dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Jan 15, 2018 at 10:52 AM
    #5521
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    There was at least 3" on the ground this morning. A lot will melt off today, get rained on this evening, freeze, then more snow again on it.
    ChadsPride likes this.
  2. Jan 15, 2018 at 10:58 AM
    #5522
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Memphis + "snow" (aka ice) = :burnrubber::bikewheelie::bananadead::help:
  3. Jan 15, 2018 at 11:04 AM
    #5523
    dirty deeds
    Nick
    Eastern KY
    It took me 50 minutes to get to work today. Normal commute is 30, tops. :frusty:
  4. Jan 17, 2018 at 5:46 AM
    #5524
    dirty deeds
    Nick
    Eastern KY
    Doing this again.
    Serious. Give me some options on the lockers and bumpers. Keep the bumper under $1500 if possible.
  5. Jan 17, 2018 at 5:47 AM
    #5525
    ChadsPride
    Sponsored by TacomaWorld.com
    Not sure about the lockers but at the risk of being called a fanboy....
    Seriously take a look into Brute Force Fab as far as the bumper is concerned.
    The quality of his builds are unreal. And at an excellent price point​
  6. Jan 17, 2018 at 5:48 AM
    #5526
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    :eek:
    Just how young are you?
  7. Jan 17, 2018 at 5:50 AM
    #5527
    ChadsPride
    :anonymous:
  8. Jan 17, 2018 at 5:52 AM
    #5528
    dirty deeds
    Nick
    Eastern KY
    Snow driving update...
    Used 4hi partially on the way home yesterday, not above 40mph. No odd sounds or issues.
    This morning, I have to use it again from the house to the bridge into Ohio. Before I even engage 4hi to back out the driveway, I try it in 2hi. I hear something very odd "under my feet". A popping/grinding/scraping sound. Wheel is straight. I spin the tires obviously because snow and slight incline of the driveway. Go to 4hi.
    Works great. Still have that odd sound though. After disengagement, still there too. Seems that it goes away at higher than 35mph, not sure really. No real rhyme or reason when the wheel is turned or not that the sound happens.
    Took a quick peek under there when I got into the lot here at work and didn't see anything that looked too out of place. I'll go out for my 9:30 not-gon-choke-a-bitch-smoke-break and take a longer peek.
    beertimecontinuum and ChadsPride like this.
  9. Jan 17, 2018 at 5:52 AM
    #5529
    dirty deeds
    Nick
    Eastern KY
    Maybe.
    ChadsPride[QUOTED] likes this.
  10. Jan 17, 2018 at 5:53 AM
    #5530
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  11. Jan 17, 2018 at 5:54 AM
    #5531
    ChadsPride
    Just a thought! :thumbsup:
  12. Jan 17, 2018 at 5:55 AM
    #5532
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Unless you're planning on becoming a human battering ram, just about all the bumpers provide FAR more damage protection than a stock bumper. Aluminum or hybrid bumpers either one will save a LOT of weight that just doesn't need to be there. The secret to plate bumpers is their ability to increase clearance more so than any other purpose. Think in these terms....Save a couple hundred lbs off the front end and make your suspension work. Add weight and you'll be back to swapping springs, etc, I've heard all the anecdotal comments about how strong steel is, etc,....I can also furnish you with hundreds of references with aluminum that have't bent anything.
    Like my Pelfreybilt!
  13. Jan 17, 2018 at 5:56 AM
    #5533
    dirty deeds
    Nick
    Eastern KY
    It all hinges on my return's amount. If it's enough, I get a bumper and winch, or just a bumper. The rest will be invested/saved.
    If it's smaller than I'd like, par for the course, I'll make a fatter than normal payment on both my truck and house for the month.
  14. Jan 17, 2018 at 5:57 AM
    #5534
    Bluegrass Taco
    Bill
    Mt Washington Ky
    And....Lockers are the best money you can spend on a 4wd if you actually plan on off roading the truck.
  15. Jan 17, 2018 at 5:58 AM
    #5535
    dirty deeds
    Nick
    Eastern KY
    I checked out a couple vendors yesterday. Avg difference from steel to aluminum is in the 30-50lb range. Better weight saving ratio in a synthetic cable over steel for the winch.
  16. Jan 17, 2018 at 5:58 AM
    #5536
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Spinner Knob to some. I go back far enough it was called a "Necker Knob".
  17. Jan 17, 2018 at 6:00 AM
    #5537
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Do BOTH. I did. Saved 60+lbs on bumper, 42 lbs on cable/syn. I lost less than 1/2" of front lift with that AND skids/sliders.
  18. Jan 17, 2018 at 6:02 AM
    #5538
    dirty deeds
    Nick
    Eastern KY
    If the return is enough and there's a good enough sale at tax time, I may.
    The aluminum bumper is the nut cracker. If I ever crack it or need to trim it for bigger tars, where the hell am I going to find somewhere to weld aluminum?! We definitely don't do that here at work, any more.
  19. Jan 17, 2018 at 6:04 AM
    #5539
    ChadsPride
  20. Jan 17, 2018 at 6:05 AM
    #5540
    dirty deeds
    Nick
    Eastern KY
    11TRDTX and ChadsPride[QUOTED] like this.
