Directional Tires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kngharley, Jan 24, 2010.
  1. Jan 24, 2010 at 4:24 PM
    kngharley
    kngharley [OP] Well-Known Member
    Corona, Ca
    Does anyone know if putting on a directional tread tire backwards will cause your truck to vibrate at high speeds.
  2. Jan 24, 2010 at 4:30 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    i would think so....let alone the fact of screwing the tread earlier. directional for a reason
  3. Jan 24, 2010 at 4:32 PM
    CUtigerfan
    CUtigerfan Well-Known Member
    South Carolina
    04 Base
    Daystar 1.5" coil spacers, bedlined bumpers, clear corners, aftermarket stereo, 20% tint, half debadged
    I wanna see what people say about this. My buddy has an old jeep and somebody slashed one of his MTs so he put on the spare but the treads in the wrong direction
  4. Jan 24, 2010 at 4:34 PM
    The_Hodge
    SC
    yeah...lots of people do that on the front tires to get better tractio on rocks, etc. the added traction is what they werent made for on the highway
  5. Jan 24, 2010 at 4:36 PM
    kngharley
    Corona, Ca
    yeh thats what I thought too. Just got my truck back from the back from the body shop. They had to refinish my rims and must have pulled the tire off of the rim and installed it backwards. They also failed to tighten the lug nuts on both front tires
  6. Jan 24, 2010 at 4:39 PM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    ^ ouch. That doesn't give you much confidence in the other work they did.
  7. Jan 24, 2010 at 4:43 PM
    kngharley
    Corona, Ca
    the body work came out good. Just the tire issue so far/
  8. Jan 24, 2010 at 5:08 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    they want vibrate if on backwards,the tread design is made to shed water to get better grip in the rain.
  9. Jan 24, 2010 at 5:30 PM
    Speed Nut
    Speed Nut Well-Known Member
    I know Goodyear Ultragrips (passenger cars tires) are directional which allows greater water dispersion due to the tread design. If the tires were put on backwards then the water would not be dispersed thus causing a loss of traction due to hydroplaning.
  10. Jan 24, 2010 at 5:38 PM
    HondaGM
    James
    South-Pole, Alabama
    2023 access cab V6
    true:D
  11. Jan 25, 2010 at 7:55 PM
    blackbox
    blackbox Well-Known Member
    SE Ohio
    2010 reg cab 4cyl 5mt 4x4 Pyrite
    Bought a truck once, it had directional tires on it, which I didn't realize until I rotated them a couple times, I didn't get any vibration but every one of those tires had to be replaced due to tread separation. They were mostly wore out anyway, no big deal, but ever since I have paid more attention to whether tires were directional or not, seems like it was just way hard on the tires to run them in the opposite direction. Just my 1-time experience, might not even be anything to it.
  12. Jan 25, 2010 at 7:57 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    ive actually heard that the offroad directional tires...if mounted in reverse...not only do you gain traction...but you can gain some highway life out of them
    i may be speaking out of my ass as i dont have any nor have i ever owned any...but ive heard it a few times
  13. Jan 25, 2010 at 9:38 PM
    kngharley
    Corona, Ca
    I took it to the shop today and they are telling me they fixed the problem by reinstalling the tire the right way. I guess I will have to see tomorrow
  14. Jan 25, 2010 at 11:39 PM
    bmgreene
    bmgreene Well-Known Member
    Brian
    L.A. Westside
    2010 PreRunner V6 SR5/OR
    Alcan Leaf Packs, OME884 Coils, 5100 shocks, U.S. Offroad Winch Mount w/Winch, Trail Gear Rear H/C Bumper, Prinsu Cabrack, DIY custom in-bed storage/sleeping deck, Sway bar delete, hidden "snorkel" intake mod, In-dash CB, Bestop Supertop, Undercover Swingbox, hood lifters, assorted lights and front spotting camera
    Loose nuts can definitely give you some nasty vibration. If you drove far like that you're probably lucky and didn't turn much.
    Not sure what effect a reversed directional tire would have besides screwing your wet traction, but it probably depends on the tread pattern and the condition of the surface you're running on.
  15. Jan 26, 2010 at 12:00 AM
    SkyHighTacoma
    SkyHighTacoma Josh
    Josh
    Brazoria County Texas
    15 DCSB SR5 MGM
    Umm, this is a lil off topic. But can someone tell me if the cooper discoverer st's (not stt's) can go both way's? :eek:
  16. Jan 26, 2010 at 1:05 AM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Mounting a directional tire backwards will not cause a vibration or have more tire wear because of it. The purpose of directional tires/tread is to channel water between the tires' footprint and the road, decreasing the chance of hydroplaning. But, you can still hydroplane even if you have directional tires. I had directional tires on my civic and one was mounted backwards and didn't even know it until someone pointed it out to me.
