dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Dec 14, 2017 at 10:31 AM
    #5241
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Get gears first. Your truck and wallet will thank you.
  2. Dec 14, 2017 at 10:43 AM
    #5242
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I still want a locker too. Will go ECGS core swap for that.
    Highly doubt my tax return will cover new gears AND locker since I'd have to get a geared front diff along with the locked and regeared rear diff.
    So much money!
  3. Dec 14, 2017 at 10:47 AM
    #5243
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    Regearing alone is gonna be like $2k unless you get it done at DYF.
    It's really the reason I haven't regeared yet and thats waaaaaay down the list. When I get dirtyfives I'll pony up tho
  4. Dec 14, 2017 at 10:50 AM
    #5244
    dirty deeds
    Nick
    Eastern KY
    Everett already told me that he doesn't and won't set gears. Not something he would even do to his own truck.
    And I don't trust a single redneck hillbilly in a 200 mile radius to do it on mine either!
    How ECGS works; buy the regeared front and rear with core charges added to them. Install them and then return the stock ones, then the core charge is credited back to you. It will cost more, but it's piece of mine. :)
    11TRDTX and ChadsPride like this.
  5. Dec 14, 2017 at 11:08 AM
    #5245
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    I did my own gears. Not interested in doing any more. Will pay to have the front locker installed. Job sux.
    dirty deeds[OP] and ChadsPride like this.
  6. Dec 14, 2017 at 11:36 AM
    #5246
    dirty deeds
    Nick
    Eastern KY
    Install of the housings isn't what I'm afraid of. They're just heavy.
    I'm concerned with proper timing and backlash and all that junk.
  7. Dec 14, 2017 at 12:15 PM
    #5247
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    i refuse to fuck with gears. Will get from ecgs when i go that route
  8. Dec 14, 2017 at 12:21 PM
    #5248
    dirty deeds
    Nick
    Eastern KY
    Zachkly
    ChadsPride likes this.
  9. Dec 14, 2017 at 1:17 PM
    #5249
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Exactly what I'm talking about. I've set up hundreds of ring & pinions.
  10. Dec 14, 2017 at 1:20 PM
    #5250
    Bluegrass Taco
    Bill
    Mt Washington Ky
    You wear dresses.
  11. Dec 14, 2017 at 1:27 PM
    #5251
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    It's called a bloody kilt you fockin idiet
  12. Dec 15, 2017 at 10:59 AM
    #5252
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    buy the turbo mani then buy this
    https://www.ebay.com/itm/T25-T2-to-...ash=item2cc58a2b88:g:PPwAAOSwf-xZpmaF&vxp=mtr
    then this
    https://www.summitracing.com/parts/tnt-11017/overview/
    and this
    https://www.ebay.com/itm/New-Univer...ash=item43f060ef32:g:-2cAAOSw9fRZ3Gaj&vxp=mtr
    then this
    https://www.ebay.com/itm/Racing-Spo...ash=item3d1dbf21b9:g:bAoAAOSwUKxYdLuO&vxp=mtr and you can either get a universal oil feed/return line kit for $50 or so or pick one up local that is made to fit your set up for about the same I'm sure and you wont have a crap load of left over parts
    then this
    https://www.ebay.com/itm/OBX-Racing-Sport-Red-38mm-Wastegate-WG38-35MM-Ultra-Gate-7-11-14-Psi-Spring/151376059948?_trkparms=aid=555017&algo=PL.CASSINI&ao=1&asc=41376&meid=311a42fd9f0949a4a65318dc936b594e&pid=100754&rk=1&rkt=1&&_trksid=p2045573.c100754.m4842
    then this
    https://www.ebay.com/itm/Universal-...ash=item51e3a2a2c4:g:~ykAAOSwfCZZ29ug&vxp=mtr
    save $100 or so for some 2"-2.5" silicone reducers and 2.5"-3" reducers and some 3" piping to get you to your throttle body and that should put all of your hardware in your hands for ~$1500 (you will also need a MAF sensor adaptor or to make one/have one made into some of that 3" stuff. then ask some of the 2tr turbo guys what they are doing for fuel upgrades. Urd has pump kits for $160 ish and injectors with plug and play harness are like $70 a pop so that will bring you up to ~$1900 if you go that route and you may have to modify the down pipe that comes with that mani since it is made for a t28 turbo and you prolly wanna run a t3; if you can get someone else to go in on the mapecu3 from urd, u can get it for $500 and that will get you a great start on everything for ~$2500 or so (put a couple hundy back cuz something isn't gonna work just like you thought it would)
    there is a couple of 1st gen 4 bangers who have discovered that the stock ecu will correct 440cc injectors on its own with no tuning (stockers are 295cc I think, well I no they are for me and I feel that is pretty standard across the board) no one has tested this on 2nd gen anything tho so it may or may not work but if it did that could save you some wiring and money
    you might can make your current exhaust work too with some fabracative magic (a welder and cutter of some sort)
  13. Dec 15, 2017 at 12:08 PM
    #5253
    dirty deeds
    Nick
    Eastern KY
    whoa!
  14. Dec 15, 2017 at 12:10 PM
    #5254
    yota243
    E.J.
    north Alabama
    :burnrubber:
  15. Dec 15, 2017 at 12:25 PM
    #5255
    dirty deeds
    Nick
    Eastern KY
    :bowdown:
  16. Dec 15, 2017 at 12:31 PM
    #5256
    dirty deeds
    Nick
    Eastern KY
    Is there a way to bolt on the hardware for turbo, intercooler, mani, etc. without the ecu and new injectors?
    I guess what I'm really wanting is the most simple install possible and only adding intercooler, piping, and turbo. Obviously with a little exhaust tweak.
  17. Dec 15, 2017 at 12:44 PM
    #5257
    dirty deeds
    Nick
    Eastern KY
    :laughing:
    A gas powered leaf blower would be better than that!
  18. Dec 15, 2017 at 1:02 PM
    #5258
    yota243
    E.J.
    north Alabama
    yes you can do all the hardware before the fuel upgrade, just make sure not to get into boost while it is in that condition. I drove around for a month before I hooked up my piggyback that way, and another month or more on stock fuel injectors with the piggy back hooked up. there are several live "save points" that you can work hard to get to and then have your truck back to working for a while before you go any further. it would be most ideal if you had access to a secondary DD tho, because there are also gonna be things that may take more than a weekend to knock out (maybe not as bad as mine since there is a turbo mani available to you, and my exhaust was all custom pieced together by me and a couple other guys)
  19. Dec 15, 2017 at 1:15 PM
    #5259
    dirty deeds
    Nick
    Eastern KY
    So what you just told me was there isn't a way to just run the turbo without new injectors and ecu.
  20. Dec 15, 2017 at 1:16 PM
    #5260
    yota243
    E.J.
    north Alabama
    I'm telling you that you can run it up to 0psi safely, anything past that is not recommended at best I would wager
