Dirt King Fabrication Builder Parts
Discussion in 'Suspension' started by Dirt King Fab, Aug 16, 2022.
  1. Aug 16, 2022 at 9:33 AM
    Dirt King Fab
    Dirt King Fab [OP] Well-Known Member
    San Diego
    2013 Toyota Tacoma
    We are proud to announce our new product line of Builder Parts! Our Builder Parts line consists of fabrication parts, bushings, bearings, steering components, brake lines, misalignment spacers, limit straps, and shock accessories. All the products are the highest quality and competitively priced. Most of the products are in stock and include dimensional drawings to ensure the product will work for your application prior to purchase.
    FABRICATION PARTS
    The fabrication collection consists of products commonly used for our vehicle builds and production products. We wanted to release this product line so the average DIY fabricator has access to all the essential and hard to find fabrication components that we use on a daily basis. Nearly all the products in this collection are designed and manufactured in house.
    Fabrication Collection:
    • Fender Washers
    • Battery Tray
    • Tabs & Gussets
    • Weld Washers
    • Round & Hex Bungs
    • Ball joint & Uniball Cups
    • Bump Stop Cans
    • Reservoir Mounts
    • Snout Blocks
    BUSHINGS & BEARINGS
    The bushing & bearing collection is a great resource to rebuild your current suspension or to build custom suspension from scratch. The bushings and bearings in this collection are the same components used for Dirt King suspension systems.
    Bushing & Bearing Collection:
    • Poly & Delrin Bushings
    • Upper & Lower Ball Joints
    • Male & Female Rod Ends
    • Jam Nuts
    • Uniballs & Uniball Kits
    • Snap Rings
    STEERING PRODUCTS
    The steering collection contains steering components that are difficult to find anywhere else. Both Toyota & Ram engineers have purchased our steering components to develop new prototype suspension.
    Steering Collection:
    • Steering Clevis & Kits
    • Clevis Bolts
    • Tie Rod Extensions
    BRAKE LINES
    The brake lines collection has a large selection of vehicle specific and universal brake lines. A major benefit to purchasing brake lines from us is they’re in stock or have a short lead time. If purchasing from another supplier a lot of these brake lines would be a custom order with a long lead time.
    Brake Lines Collection:
    • DOT Approved Brake Lines
    • Brake Line Tabs
    • Brake Line Clips
    MISALIGNMENT SPACERS
    The misalignment spacers collection is entirely machined in house. Our spacers may look similar to other manufacture’s spacers but the difference is we use high grade 17-4 stainless steel and hold tight tolerances to ensure a perfect fit every time. Our spacers can be used for control arms, steering, shocks, links, panhard bars, or any other part that uses a rod end or uniball joint.
    Misalignment Spacers Collection:
    • High Misalignment Spacers
    • Half Moon Spacers
    • Step Spacers
    • Shoulder Spacers
    • Heim Spacers
    • Tapered Spacers
    • UCA & LCA Spacer Kits
    • Shock Spacers
    LIMIT STRAPS
    The limit straps collection consists of limit straps and everything needed to mount them. Our limit straps are quad wrapped with 1.75” wide nylon webbing. The tabs are zinc plated 4130 steel with deflector clips where the nylon meets the tabs to reduce abrasion and tearing. We offer sizes ranging from 8"-22"
    Limit Strap Collection:
    • Limit Straps
    • Limit Strap Clevis Mount
    • Limit Strap Mounting Kit
    SHOCKS & ACCESSORIES
    The shocks collection consists of Fox & King bump stops, Fox & King bump stop cans, shock spacers, shock tools, and Eibach springs.
    Shock Collection:
    • Fox & King Bump Stops
    • Fox & King Bump Stop Cans
    • Shock Spacers
    • Spanner Wrenches
    • Shock Oil
    • Eibach Springs
    For more information you can reach out to our sales team at 619-944-8913, sales@dirtkingfabrication.com or check out our website at www.dirtkingfabrication.com
  2. Aug 17, 2022 at 2:58 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    I used a bunch of yalls stuff for my +2 LT build! Great quality stuff!
    I used:
    uniballs
    mis spacers
    bushings
    coilovers
    [​IMG][​IMG][​IMG][​IMG]
    Connorvan likes this.
  3. Aug 18, 2022 at 3:19 PM
    Connorvan
    Connorvan Fasha
    Connor
    Reno, NV
    08 TRD OR DCSB
    315 75 16 Toyo MTs DIY Bed Rack Smittybuilt RTT Dirt King SUA Kit Custom Long Travel hangers and shackles Shackle flip King 16" Triple BP Shocks King 2.0 x 2.0 bumps Dirt King Frame box kit. Rebuilt rear cross member with 1.75" DOM Deaver H70HD leafs Polk Audio speakers F/R Handmade ported sub box for 10" sub Rockford Fosegate 1000W RMS amp TJM Front Bumper, custom DOM bull bar. Fabd Steel high clearance bumper Amber fogs Smitty Built 9500lb XRC winch King 2.5 with #700 coils Total Chaos Spindle Gussets 1.25" Spidertrax Spacers Icon Delta Joint UCA Thor cowl intake Fuck mud flaps and wheel liners. Switch pro mount and blue ray systems buss bar Dual audio double DIN head unit JD fab battery tray Alpharex Head/Tail lights Prinsu Roof racks Cab and Camper Don’t tread on me sticker for extra HP
    I too am super happy with the DK builder parts!! I might need that battery tray next. I currently have their
    - Weld in Alignment tabs in the front
    - DK spring under LT kit in the rear for 2005+ Tacoma
    Brian422 likes this.
