dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Aug 17, 2018 at 9:59 AM
    #7001
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  2. Aug 17, 2018 at 11:21 AM
    #7002
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    The fox shocks on my mountain bike ride great. Therefore everyone should buy Fox Shoxxx :rolleyes::jerkoff:
    14Tacos4me, 11TRDTX and tacofort like this.
  3. Aug 17, 2018 at 11:25 AM
    #7003
    tacofort
    tacofort Well-Known Member
    Joe
    Cincinnati, OH
    2017 Toyota Tacoma TRD PRO, Automatic, Cement
    Adventure Trailers Tacoma Habitat Pelfreybilt Rock Sliders Line-X Pelfreybilt Pro mid, Gas, Exhaust Reroute Skids Hondo Unholey Dash mount Total Chaos Bed Stiffeners Redline Tuning Hood Lift Struts Weathertech Floor Liners
    Better T shirt logos.
    14Tacos4me likes this.
  4. Aug 17, 2018 at 11:32 AM
    #7004
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Much yes. But, haven't seen a number for their travel length yet
  5. Aug 17, 2018 at 11:36 AM
    #7005
    dirty deeds
    Nick
    Eastern KY
    You're right. Far as the Fox shocks go, short of the coating, they're industry leaders, not just the standard as the rest are. Much muchier in all thing used, again, except the choice of coating applied. And if I were to go 2.5, which is highly likely I will, they're only available in steel bodied, which can corrode faster.
    So far, I've found out that I want/need 650lb coils and extended travel. With or without the swizzle stick DSC Adjusters, from any company. Though, it would be nice to go almost full wet noodle on the trails, then crank out the raging semi on pavement.
  6. Aug 17, 2018 at 11:48 AM
    #7006
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Are you running a uniball UCA?
  7. Aug 17, 2018 at 12:14 PM
    #7007
    dirty deeds
    Nick
    Eastern KY
    SPC LR, old version
  8. Aug 17, 2018 at 12:42 PM
    #7008
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    You continue to mention the coating. Are you looking for a coilover based on its coating? They all started out as steel and then were painted. :gossip: you could paint them yourself....
    But for real, all shock bodies that are steel will rust. There's not a coating on the planet that doesn't break down over time. Spraying Fluid Film on stuff really helps prevent this but don't ever solve it. There's also a reason steel is used. Aluminum is more malleable. Combine that with heat and it will expand much easier then steel. What will happen in these expansions is air will pass by the piston or vica versa and create what's called cavitation (basically air bubbles in the oil). This leads to an array of problems which culminates with blown seals from improper nitrogen pressure and shitty performance from air and oil now passing through the holes in the piston literally creating pockets of "untuned" motion.
    Soooooooo Fox is a shock that categorically matches, or in many cases far exceeds, any other shock in human existence but you question getting them because the paint isn't as good? It's very confusing to me.
  9. Aug 17, 2018 at 1:01 PM
    #7009
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Are you planning to switch to a uniball? I was under the impression you wont be able to take advantage of the extended travel coilovers on a ball joint upper as they will limit the coilover. Asking for my own benefit as I am on 5100s and stock UCA's and have been back and forth on the subject.
  10. Aug 17, 2018 at 1:06 PM
    #7010
    dirty deeds
    Nick
    Eastern KY
    Idk, guess I'm just sweating having rusty $1500+ shocks. But they'll match my slightly rusty sliders and frame :)
    Fox is the industry leader, for sure!
    Pricing from HS Offroad:
    Ext travel, 650 coils, and adjusters
    ADS - $1949.50
    Fox - $1959.95
    ADS is slightly cheaper w/ and w/out adjusters.
    ChadsPride likes this.
  11. Aug 17, 2018 at 1:08 PM
    #7011
    dirty deeds
    Nick
    Eastern KY
    Not planning on it.
    To really answer and add to this point; in email convo between Marie at HS, I was not told my SPC LR ucas wouldn't work with either the Fox or ADS COs. If wrong, hoping someone can chime in about it.
  12. Aug 17, 2018 at 1:14 PM
    #7012
    tacofort
    Joe
    Cincinnati, OH
  13. Aug 17, 2018 at 1:39 PM
    #7013
    dirty deeds
    Nick
    Eastern KY
    tacofort[QUOTED] likes this.
  14. Aug 17, 2018 at 3:40 PM
    #7014
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    You're willing to pay that much for performance coilovers, and you're worried about a 10 fucking dollar difference? The fuck deeds? Get the damn foxes.
