reinforcement, rear diff breather to taillight mod, 12" combo led bars behind lower grill wired to high beams, Toyota led bed light kit, 400 watt anytime mod, SSO slimeline front bumper.
    I recently had the same experience. Unbelievable that Toyota messed up such a basic piece that has been around for so long. I was amazed that 25+ year old Honda right next to my new Tacoma has things on it that or needed (like a dipstick) that work perfectly, but Toyota f'd it up.
    Some people have sanded the end.
    What I finally settled on doing (even though I can't believe I have to) is leave the dipstick out for at least 10 minutes, longer if possible. Insert and pull read carefully. If you reinsert and immediately pull the stick, it will not read correctly. You have to wait another 10 to insert and pull again.
    What seems to happen is when you pull the stick oil rubs off on the tube on the sticks way out. Which then transfers back on the stick when you check again.
    Good luck and know many feel the same way. You have to love them engineers.
  4. Feb 4, 2014 at 8:53 AM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    There's nothing you can do. Just have to wait for the oil to settle.
  5. Feb 4, 2014 at 8:55 AM
    Juan Solo
    Juan Solo Well-Known Member
    Johnny
    Houston
    2014 4x4
    Must be a Toyota thing. My Yaris' dipstick is plastic from top to bottom. But at least it works lol.
  6. Feb 4, 2014 at 9:04 AM
    TaylorU
    TaylorU KC HiLiTES Vendor
    Taylor
    Flagstaff, Arizona
    2010 4x4 TRD Off-Road
    ADS 2.5" coilovers, Light Racing UCAs, 2.125" rear ADS shocks, Raptor-Style Grille using Homertaco mesh and BAMF letters, MB 352 wheels, 285/75r16 Cooper ATPs, Mini D2S 3.0 HID Projectors retrofitted, KC Flex 20", KC Pro6 light bar, KC G4 LED fog lights, Pelfreybilt front bumper
    Haha Ive always felt this way too
  7. Feb 4, 2014 at 9:06 AM
    WV150
    WV150 Well-Known Member
    South Carolina
    Trifecta Tonneau Cover
    Check it first thing in the morning before you start it if it is fairly level where you park.
  8. Feb 4, 2014 at 9:11 AM
    Larry
    Larry CARL
    CARL
    Mine works fine
    Maybe I'm not a dipstick who doesn't know how to use a dipstick :laugh:
  9. Feb 4, 2014 at 9:34 AM
    merkman
    Etna, NH
    2012 green
    I had the pre tacoma 95 P/U (22RE) prior to the 12. I was amazed at how many features were the same as my 95.... but not the dipstick...that needed re-engineering to decrease its effectiveness.......to almost USELESS..... Arrrrrrrrrrrrg
  10. Feb 4, 2014 at 10:03 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    LOL!!
    mine works as well..i might have to turn it over to look at the other side, but one side or the other..i get the reading.
  11. Feb 4, 2014 at 11:37 AM
    Jrahn0822
    Jrahn0822 Well-Known Member
    Jake
    Iowa
    07 DCLB
    I will say that the first time I pulled it I was like what the heck, only two little dimples?!? But honestly it's a dipstick. The concept is the same as if it's textured between the dots or not. Its not that big of an issue
  12. Feb 4, 2014 at 11:40 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    :popcorn:
