Direct (gas) Impingement vs. Piston
Discussion in 'Guns & Hunting' started by Xshark, Feb 16, 2012.
  1. Feb 16, 2012 at 12:26 PM
    Xshark
    Xshark [OP] Well-Known Member
    A whole lotta ink has been spilled in this debate.
    I've read lots about it, but I'd like some first-hand experience from the 'Team Piston' group.
  2. Feb 16, 2012 at 6:18 PM
    wileyC
    wileyC Well-Known Member
    Centerville, OH
    2012 PreRunner Double Cab TRD Sport
    well, as you alluded to this is quite a debate... i dunno, from what i've heard DI should be plenty reliable for most uses, ...i've heard the piston systems can have problems of their own..
  3. Feb 19, 2012 at 9:29 PM
    ChewbacaTW
    ChewbacaTW My progeny will be awesome!
    Sam
    Flagstaff, Arizona
    02 Xtra Cab TRD off road
    K&N air intake, custom exhaust, Powerslot Brakes, urethane steering rack bushings
  4. Feb 26, 2012 at 4:07 PM
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    ^^^ +1.
    I got 2 DI AR's and 2 piston AR's.....I'll take the piston gun over the DI anyday. Less lube, less potential for failure, and most importantly (practical reasons) less cleaning. :D
  5. Feb 26, 2012 at 9:14 PM
    Alderleet
    Alderleet Ace of Spades
    Nick
    Salty Hell
    '00 Acc Cab TRD 4x4
    I love Piston over DI, however there is a larger debate raging with Long stroke piston vs short stroke.
    Short stroke is more accurate, given the energy is applied as a single momentary impulse. Long stroke is more reliable, given that all components are connected and the only form of blockage would be a destroyed gas tube...
  6. Feb 27, 2012 at 9:33 AM
    Murph
    Murph Go Pack Go!
    Tyler
    Fox Valley, WI
    2000 Extra Cab TRD O/R
    3" lift. American racing 15'' rims. 33x12.50 BFG A/T tires. tool box. ARB bumper, mile marker winch, kc highlights. No carpet inside sprayed with bed liner. Kicker door speakers. Alpine head unit.
    The piston ar's have seen key fractures, but the HK MR 556 A1 is too legit to quit! Leave it up to the Germans to over engineer :D.
  7. Feb 27, 2012 at 3:40 PM
    Skimafia
    Skimafia Well-Known Member
    I sold a DI gun for a piston gun for two reasons. The first is the amount of time it took to clean. Every time I shot it I would have to dedicate an hour or more to cleaning it out.
    The second reason was reliability. I am sure a major reason I had issues with my gun was because it wasnt the best AR brand out there. I had a Bushmaster Predator that was an amazingly accurate gun. But I had failure to feed issues from day one. Probably one out of every 30-40 shots wouldnt cycle. I tried different ammo, different amount of oils in the gun, and still had problems. There is nothing worse in my opinion than a gun that isnt reliable. So I sold it and bought a Ruger SR556. I have put 1000+ rounds through it with not a single problem. And its is so so easy to clean!
