dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Sep 9, 2018 at 6:58 PM
    #7181
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Got things mostly straight how they should be. Fine tuning is all that's left.
    I really tweaked it hard hitting that ledge at Rush. Just couldn't get on the same line from the day before. Learning curve. Shit happens when you actually push yourself and your tools!
    2TRunner and Robertocritser like this.
  2. Sep 10, 2018 at 4:30 AM
    #7182
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Weld it.
  3. Sep 10, 2018 at 5:31 AM
    #7183
    dirty deeds
    Nick
    Eastern KY
    If it wasn't Appalachian monsoon season, I would! Something tells me welding in rainy weather can hurt the baby.
    Need to practice. Gonna pilfer the scrap bins here at work to play so my tab welds don't come out like total shit.
  4. Sep 10, 2018 at 5:41 AM
    #7184
    dirty deeds
    Nick
    Eastern KY
    Mid skid coming today.
    Clutch by Wednesday.
    Provided weather doesn't interfere.
    Gotta get one of the 2 rear IFS skid bolts drilled out likely. The little nut, inside the cross member before the trans, that's welded in has broken free. Not the first time one of these buggers on the truck did this, first time in this tight a spot though. Skid HAS to come out for easy removal of trans/t case for clutch install.
    Any brilliant ideas? Tried wedging a 13 and 12mm wrench in there to grab the nut. Starts to grab then rolls right off due to angle of the dangle of applied forces. Haven't torched yet. Figure drilling out and attempting to weld it back in would yield a better result.
    beertimecontinuum likes this.
  5. Sep 10, 2018 at 5:42 AM
    #7185
    beertimecontinuum
    Everett
    Good idea :cheers: #pilferbilt
  6. Sep 10, 2018 at 5:44 AM
    #7186
    beertimecontinuum
    Everett
    Hmmmm Txt me a pic when you can
  7. Sep 10, 2018 at 5:45 AM
    #7187
    dirty deeds
    Nick
    Eastern KY
    LAWL!
    What you did, there, I see it.
    11TRDTX likes this.
  8. Sep 10, 2018 at 5:45 AM
    #7188
    dirty deeds
    Nick
    Eastern KY
    This evening I can make that happen.
  9. Sep 10, 2018 at 6:14 AM
    #7189
    dirty deeds
    Nick
    Eastern KY
    This is spot on, mostly.
    My rear is A02A. Which is 8" rear (always heard it's 8.4" though) with 4:10 girz (100% correct) and an open diff (also, sadly, correct)
    I thought the giant "C" on the sticker that's on the diff meant something, likely doesn't mean anything in regard to the above thread. Will look into this further.
    Did this thinking I may have had a LSD in the rear, which sucks!
  10. Sep 12, 2018 at 3:03 AM
    #7190
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    How is the alignment going?
    I am A02A also. Yes, the "8.4" technically measures "8". The biggest difference between our trucks and it seems what appears to be most other Toyota trucks, is our trucks use the handle bar type bearing truss' over the carrier while it seems many of the other trucks do not, If I'm not mistaken.
  11. Sep 12, 2018 at 5:38 AM
    #7191
    dirty deeds
    Nick
    Eastern KY
    Does that add anything for strength or no?
  12. Sep 12, 2018 at 6:04 AM
    #7192
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Hey deeds, i know how you feel about km2's in the rain, but..... it rained this morning here (not too much, but enough). I was turning right onto a street from another (note: there is no stop sign for me), and as i turn, i drift my truck in the turn...... a woman who was driving the opposite direction put her hands up to her windshield and started clapping. That made my morning :humble:
    dirty deeds[OP] likes this.
  13. Sep 12, 2018 at 6:11 AM
    #7193
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    8" and 8.4" are two totally different diffs. Dimensionally they are similar but they each have their own unique R&P, carrier, case and housing. Biggest tip off of the difference is the girdle that bridges over the caps on the 8.4" and makes the housing cover have a significantly different shape from the 8.
    Yes, pretty significant improvement in ring gear deflection.
  14. Sep 12, 2018 at 6:20 AM
    #7194
    dirty deeds
    Nick
    Eastern KY
    I've got my Grabbers back on for the time. #babystreettars
  15. Sep 12, 2018 at 6:22 AM
    #7195
    dirty deeds
    Nick
    Eastern KY
    So, this makes the open diff 8.4 stronger than the 8"? Where's the weak point in locking them?
    Robertocritser likes this.
  16. Sep 12, 2018 at 6:33 AM
    #7196
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Correct. Typically the R&P itself is the weak point...the girdle keeps them together better than the 8" but it's still a relatively small gearset.
    I never had an issue with mine on 37's fwiw.
  17. Sep 12, 2018 at 6:52 AM
    #7197
    dirty deeds
    Nick
    Eastern KY
    This is good news! Hopefully won't go to complete shit with the locker.
    I will likely stay on 33, at most, until I'm 100% ready to regear. Even now, I feel that 4.56 or 4.88 is needed at times running armor and the KM2s. And I'm not even packing all my tools I normally carry every day
  18. Sep 12, 2018 at 9:51 AM
    #7198
    2TRunner
    2TRunner Snoop Dad
    My House Usually
    We said the same thing. In different ways, lol.
    The deflection is what causes ring gear teeth to break off in the off road models. I also personally think its was tears apart Levi's locker. Deflection eventually either shears the carrier bolts or they keep backing out until boom!
  19. Sep 13, 2018 at 6:58 AM
    #7199
    dirty deeds
    Nick
    Eastern KY
    New clutch came yesterday! :yes: Pumped that it's here, not so much for solo intall/minimal help from the gf while she's at work. But, I've read the shit outta @allmotorrex's clutch install write-up and feel pretty confident I can get it done in a weekend.
    Still tossing the idea of whether to resurface the flywheel or not. Might wait til next weekend to really tackle it. Don't want to tear it down and find an issue with short notice of needing time off from my menial job.
  20. Sep 13, 2018 at 9:08 AM
    #7200
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    That's what I thought too.
    It's been sitting for 10 months...
