dirt bike in doublecab bed tailgate closed, brainstorm
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacoTaro, Feb 19, 2015.
  1. Feb 19, 2015 at 10:44 AM
    TacoTaro
    TacoTaro [OP] Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    So I am looking to tow a trailer (that's a different thread) but I need to carry motorcycles in the bed at the same time. That means I need to be able to close the tailgate with the bike loaded.
    Anybody have some creative solutions for me? I have been dreaming up all kinds of crazy fabricated/home made solutions, like lifting the rear wheel over the closed tailgate using a stand of some sort.
    Thoughts?
  2. Feb 19, 2015 at 11:38 AM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    I take it diagonal won't work either. What if you pull the front wheel off and make a little bracket for the fork like a bicycle roof rack, but mount it to the front bed rail.
  3. Feb 19, 2015 at 11:47 AM
    TacoTaro
    Los Angeles
    04 DC 4x4
    Diagonal won't work, bed is too narrow and the wheel wells go all the way to the front of the bed.
    Interesting idea. Bracket would need to be heavy duty to hold up to a 300 pound bike. Probably bolted to the bed floor using some thick steel.
    I think it would be easier to secure the bike with the front wheel in place. I would have to measure it to see if that would shorten it enough.
  4. Feb 19, 2015 at 11:56 AM
    BadBrains
    BadBrains Spreading the Aloha
    AL
    '07 Taco LT, '00 GS-R, '75 C10, '83 CJ-7, '19 T4R SR5
    King, TC +2"LT, 35's, Aluminum this and that.
    Take off the tailgate temporarily?
  5. Feb 19, 2015 at 11:58 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    My dad used to haul a motorcycle and tow his camper and the bike was too long to fit in the bed. He made a platform out of plywood that fit in the bed and went off the back edge a bit. He supported the back edge with a couple blocks of wood bracing it down to the step in the bumper so the rear tire would be supported. This allowed him to tow the trailer and the bike, he just had to completely remove the tailgate.
  6. Feb 19, 2015 at 12:07 PM
    Boerseun
    Boerseun Well-Known Member
    Ferdie
    Sarasota, Florida
    2018 Tundra TRD Sport 4x4
    Upgraded 2002 Tacoma to 2018 Tundra
    ^^^something along these lines would be the only way to do it. Either plywood or a C-channel steel section for the rear wheel to sit on.
  7. Feb 19, 2015 at 12:17 PM
    ChrisH
    ChrisH Well-Known Member
    Orinda, CA
    '00 PreRunner
    Don't over think it. :)
    Just get a hitch extension so the trailer sits further back. Then you can have the tailgate down with the motorcycle wheels on the tailgate.
    HF has them for $20 Here's some info from etrailers, take note of the tongue weight reduction.
    http://www.etrailer.com/faq-hitch-adapters-extenders.aspx
    I'll add that you may need longer safety cable/chains & trailer wiring...
  8. Feb 19, 2015 at 12:18 PM
    Boerseun
    Ferdie
    Sarasota, Florida
    Another option is a hitch receiver extension. That way you can keep the tailgate down and the hitch point would just be further back. It just depends on how big/heavy your trailer is.
  9. Feb 19, 2015 at 12:18 PM
    Boerseun
    Ferdie
    Sarasota, Florida
    ^^^^ LOL, posted the same time.
  10. Feb 19, 2015 at 12:20 PM
    Pugga
    Massachusetts
    For anything beyond a very light flat bed trailer, I wouldn't do the hitch extension. That just puts the point load of the trailer that much further behind the rear wheels, making it feel a lot heavier than it actually is (especially when there is already a motorcycle in the bed).
  11. Feb 19, 2015 at 12:49 PM
    TacoTaro
    Los Angeles
    04 DC 4x4
    I'm looking at a small travel trailer. So 2500 pounds dry. Maybe 3000-3200 loaded. I think the GVWR is going to be in the 3500-3700 range
  12. Feb 19, 2015 at 12:53 PM
    TacoTaro
    Los Angeles
    04 DC 4x4
    The double cab bed is so short that the rear tire is completely on the tailgate.
  13. Feb 19, 2015 at 1:38 PM
    taco206
    taco206 Well-Known Member
    Mill Creek, WA
    14 DCSB SR5 PreRunner 2.7L
    I would set down a 10 inch wide 1 or more inch thick piece of plywood running diagonally to the back of the truck. It would have to be cut at the correct angle to fit in tight into the front corner of the bed. A cradle around the rear wheel of the bike to hold it tight. Since the front wheel will be strapped down hard onto the front of the board, it would be in there tight. The rear would need to be braced some to prevent shifting.
    This way the tailgate could be removed
    Kinda like this:
  14. Feb 19, 2015 at 4:44 PM
    bighouse01
    bighouse01 Well-Known Member
    NY
    04 DC TRD
    How about a small boat trailer. They are way long. Tailgate down and plenty of room. You can custom build a deck on it to fit whatever you need.
  15. Feb 19, 2015 at 4:50 PM
    ErocksTaco
    ErocksTaco Well-Known Member
    Eric
    Denver
    06 4x4 DCSB Sport Radiant Red
    OME 886 and rear Dakars Light Racing Upper Control Arms All pro U-bolt flip with Timbren Bump Stops CVJ Reman axles with off road boots Adventure Offroad Fab Sliders ARB Front Bumper Interior LEDs Weathertechs 2009+ taillights 2009+ headlights
    Trade up to a long bed
  16. Feb 19, 2015 at 6:28 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
  17. Feb 19, 2015 at 6:39 PM
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    what about putting the rear tire at the front of the bed, and turn the front tire sideways along the tailgate. idk.
  18. Feb 19, 2015 at 6:41 PM
    Broke Okie Ty
    Ty
    You ever tried to load a bike backwards? it sucks...
  19. Feb 19, 2015 at 6:51 PM
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    just strap the bike down with the tire on top of the tailgate! thats what id do. if your worried about the tailgate put some foam inbetween there.
  20. Feb 19, 2015 at 6:52 PM
    POOLGUY
    JEFF
    ALABAMA
    yes, i have and it is a pain in the ___.
