Dirt King stock width LCAs now available
Discussion in 'Suspension' started by Dirt King Fab, Oct 2, 2013.
  1. Oct 2, 2013 at 8:53 AM
    Dirt King Fab
    Dirt King Fab [OP] Active Member
    Nick
    San Diego
    2013 Toyota Tacoma
    Dirt King 2005+ Toyota Tacoma Stock Width Lower Control Arms are now available. Our Stock Replacement Lower Control Arms are an excellent upgrade for those looking for a stronger more functional LCA without increasing the track width. These will work on both 2wd and 4wd vehicles. We use custom machined bolts and uniball cups for axle clearance and additional wheel travel. We also replaced the weak factory ball joints with 1" stainless steel uniballs for strength and more articulation. With these arms you have the option of running hydraulic bump stops. Unlike other companies we use Delrin bushing in our lower arms instead of soft urethane bushings which bind and flex when braking. These arms are considerably stronger than stock to withstand the abuse seen in off-roading. Our Stock Replacement LCA's are a direct bolt on part and does not increase track width. These are fully CAD designed, cnc laser cut and bent to ensure a quality fit. Our arms come fully assembled to save time and easy installation.
    You can find more information and are available to order on our website here http://shop.dirtkingfabrication.com/Stock-Replacement-Lower-Control-Arms-TTF4-S103.htm
    Mademan925 likes this.
  2. Oct 3, 2013 at 11:33 AM
    SoCaltaco65
    SoCaltaco65 Well-Known Member
    2011 DCSB 4x4 Offroad TRD
    Harbor Freight 110v welder garage fab parts.
    Nice!
    Nick, any plans for a secondary bypass fitment?
    Good luck with these.
  3. Oct 3, 2013 at 2:36 PM
    Dirt King Fab
    Nick
    San Diego
    2013 Toyota Tacoma
    We can have it set up for a bypass shock as well. We choose not to add it since being at stock width the arm is just too short and it will cause you to lose quite a bit of turning radius since the tire will contact the bypass shock. Also figured most people would want to go to an extended kit if they were looking to run a secondary shock so more travel would be obtainable. We will have all of our 3.5" kits (and possibly 2" kits if we end up designing and building them) set up to run a bypass as it will not affect turning radius.
  4. Oct 3, 2013 at 2:43 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Black Death
    6 inch PC Douche Bag lift...what else do I need?
    :eek::eek: Must have!... but need more $$.
  5. Oct 3, 2013 at 2:43 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Love the uniball in arm design. I assume you retain the factory ball joint bracket between the factory arms and the spindle?
  6. Oct 3, 2013 at 2:44 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DBCB SB 4x4
    Yes
    Hope to do business with you soon. I have National in El Cajon building a new leaf pack right now and as soon as I get the rear upgrade done you guys are next on my list for uppers and lowers, very stoked that I can get these from SD locals !
  7. Oct 3, 2013 at 4:47 PM
    Dirt King Fab
    Nick
    San Diego
    2013 Toyota Tacoma
    Yes we use the factory ball joint bracket. With this design we are able to achieve much more ground clearance rather than having the uniball in the block. We will have our long travel kit the same way.
    National does good work. We look forward to hearing from you. If you have any questions about anything feel free to shoot me a PM or email.
  8. Oct 3, 2013 at 4:56 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Those look nice!
  9. Oct 3, 2013 at 5:05 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    :thumbsup:
    These are about $300 less than the TC arms. Very good!
  10. Jan 7, 2015 at 7:14 AM
    Pcyc
    Pcyc Well-Known Member
    Fritz
    San Francisco, CA
    09 doublecab sr5 TRD offroad
    See Build Page
    Made my order! I am excited to Run these and the TC CAM and Spindle gussets.
  11. Jan 8, 2015 at 4:33 PM
    Dirt King Fab
    Nick
    San Diego
    2013 Toyota Tacoma
    Some updated pictures of our Tacoma Performance lower arms installed on customer's vehicles
  12. Jan 8, 2015 at 4:52 PM
    HectoRome
    HectoRome Grizzled Contracting NCO
    07 PreRunner SR5 TRD Off-Road Debadged, Icon Stuffs, MaxTrac Spindles, Dirt King LCAs
    These look incredible ! ! !
  13. Feb 1, 2015 at 2:36 AM
    12TRDTacoma
    12TRDTacoma Mid Traveling
    Roberto
    Concord, CA
    12 TRD Sport DCLB 4x4 Tacoma
    Supercharged
    Bump for an awesome manufacturer of such a kick ass product. I cannot speak more highly about such a stand up set of guys making such fine pieces for our trucks. I am still thrilled with my uppers and lowers and I am looking forward to my next wheeling session with these. (After I work out the small kinks out of things that need some attention not suspension related.) I see you guys used one of my installed pics on here. Nice. :D
    Thanks again Dirt King :thumbsup:
  14. Feb 1, 2015 at 3:01 PM
    OICU812
    OICU812 Well-Known Member
    The uniballs do they require regular lubrication or is this basically a maintenance free operation?
    Also how much more NVH could one expect going to these from stock lca?
    Many thx
  15. Feb 1, 2015 at 11:10 PM
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    The uniball still does require regular maintenance as one should expect with any other aftermarket uniball control arm setup. The NVH factor is hardly noticeable. It does provide a more direct feeling, but nothing that I have never not liked. Everyone is different however so your results may vary. I hope that helps.
  16. Feb 2, 2015 at 5:29 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
  17. Feb 2, 2015 at 8:03 PM
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    The install is fairly straightforward. You will love them :thumbsup:
  18. Feb 3, 2015 at 7:21 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Already have the truck ripped apart, just awaiting arrival! Question for those using these in the rocks, are they going to take a beating without a care, or would a skid be beneficial. I know TC makes skids for theirs, but it seems that most with aftermarket LCAs don't use them.
  19. Feb 3, 2015 at 7:24 AM
    Large
    Large Red
    I've wheeled the piss out of OEM LCAs without skids on them .. they have taken quite a beating. I don't really understand the need for LCA skids in the first place. I've only seen scratches, never a bent or broken LCA.
  20. Feb 3, 2015 at 7:25 AM
    12TRDTacoma
    Roberto
    Concord, CA
    Supercharged
    Very nice! :thumbsup: skids will not be necessary as most rock crawlers purchase these with the intention of being able to bump them into rocks without worrying about them bending like stockers would. The only thing that you will damage on them is that beautiful powder coating paint job. :D
