dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Oct 15, 2019 at 5:33 PM
    #7741
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    But lose all that traction. :der:
  2. Oct 15, 2019 at 5:34 PM
    #7742
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    :rofl:
    I'm out. Doesn't fit my thread title
  3. Oct 15, 2019 at 5:40 PM
    #7743
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    I have their tire deflator. LEGENDARY quality.
  4. Oct 15, 2019 at 6:01 PM
    #7744
    cedarpangolin
    cedarpangolin So country I bleed cedar sap.
    Christian
    2015 Tacoma Access Cab 4x4 2.7L
    1.5" wheel spacers, 2.5 front and 1" rear leveling kit, AFE Dry drop in filter, Thrush Glasspack Cherry Bomb exhaust, Falken Wildpeak AT3W tires Soon to be: bully aluminum side steps, plastidip emblems
    why did i read the title in the tune of the song "dirty deeds"
  5. Oct 15, 2019 at 6:42 PM
    #7745
    presta24
    presta24 Well-Known Member
    chris
    Cincinnati
    2014 Taco TRD 6spd, 2k3 SR5 4runner V8
    Scratches, dents, lots of squeaks.
    OP, we're staying at the Hampton downtown. You owe me $90
  6. Oct 15, 2019 at 8:33 PM
    #7746
    dirty deeds
    Nick
    Eastern KY
    Lol
  7. Oct 15, 2019 at 8:34 PM
    #7747
    dirty deeds
    Nick
    Eastern KY
    Because you like good music! :headbang:
    cedarpangolin[QUOTED] likes this.
  8. Oct 17, 2019 at 6:50 AM
    #7748
    dirty deeds
    Nick
    Eastern KY
    One other thing I noticed after the fact... all the assembly/set up paint markings that were still on there after Gid and I swapped, was completely gone. Not sure how long he had them in his truck, but I couldn't have put much over 10k miles on them myself.
    Makes me think there were bigger things at play here. Likely some misalignment in my driveshaft. I do/did have a carrier spacer in there.
    Also, what company should I get gears from? Nitro, Yukon, others? Do I need the master install kit as well or use what I already have in there? Noted that ECGS states their kit shims aren't as good as OEM.
  9. Oct 17, 2019 at 7:08 AM
    #7749
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Gear pattern paint comes off pretty much immediately in gear oil do nothing nefarious going on there. It looks like shock loading and deflection failure. The setup looks good with a wear pattern erring towards deep on the root of the ring gear teeth. Some sort of shock load happened combined with deflection where the gears pull apart from each other and it blew the end of a tooth off.
  10. Oct 17, 2019 at 7:15 AM
    #7750
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    I’d just call ECGS and see what they recommend. You should be able to get away without a master install kit. Just some shims and they do sell OEM ones I believe. I run Nitro gears with no problems and ZUK likes them too.
  11. Oct 17, 2019 at 7:17 AM
    #7751
    dirty deeds
    Nick
    Eastern KY
    The rock face I climbed, then backed off of, likely left the new scarring I see on the driveshaft where it meets the 3rd. Which is probably also what caused the deflection. All the other scarring is much more forward to the center support bearing and not near as wide and aggressive. I think I've talked myself into the reason/how/why this happened.
    That's what I get for wheeling solo without a "real spotter" :rolleyes:
    I'm ready to watch doll hairs burn, I think. Let's spend some money today!
    beertimecontinuum likes this.
  12. Oct 17, 2019 at 7:18 AM
    #7752
    dirty deeds
    Nick
    Eastern KY
    I may be rethinking the locker situation too. Switch to a more aggressive LSD, idk yet. Like to have selectable, just don't have selectable money right now :rofl::bananadead:
  13. Oct 17, 2019 at 7:28 AM
    #7753
    dirty deeds
    Nick
    Eastern KY
    I sent ECGS a message for help.
  14. Oct 17, 2019 at 9:27 AM
    #7754
    presta24
    chris
    Cincinnati
    Sure it has nothing to do with that high dollar walmart gear oils you rave aboot?
  15. Oct 17, 2019 at 9:55 AM
    #7755
    dirty deeds
    Nick
    Eastern KY
    Actually, after reading their tech articles on ECGS, all syn oils aren't what they consider ideal, over dino w/ an additive and shorter change intervals. Looks like I'll be switching to an even cheaper option! :headbang:
    presta24[QUOTED] likes this.
  16. Oct 17, 2019 at 9:58 AM
    #7756
    dirty deeds
    Nick
    Eastern KY
    New Nitro 4.88s for the rear, Yukon master install kit, solid spacer with shims kit (to use instead of the aftermarket shims in the master), new springs and pins for the locker, free shipping = $520
    :eek: :spending: :burnrubber: :mudding: :oldglory:
    hopefully some stickers for $500!
  17. Oct 17, 2019 at 10:01 AM
    #7757
    dirty deeds
    Nick
    Eastern KY
    @Caboose117 can you compete with that price? If so, shoot me a PM sir
    Caboose117 and My Name is Rahl like this.
  18. Oct 17, 2019 at 12:22 PM
    #7758
    dirty deeds
    Nick
    Eastern KY
    Too late. Already ordered. ECGS said parts expected this Saturday!
    Hello, ramen, my old friend
    Justinogo likes this.
  19. Oct 17, 2019 at 1:26 PM
    #7759
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    ECGS still suggesting Lucas 85W-140 non-synthetic?
    Worked fine for me i think and was cheap enough.
    dirty deeds[OP] likes this.
  20. Oct 17, 2019 at 1:41 PM
    #7760
    dirty deeds
    Nick
    Eastern KY
    Yes they are. I've used Mobil 1 once and SuperTech synthetics since owning the truck. Never had a problem and the oil was never that bad. The OEM (assuming here) when I changed it first at 30k, was black, then dark brown, then a few drips of medium brown.
    If they recommend the dino, I'll get the dino.