  15. Aug 17, 2018 at 4:59 PM
    #7015
    dirty deeds
    Nick
    Eastern KY
    :rofl:
  16. Aug 18, 2018 at 2:31 AM
    #7016
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    Just go SAW and get it over it with. And get 2.5 everything.
    I personally am not a fan of Fox. Can't get behind a company that produces 2 lines of shocks. Performance and Factory series can suck it. How about they just make one line of quality shocks instead of a cheap line and a quality line.
    And I still say Resi's are overrated for the application we use. You're going 15 mph through mud, not blasting over dunes.
  17. Aug 18, 2018 at 2:50 AM
    #7017
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    http://accutuneoffroad.com/articles/fox-2-5-factory-series-vs-2-5-performance-series/
    This reads pretty "Pro Fox", but read between the lines.
    They offer 2 lines. One is substandard to the other. This topic honestly irks me and turns me off to their products. It's the "Good, Better, Best" rating system.
    You can't buy Factory series, without Resi's. They do not offer smooth body Factory shocks, at all, iirc. Which in turn jacks up the price for "Factory Series"
    Resi's look cool. I personally don't want to pay extra $ to look cool though. If I was running fast, then the resi's might have a bit more purpose then they do for climbing up mountains.
    IMO...this stuff is designed to take your money.
    I ride plenty fine on my DKs, Camburgs (SAW), All pros and cheap Toytec rears. I cheaped out on rears, spend wisely and for your uses. Not for some stupid ass looks.
    dirty deeds[OP] likes this.
  18. Aug 18, 2018 at 10:00 AM
    #7018
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I don't care to be a part of the above discussion but if I may make a suggestion Nick .....
    Speaking out of ignorance towards Headstrong, I would purchase my coilovers from a company who's not just a retailer but who works on shocks and tunes shocks. Off the shelf tuning is very generic. Yes it will be better then what you currently have but it's still generic. This means regardless of vehicle weight, tire size, wheel/tire weight, terrain driven on, horsepower, etc .... every coilover is valved the exact same. To use an analogy, it's like buying a turbo diesel from the dealership, keeping it stock then using it to tow a 10k# trailer every weekend. It will be fine but the guy next to you with the exact same truck who chose to put a programmer, intake and exhaust on to gain 300 more torque is using the turbo diesel better specifically to his needs.
    You're worried about buying $1500 coilovers that rust (once again, they all fucking rust!) but you're not worried about buying $1500 coilovers and only using 30% of their performance potential. Downsouth Motorsports, SDHQ, Accutune Offroad, etc .... will custom valve your coilovers for YOUR truck. Not Matt's, Not Mike's, not a 6k# tundra. YOUR truck. If this doesn't appeal to you, you'll be just fine and not any worse off then all the other guys with generic valving. If you want to get a far superior performance experience and actually use the potential of your $1500 rusty steel coilovers then giving one of the aforementioned companies a call is the best decision you can make.
    Once again, Headstrong may do this but I haven't personally heard anything pertaining to them having extensive knowledge of shock tuning.
    dirty deeds[OP] and 11TRDTX like this.
  19. Aug 18, 2018 at 6:48 PM
    #7019
    dirty deeds
    Nick
    Eastern KY
    Now this is the response from you I wanted! Pointing me in a better direction to achieve the proper end result.
    I guess I was a bit ignorant to the valve tuning and didn't expect much beside off the shelf, and to twist the adjusters to my own liking. Still unsure about adjusters anyway, but I also don't want something that's just okay for on/off road, rather it be adjustable and near greatness at both. If I can regular resi shocks turned right, I'll leave off the adjustment knobs.
    When the time comes to get the shocks, likely tax return season, I will look to one of the mentioned shops instead.
    She did just buy a 2015 Traverse LTZ awd today :facepalm:
  20. Aug 18, 2018 at 7:04 PM
    #7020
    dirty deeds
    Nick
    Eastern KY
    Already have their ext travel 2.0 Performance Series IFP in the rear and it was a damn magical difference over the 5100s! Slap in leaf packs and I'm good with the rear for a while.
    To add to what you feel about Fox making multiple lines of shocks, think about Bilstein man. They make 3 or more different shock setups for a Taco, from $300-$2000.
    Sure, resis aren't exactly "needed" for how most of us wheel, but Lola gets what Lola wants. And Lola wants to put resi shocks on front of my truck and I'll let her. :)
    fleckosaurus likes this.
