Dirt King Long Travel Suspension Install
Discussion in 'Long Travel Suspension' started by Dirt King Fab, Jun 24, 2018.
  1. Jun 24, 2018 at 1:11 PM
    Dirt King Fab
    Dirt King Fab [OP] Well-Known Member
    San Diego
    2013 Toyota Tacoma
    Hey guys I wanted to share an install we did recently on one of our personal vehicles, a 2013 2WD Tacoma double cab. Its been awhile since we've posted on the forms so I made sure to take some photos during the installation process. Here are the products that we installed:
    The truck also has Fiberwerx front and rear flared fenders, 17" Method NV wheels, 35" Toyo AT2 tires, and custom Dirt King front bumper. We are still undecided on whether to do leaf springs or links on the rear suspension.
    The installation started by removing the old suspension and cutting off the factory bump stop to make room for the 2.5 triple bypasses.
    Next we prepped the frame for the double shear kit. We mocked up the tabs with the upper arm inner bushing sleeves and bushing washers just like how it will be during the final install. We also added two .030" shims, one for each tab to account for any warping during welding. These welding shims are included with our double shear kit so anyone else installing them would follow the same process. Then we tacked the tabs to the frame and loosened the upper arm bolt to make sure it moved through the tabs and frame freely. Once we knew they were fit properly we welded up the tabs and removed the upper arm bolt after cooling.
    The installation of the bypass shock hoops followed. The first thing was to do a rough cut to the wheel well so the hoop would fit in place. Then we mocked up of the shock hoop and suspension. This allowed us to do the final trimming to the wheel well for proper clearance for the shock hoop and reservoir hose. Then we let the suspension droop out so we could set the limit strap clevis mount. With the suspension at full droop we accounted for 1/2" of limit strap stretch. After everything was tacked in place we removed the suspension, did the final welding, clean up, and paint.
    With a majority of the work complete there was only a few things left before final install. The last things that needed paint were the spindles and wheel wells. While we waited for the paint to dry we cleaned up the calipers and replaced the brake pads. We also took the hub and traced the outside profile on the dust shield to cut it out. We didn't want the dust shield because rocks get caught in-between the shield and rotor causing noise. Its important to cut it and keep it as a spacer between the hub and spindle or the rotors wont be centered in the calipers. Once that was complete and the paint dried it was time for final assembly. If you want a complete break down of the installation process click here and view the instructions within the "Instructions" tab. Up until now most of the photos were taken quickly with a phone. After the final assembly we took better quality photos.
    P1222323.jpg P1222345.jpg P1222377.jpg P1222444.jpg P1222459.jpg P1222519.jpg P1222583.jpg P1222309.jpg P1222292.jpg P1222597.jpg tacoma lt kit.jpg P1222386.jpg
    Thanks for taking the time to read through the write up and I'll do my best to keep checking in and answer any questions you may have. If your interested in viewing our full product line up for your Toyota then click on one of the following links. 05-15 Tacoma Products | 16+ Tacoma Products | 03-09 4Runner Products | 10+ 4Runner Products | 07-09 FJ Cruiser Products | 10-14 FJ Cruiser Products | 07+ Tundra Products
  2. Jun 24, 2018 at 8:14 PM
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    Wow Killer truck! With all of that work on the front end I would say link the rear screw leafs lol... Keep us posted and keep up the great work! I have a set of your stock length LCAs on my 2012 Taco and need a set for my 2014 4Runner so I don't have to hear them binding and popping!
    Dirt King Fab[OP] likes this.
  3. Jun 25, 2018 at 11:32 AM
    tacoscar
    tacoscar Active Member
    oscar
    Fontana california
    2007 silver tacoma prerunner4x2
    *Dirt king 3.5 long travel *Front king 2.5x8 long travel coilover *Front King 2.5x8 bypasss long travel bypass *Rear 2.5 stock lenght reservoir king shock *advanced fiberglass fenders *315/70/16 fallen wildpeak m/t *double standard method race 16" wheels *rough country side sidesteps *digidiodes 50inch curved led bar (×1) *digidiodes 4×4 pod lights (x2) *Rigid industries dually d2 pods (x2) *hidretrofit headlights *spyder led taillights w 3rd led brake light *pioneer nex 7201 double din *power acoustik 4000bmaf bass amplifier *power acoustik 12 inch subwoofer *jl audio 500/1 high amplifier *rockford forsgate speakers all around
    Sickass suspension cant wait to have mine finished !
