dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Jun 3, 2017 at 7:48 PM
    #2941
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    long drive but I've heard good things about RRG. :spy:
  2. Jun 3, 2017 at 8:10 PM
    #2942
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Doooooo iiiiiiiittttt!!!!!
    MarX and dirty deeds[OP] like this.
  3. Jun 3, 2017 at 8:15 PM
    #2943
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    @11TRDTX
  4. Jun 3, 2017 at 8:22 PM
    #2944
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Can't need to save vacation time. Wife wants to go to Gatlinburg for our anniversary (in September). Secretly planning at the least a meet up with the dudes in the area :spy:
  5. Jun 4, 2017 at 5:59 AM
    #2945
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I see the problem.
    Buy REAL beer. Diet beer does not count unless you're a woman.
  6. Jun 4, 2017 at 7:23 AM
    #2946
    JayMac
    JayMac I'm not bad... I'm just drawn that way.
    Jessica
    Oregon
    2007 DCLBFTMFW
    STILL doesn't count if you're a woman!!
  7. Jun 4, 2017 at 8:26 AM
    #2947
    Bluegrass Taco
    Bill
    Mt Washington Ky
  8. Jun 5, 2017 at 5:33 AM
    #2948
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    You should come. We can trade more bang bangs for truck parts!
    ChadsPride likes this.
  9. Jun 5, 2017 at 5:33 AM
    #2949
    ChadsPride
    Sponsored by TacomaWorld.com
    Sup DD, you get that puppy on?
    dirty deeds[OP] likes this.
  10. Jun 5, 2017 at 5:58 AM
    #2950
    dirty deeds
    Nick
    Eastern KY
    Hey mang! Good time in Cabo, or wherever you went?
    No. I'm gonna wait a few days and let it set up more. I could still put a mark in the coating with my fingernail late last night.
    If it never firms up, looks like it'll get stripped again and then I'll just rattle can it and be done. Or bite the bullet and pay for someone to coat it.
    JayMac and ChadsPride[QUOTED] like this.
  11. Jun 5, 2017 at 5:59 AM
    #2951
    ChadsPride
    Oh yeah, Cabo was amazing to say the least.
    Right on brother, just checking to make sure I didn't miss the reveal.
    JayMac and dirty deeds[OP] like this.
  12. Jun 5, 2017 at 6:02 AM
    #2952
    dirty deeds
    Nick
    Eastern KY
    Notch yet
    ChadsPride[QUOTED] likes this.
  13. Jun 5, 2017 at 6:02 AM
    #2953
    ChadsPride
    Roger
  14. Jun 5, 2017 at 6:03 AM
    #2954
    dirty deeds
    Nick
    Eastern KY
    Says to wait 72 hours before putting anything in the bed of the truck (if this were used on a truck bed), so to me that means I'm gonna wait 72 hours at least to mount it.
  15. Jun 5, 2017 at 6:04 AM
    #2955
    ChadsPride
    Shit, I've waited months and havnt even done a damn thing with mine.
    You are ahead of the curve IMO
  16. Jun 5, 2017 at 6:12 AM
    #2956
    dirty deeds
    Nick
    Eastern KY
    Don't use a grinding disc to prep the steel unless you want it textured. It's difficult to keep it from gouging it, however, the bed liner did fill a lot of the marring. I also went back over the whole thing with a flap disc and that fancy 3M wheel https://www.amazon.com/3M-9099DCNA-Large-Paint-Stripper/dp/B00004Z4DV and mostly got it back to smooth.
  17. Jun 5, 2017 at 6:13 AM
    #2957
    dirty deeds
    Nick
    Eastern KY
    Do the prep work yourself if you can. Save you a dollar, take pride in knowing you did it yourself! And your turn around time at the powder coater (if you do that) will be much faster too!
  18. Jun 5, 2017 at 11:33 AM
    #2958
    dirty deeds
    Nick
    Eastern KY
    I had REAL beer too. I would've been more worthless that day if I drank many of those. The Lite was more for thirst quenching haha!
    BTW, need to pick your brain about my CB antenna.
    I don't think it's grounded properly. Reception sounds like crap, similar to when my magnetic antenna would fall of the roof, I can hear people talking, but it just doesn't sound right.
    Currently, installed in this order: antenna, spring, quick connect, top half firestik stud (lock washer, ceramic washer), mount bracket (painted mind you), lower half of firestick stud, firestik coax, radio. Radio is grounded through the self built connector to the 12v accessory outlet. It's fused.
    What am I missing? If I need to install a ground strap or cable, where in that mess would it go? Should I eliminate something in the setup?
  19. Jun 5, 2017 at 11:42 AM
    #2959
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Ground your antenna mount. Also, make sure there is no paint/powder coat where the bottom (ground side) half of the stud contacts the mount.
  20. Jun 5, 2017 at 11:44 AM
    #2960
    dirty deeds
    Nick
    Eastern KY
    Easy enough!
    Grounding the mount bracket is easier (to me) than grounding the antenna assembly. Didn't want any more exposed cables than what little bit shows of the coax.
    Now to find a proper path to run a ground wire!
    MarX and ChadsPride like this.
