Dirt King LCAs, OEM Cam Bolts and ADD
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by Wishbone Runner, Oct 14, 2020.
  1. Oct 14, 2020 at 9:25 AM
    Wishbone Runner
    Wishbone Runner [OP] Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    *Located in Arvada, CO*
    Dirt King LCAs:
    $900 shipped, or make an offer!
    These are the first version they released, I welded on double shear limit strap tabs, well used but still plenty of life left in them. You will need bushings and the spindle adapter from Dirt King, these were on my 4Runner and the spindle has a different taper, contact them for pricing. Uniballs were replaced last year and are tight, the liner on one is starting to tear a bit. Full disclosure, I did have the uni come loose and put a few small spot welds inside the uniball cup to keep the balls nice and tight, this presents no problem, just want to be transparent.​
    OEM LCA Cam Bolts: $75 shipped
    Minimal miles on them, solid mounted the Dirt King LCAs shortly after. The small cam is spot welded for extra measure.
    ADD: $200 shipped
    Off my 2004 4Runner with ~220k miles on it but working flawlessly, pulled the motor apart a few years ago and soldered the motor contacts. Will part out motor or other bits.
    Island Cruiser likes this.
  2. Oct 16, 2020 at 3:22 PM
    Nalpak99
    Nalpak99 Booty Hunter
    Kyle
    2005 Toyota Tacoma pre-runner
    mid travel
    do you know if these LCA's ill work on a 2005 tacoma pre runner?
  3. Oct 16, 2020 at 4:44 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    A 6 lug, yes.
  4. Nov 2, 2020 at 8:27 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Cam bolts still available?
  5. Nov 2, 2020 at 8:31 AM
    Voltron4x4
    Denver, Colorado
    This and that...
    Just saw these came off a 4Runner. Needing them for my Tacoma though.
  6. Nov 4, 2020 at 8:43 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    PM sent, they fit 2nd gen tacos.
  7. Nov 13, 2020 at 2:24 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  8. Nov 17, 2020 at 1:21 PM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Buuuuump. Make an offer.
