Direct Mount Roof Racks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jimmytwoshoes12, May 12, 2016.
  1. May 12, 2016 at 2:10 PM
    jimmytwoshoes12
    jimmytwoshoes12 [OP] New Member
    2015 Blue Tacoma 4x4 V6 Manual Double Cab
    None.
    I have a 2015 Tacoma Double Cab and am looking at adding a roof rack with the plan to primarily carry 2 kayaks. The weight limit on the OEM rack seemed a little on the low side for the kayaks and the J-racks (kayaks are listed at 48 lbs/piece). I won't generally be driving very far with the kayaks (so maybe the 100 lbs is sufficient?). Either way, I wouldn't mind something a little more robust if possible. I am a little leery about the feet/towers that have the latches that lock into the door frame seems like they'd scratch/dent over time. So I'd really prefer to be able to do something that mounts directly into the space that is already there. What are the options? I haven't had a ton of luck. The racks from Baja and Prisnu look like they might be a bit too robust for my needs and aren't exactly aesthetically pleasing. Thanks for the help!
  2. May 12, 2016 at 3:33 PM
    Pigpen
    Dan
    Northwest Montana
    Looks like you have the age old fashion or function dilemma.
    I opted for Yakima Q towers, for better and worse. I like being able to remove them when I want. I did improperly load them once with my 100 pound canoe (canoe wasn't the problem - I was) and dented my roof. And they can fuck up your paint too, if you don't remove them and clean everything regularly.
    I vote Prinsu for fashion and function, I really like the Baja flat racks too if you want lower profile.
  3. May 30, 2016 at 6:02 PM
    AdamBWB
    AdamBWB Member
    Adam
    '16 TRD Off Road - Inferno
    TBA still awaiting delivery
    do you know if either of those racks can handle the weight of a CVT tent? its about 150lbs and i would like to use it so add another 200lbs and possible guest.
  4. May 30, 2016 at 6:18 PM
    clc clc
    clc clc Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    I have Thule rails on my cap and haul all kinds of stuff.
    I don't see why the bars couldn't hold the weight, my limiting factor is the strength of the cap.
  5. May 30, 2016 at 9:27 PM
    Pigpen
    Dan
    Northwest Montana
    The load recommendations include traveling at highway speed, so wind and inertia are taken into consideration. I know some people run tents on these setups, some add a third bar for added support - really easy to do. If it was me, I'd go with a permanent rack system if I was doing a RTT, but I am sure a Yakima or Thule will work.
