Dirt King Fabrication 3rd gen Tacoma Long Travel Install
Discussion in 'Long Travel Suspension' started by Dirt King Fab, May 20, 2021.
  1. May 20, 2021 at 2:08 PM
    Dirt King Fab
    Dirt King Fab [OP] Well-Known Member
    San Diego
    2013 Toyota Tacoma
    Hi guys I wanted to share an install we are working on for one of our customers, truck is a 2016 Toyota Tacoma Prerunner double cab. Parts being installed are
    -Long Travel Kit DK-813908-B
    -Alignment Cam Gussets DK-813973
    -Upper Control Arm Double Shear Kit DK-813945
    -Spindle Gussets DK-811959
    -King Long Travel Spec Coilovers DK-811908-KSS-A
    -King Long Travel Spec Triple Bypass DK-811908-25KSB
    -Bypass Hoop Kit DK-811910
    We are also installing a set of ADV fiberglass front fenders and bumper caps, I will keep you guys updated as progress continues and post some finalized pics after the fenders are color matched. For more information you can visit our website at dirtkingfabrication.com or email ngardner@dirtkingfabrication.com
  2. May 21, 2021 at 3:00 AM
    MI-FLoffroader
    MI-FLoffroader Brett
    Brett
    Merritt Island, FL
    12' T4R LE/2003 SR5 SPORT V8/1988 DLX 22RE AUTO
    2012 T4R LE -Shoreline Blue Pearl 2003 T4R SR5 Sport V8 -Stratosphere Mica
    The timing of this is perfect. Going to be installing your full kit on my 03' 4Runner this summer when I get some time. Didn't realize the bump horns get completely removed to install the cans. Learning shit already. Thank You DK!
  3. May 25, 2021 at 1:00 PM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Yes we completely remove the factory bumps top surround for proper placement of the hydro bump, if you have any questions along the way don't hesitate to reach out to me and i can help you out ngardner@dirtkingfabrication.com or my direct line is 619-567-6240 and we appreciate the support!
  4. May 27, 2021 at 4:22 PM
    KaizenOffroad
    KaizenOffroad Member
    Huntington Beach, CA
    2018 White Tacoma TRD OR
    Solid kits. Always a pleasure to install DK kits.
    MI-FLoffroader likes this.
  5. May 28, 2021 at 7:13 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    We appreciate it, you guys always knock them out of the park!
    Heres some finished pics, I believe the customer will do our spring under kit down the road and most likely some 35s
  6. Mar 3, 2022 at 8:29 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Customer came back and we just completed the spring under install!
  7. Mar 4, 2022 at 2:04 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Any plans on running a ball joint or variation of one in your LT LCA's soon?
  8. Mar 10, 2022 at 10:35 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    We are definitely considering it and would love to hear your guys feedback on who would be wanting to run ball joints over uniballs
    vhinojosa4735 likes this.
  9. Mar 12, 2022 at 6:53 PM
    BlessdApparel1
    BlessdApparel1 Overland Warehouse Online
    Oceanside
    2013 Tacoma Build In Progress
    @pelfreybuilt Aluminum Front Bumper @Dirtking 2.5 Long Travel @bajadesignsofficial Fog Pocket Kit, S1’s, A Pillar Squadrons @bajadesignsofficial 20” S 8 @cbioffroadfab Bedrails @mountain_hatch Tailgate Attachment @dirtylyfewheels 17” Roadkill Race Beadlocks @falkentire Wildpeak A/T’s @yakimaracks RTT @nickdeyatnight Rocksliders And Custom Rear Swingout Bumper @shibui_tank On Board Air @calicowboywhiskey Whiskey @phalcon_trailers Dualzone Fridge @fabzonearmor Skids @Allpro Offroad Bed Stiffners And Gas Tank Skid @archivegarage Rear shock location @Iconvehicledynamics RXT Leafs Pack @4xinnovations hangars and shackle flip @Radflo Custom 2.0 resis with finned 2.5 Res and adjuster
    @Dirt King Fab I just installed this kit on my second gen, and it’s amazing. Super stoked to run this. The first few days the kit did amazing. Last weekend I did a trip up to big bear and now the front end (I beleive the bushings in the LCA) literally squeak and creak SO loud.
    do you guys have a fox for this? Originally when installed this wasn’t an issue. Now, it sounds Absolutely horrible especially for a brand new front end.
    Other than that, I’m beyond stoked! This kit handles insanely good.
    roguegs likes this.
  10. Mar 13, 2022 at 5:28 AM
    MI-FLoffroader
    Brett
    Merritt Island, FL
  11. Mar 13, 2022 at 2:17 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @BlessdApparel1
    Step 1: Check torque on all bolts.
    Step 2: Did you grease all the bushings / what grease did you use / how did you grease them? Improperly greased poly will squeak a ton especially if sand gets up in the mating surfaces.
  12. Mar 14, 2022 at 10:03 AM
    BlessdApparel1
    Oceanside
    Thank you both for the responses.
    They are torqued to spec. I had greased them prior to install and put a few 100 miles on them and they were silent.
    after a trip wheeling in the mud and snow, they are now loud as fuck.
    Im gonna stop by @Dirt King Fab and pick up some more grease and see if i can resolve my problem.
  13. Mar 17, 2022 at 7:44 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Hey Matt, while the poly and delrin bushings are a great performance option they can make some noise in less than ideal weather conditions (snow, mud, rain etc) the best option would be to come by and grab a tube of Prothane Super grease (we have in stock SKU 19-1751) and grease all the pivots. For optimal results we recommend to jack up the truck and loosen the control arm pivots, put 2-3 pumps of grease into each pivot and retorque each pivot bolt, then wipe off excess grease. A common mistake is overgreasing with either the wrong grease or doing it with the hardware still tight, this will cause the bushing to swell and become damaged. If you have any questions anyone in our sales team can assist you while you are here
  14. Mar 30, 2022 at 6:40 AM
    MI-FLoffroader
    Brett
    Merritt Island, FL
    @Dirt King Fab 03' 4Runner mock up- made a cardboard template that is the same diameter and length of the hydro can at full bump.
    So far this position looks centered on the pad, clears the bypass, keeps the UCA an inch off the inner fender well, and leaves about a 1/2" of shaft left on the shocks.
    Gotta get my diff installed and cycle the CV to make sure that clears. Learning as I go, so if anyone sees a problem lmk.
  15. Mar 30, 2022 at 7:20 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Looks good so far, you can bump it further than that as well to where the shock body is touching the rubber shaft bump, that will give you plenty of shaft left. Also I recommend cutting off the smaller rib at the base of the strut mount it will make it much easier to weld your bump stop mounts
  16. Mar 30, 2022 at 8:03 AM
    MI-FLoffroader
    Brett
    Merritt Island, FL
    I guess the red arrow is what your talking about? That probably would make it easier to get the gun in there.
    Thank You!!
  17. Mar 30, 2022 at 8:06 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
  18. Mar 30, 2022 at 9:36 AM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Also, make sure you check at full droop for bypass clearance. That's the critical clearance point.
  19. Mar 30, 2022 at 10:00 AM
    MI-FLoffroader
    Brett
    Merritt Island, FL
    Thank you! I had looked at it initially a couple days ago, but I made some changes to the template at full bump, and forgot about that part. SMDH
  20. Mar 30, 2022 at 12:46 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I agree! When we did bumps for my JD kit, I had more clearance issues at droop. The bypass starts to swing inboard when the lower armdroops out.
