dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Jun 27, 2018 at 5:45 AM
    #6781
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Back on the bb tars. Man, that was just sooooo hard :rolleyes: changing wheels...didn't even use my air tools til I get the garage feeder ran in again.
    Anywho. How the hell can an alignment be affected SO MUCH by these different tires? I'm nearly straight and true with the Grabbers, but the KM2s kick the wheel to the right and would push the truck left if I let go of the wheel. Sure, the KM2s aren't exactly balanced well, but it did it at all speeds. 5mph or 55mph.
    ChadsPride likes this.
  2. Jun 27, 2018 at 5:46 AM
    #6782
    ChadsPride
    Sponsored by TacomaWorld.com
    Might just be a bad tire
    dirty deeds[OP] likes this.
  3. Jun 27, 2018 at 5:47 AM
    #6783
    dirty deeds
    Nick
    Eastern KY
    Always possible, yes. Josh chunked em a bit, and I certainly didn't baby them this past trip to RRG. I let those KM2s eat and eat they did! :fistbump: :mudding:
    ChadsPride[QUOTED] likes this.
  4. Jun 27, 2018 at 5:54 AM
    #6784
    ChadsPride
    :woot:
    What's next up on this beast?
  5. Jun 27, 2018 at 5:57 AM
    #6785
    dirty deeds
    Nick
    Eastern KY
    Clutch. At minimum.
    More important and functional than a front bumper. Bumper won't do shit without anything pushing it.
  6. Jun 27, 2018 at 5:59 AM
    #6786
    ChadsPride
    Word up!!!
  7. Jun 27, 2018 at 6:03 AM
    #6787
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Tires don't affect alignment. They may affect how your truck tracks and follows the crown/ruts in a road but your alignment is the same regardless of tires.
    Bluegrass Taco and ChadsPride like this.
  8. Jun 27, 2018 at 6:18 AM
    #6788
    dirty deeds
    Nick
    Eastern KY
    Yes, and no.
    That doesn't explain why all 5 wheels, drive and steering are straight with the Grabbers, but the steering wheel is cocked right ~15° driving straight and letting go of the wheel steers left immediately on the KM2s. At any speed, slow or above 65mph. The Grabbers behave as they should across the board.
  9. Jun 27, 2018 at 6:23 AM
    #6789
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Does it matter which km2 is where? Rotate front to back, still happen? What air pressure in km2s?
    dirty deeds[OP] and ChadsPride like this.
  10. Jun 27, 2018 at 6:29 AM
    #6790
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    No period. Alignment is a static series of measurements taken from the hub. What tires are on that hub/wheel make no difference in the alignment numbers.
    Sounds like you may have a bad tire if it's behaving that oddly.
  11. Jun 27, 2018 at 6:53 AM
    #6791
    dirty deeds
    Nick
    Eastern KY
    I've not gotten that deep into this yet. I aired up to 38 or 39 psi when we left and it rode a lot better, less shake in the 40-65 mph range than before.
    This makes more sense. Guy here at work said the taller tire may have changed the camber, but without touching any components, not possible.
    An out of balance tire is more so the culprit I think. They'll get balanced when I have them put on the steel wheels.
  12. Jun 27, 2018 at 9:04 AM
    #6792
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Just live with it :notsure:
    That's what I do.
  13. Jun 27, 2018 at 9:44 AM
    #6793
    dirty deeds
    Nick
    Eastern KY
    Also yes. As little as the KM2s will actually be on the truck, I'm not sweating it. More of an inquiring minds type of post.
    11TRDTX[QUOTED] and ChadsPride like this.
  14. Jun 27, 2018 at 10:01 AM
    #6794
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Run them all the time, then you'll get used to it and won't bitch about it :boink: :D
  15. Jun 27, 2018 at 5:22 PM
    #6795
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Suspension geometry does not change with tire size. Period.
    How truck interacts with the road will change with tire width/height/weight/condition (ie wear)
    Alignment hasn't changed unless you physically changed it.
    Mud tires CAN put more focus on what was a bad alignment/less than perfect alignment that wasn't as pronounced of a condition with less aggressive treaded tires.
    Existing tire wear changed with swapping tires.
    1 of the last 2
    .....There's where your problem is at.
  16. Jul 2, 2018 at 5:43 AM
    #6796
    dirty deeds
    Nick
    Eastern KY
  17. Jul 2, 2018 at 5:52 AM
    #6797
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    Nice! Very Slick Vid! However, at no point in time did I see Meat let alone Gorging it. I want my money back lol :annoyed:
  18. Jul 2, 2018 at 5:54 AM
    #6798
    dirty deeds
    Nick
    Eastern KY
    Oh, there was meat! And it was gorged! Gotta keep it kinda family-friendly on his page.
    Cody is pretty good with a video camera/drone and editing software.
    FastEddy59[QUOTED] likes this.
  19. Jul 2, 2018 at 6:06 AM
    #6799
    dirty deeds
    Nick
    Eastern KY
    Hey @cllowe24
    Did you do any of the bonding work on this rack? Or was that from the other owner? Curious what was used. One side seems to have held and the other didn't.
  20. Jul 2, 2018 at 9:55 AM
    #6800
    cllowe24
    cllowe24 Well-Known Member
    Mid Tennessee
    2015 access cab
    Billstines with 885 coils 2”aal Lce header, pro dry drop in filter, charcoal filter removal, light bar in grill, ditch lights, yaesu dual band radio, and a bunch of other junk
    No that was all him. All I did was unbox it.