    Foginator and Dirt King Fab[OP] like this.
  4. Jun 25, 2018 at 4:00 PM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Thanks guys, we just dropped it off today at Fiberwerx for them to design some new bedsides off of it. I'll post some update photos as it comes together.
  5. Jun 28, 2018 at 8:04 AM
    BPaulin_
    BPaulin_ Well-Known Member
    Bruno
    Orange County, CA
    2010 Tacoma TRD Off Road
    Baja Kits +2 LT Kit
    looks great!
  6. Jun 28, 2018 at 8:41 PM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Well the guys at Fiberwerx are kicking some ass! Check out the progress pictures we got today from Jason. This is day two in the shop and it’s starting to take shape. Once complete these bedsides will be a production product available to the public.
    BBDB3ACF-1941-4606-A8EE-995BE8BE6CEB.jpg 9B15A529-9B95-42D7-B062-C11668FBF486.jpg
  7. Jun 29, 2018 at 4:15 AM
    Hawk373
    Hawk373 Well-Known Member
    2012 TRD Sport DCLB
    DMZ, ADS, King, JFR, SOS, ECGS, LSK
    Nice, are these 6” as well?
  8. Jun 29, 2018 at 8:01 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Yes they are.
    Hawk373 likes this.
  9. Jun 29, 2018 at 8:05 AM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
  10. Nov 10, 2019 at 9:16 PM
    justinlovetice
    justinlovetice Well-Known Member
    Justin
    Kaneohe, HI
    2019 TRD Off-Road
    Did you weld the back side of the double shear gussets or is there no need to @Dirt King Fab?
  11. Nov 11, 2019 at 10:52 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you can get to it, it won’t hurt but 99% just weld the front and sides.
    justinlovetice likes this.
  12. Nov 11, 2019 at 11:26 AM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    @justinlovetice welding the front and the sides is more than enough to withstand the force it sees. It doesn't hurt to weld the back side but the engine would need to be removed to get in there.
  13. Nov 11, 2019 at 11:52 AM
    13txtaco
    13txtaco Well-Known Member
    Katy Texas
    2013 Tacoma 4x4
    What front bumper you running??
  14. Nov 11, 2019 at 12:40 PM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    It's a custom bumper that we built.
  15. Nov 11, 2019 at 12:45 PM
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    You can also bevel the plate to get 100% pen weld on the double sheer brackets. That's what I did on mine.
    justinlovetice and Dalandser like this.
  16. Nov 11, 2019 at 10:28 PM
    Armament
    Armament Well-Known Member
    Nick
    Albuquerque, NM
    2012 Tacoma Double can 4wd
    Full Camburg LT front suspension, King coil overs, Rough Country spindles, King 2.5 reservoir rear shocks, OME Dakar spring packs, T100 E-locked rear axle, 35x12.5x17 tires, Fiberworx fenders and bedsides.
    Any pump stop area?
  17. Nov 11, 2019 at 10:30 PM
    CaptainTikihut
    CaptainTikihut Well-Known Member
    NorCal
    2017 Taco Supreme w Stuff
    That's fucking TITS!
  18. Nov 11, 2019 at 10:34 PM
    dc2’s
    dc2’s Well-Known Member
    California
    2017 Toyota Tacoma trd 4x4 off road
    Added a driver
  19. Jan 31, 2020 at 1:54 PM
    Mb471
    Mb471 Well-Known Member
    Bay Area, ca
    17 DCLB
    any chance you guys (dirtking) will ever make a production run on that bumper for second or third gen trucks?
  20. Jan 31, 2020 at 2:04 PM
    Dirt King Fab
    San Diego
    2013 Toyota Tacoma
    Sorry this type of bumper is custom built only because it requires to much modifications to the vehicle for an average person to install.
