dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Apr 16, 2018 at 10:13 AM
    #6501
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  2. Apr 16, 2018 at 10:35 AM
    #6502
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    :thumbsup:
    Rather crawl than mud. But at a high rate of speed :D
    Realize how much I dislike mud after this weekend and the 60k service. There was LBL crusted slurry, stick, leaves, and gravel all up under every which way on the truck. Shit falling in my ears, mouth, nose, and eyes.
    I've washed or rinsed the truck at least 3 times with a pressure washer since the trip there. Not counting the rain that's helped some.
    Justinogo[QUOTED] and tacofort like this.
  3. Apr 16, 2018 at 10:40 AM
    #6503
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Fuck mud. And you got those sliders and skids for a reason right? Get those tarz and your truck will be way too capable for boring old fire roads and mud holes. I expect to see you having some fun on the big boy rocks soon :rolleyes:
  4. Apr 16, 2018 at 10:48 AM
    #6504
    dirty deeds
    Nick
    Eastern KY
    This weekend :anonymous: maybe. If we find rocks.
    I need a locker and tars stat!
  5. Apr 16, 2018 at 11:47 AM
    #6505
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Come to Windrock next month :D
    You getting a lock right?
  6. Apr 16, 2018 at 11:51 AM
    #6506
    dirty deeds
    Nick
    Eastern KY
    Possible I may come there.
    Not sure what kind of locker tbh. Nothing too expensive, that I do know. Won't pay for an air locker and it'd be a lot like work to swap the axle to an e-locker. Let alone finding the axle itself in my area. Don't care if I bark tires in the mall parking lot, at least the Heeps will know I'm #trailrated
    I contacted ECGS quite a while ago about it to get myself a game plan, they never replied.
    tacofort likes this.
  7. Apr 16, 2018 at 12:25 PM
    #6507
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    I love my lock right in the rear. I know Gideon and Levi like the no slips they have. Stay under probably 2000-2500rpm and it just ratchets so you won't scrub your tires. Lock right is a bit more aggressive offroad but makes more noise, no slip is more road friendly but not as aggressive on the lock up offroad. Gideon says his no slip doesn't lock in reverse either.
    I think the no slips generally run for about $100 more than the lock right, but I got my lock right for just $190 on Amazon.
    Really easy install. Wouldn't bother getting ECGS to do it unless you want to regear at the same time
  8. Apr 16, 2018 at 12:30 PM
    #6508
    dirty deeds
    Nick
    Eastern KY
    That's good info! Thanks for sharing! I'm clueless on them, so I'm learning much as I can.
    Know what rear end you have? On the ECGS site, mine is the 8.4" Non-ELO T100/Tacoma I think.
    I contacted ECGS just for help figuring out what rear I had and what locker to get. You're right, I won't be doing core swaps until regear.
  9. Apr 16, 2018 at 12:33 PM
    #6509
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    I have the 8.4, so does Carter (no-slip), Gideon (no-slip), and I'm fairly sure Levi's is the 8.4 as well. Yours should be the 8.4 because it is non Elocker.
    The powertrax lockers just slide into the carrier and replace the spider gears. You reuse the stock shims, all you have to do is slide the springs into the locker once it's in. Hardest part is holding down the housing while you retorque the ring gear (I stuck it in a vice and got a torque wrench on it. Think it was like 80ft-lbs)
    Just make sure you are using limited slip gear oil in the diff afterwards
  10. Apr 16, 2018 at 12:49 PM
    #6510
    dirty deeds
    Nick
    Eastern KY
    I don't see the no-slip on the ecgs site, only the lock right
  11. Apr 16, 2018 at 12:53 PM
    #6511
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
  12. Apr 16, 2018 at 12:57 PM
    #6512
    dirty deeds
    Nick
    Eastern KY
  13. Apr 16, 2018 at 1:13 PM
    #6513
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Short version is;
    No-slip makes basically no noise and won't chirp tires as often but costs more and won't be as consistent offroad.
    Lock Right clicks quietly when you turn and will "unload" occasionally which makes a pop sound (only had it happen to me a few times and I was pulling a trailer), but locks up more aggressively offroad and costs less
  14. Apr 16, 2018 at 1:24 PM
    #6514
    dirty deeds
    Nick
    Eastern KY
    Lock Right it is then
  15. Apr 16, 2018 at 1:26 PM
    #6515
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
  16. Apr 16, 2018 at 1:27 PM
    #6516
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    :fistbump:
  17. Apr 16, 2018 at 7:21 PM
    #6517
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    No slip here
    Justinogo and ChadsPride like this.
  18. Apr 17, 2018 at 2:45 AM
    #6518
    beertimecontinuum
    Everett
    Nudes inbound!!
    dirty deeds[OP] likes this.
  19. Apr 23, 2018 at 10:34 AM
    #6519
    dirty deeds
    Nick
    Eastern KY
  20. Apr 23, 2018 at 10:42 AM
    #6520
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    :spy:
    It's been a while.
    Shenanigans
    dirty deeds[OP] and ChadsPride like this.
