dirty deeds' deeds, done dirt CHEAP! and dirty vibes
Discussion in '2nd Gen. Builds (2005-2015)' started by dirty deeds, Nov 7, 2016.
  1. Apr 22, 2020 at 11:29 AM
    #7861
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I dont think we wheel enough to justify the bling. They're badass though
    I voted 5100s because of this vvv.
  2. Apr 22, 2020 at 12:01 PM
    #7862
    dirty deeds
    dirty deeds [OP] Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    ~2 weeks for new rear diff
  3. Apr 22, 2020 at 12:08 PM
    #7863
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    i seriously considered 6112's and read halfway through the thread then quit because of the information/settings/opinions to get "x" amount of lift varied so much. at 1 point i saw people were having to set at clip 5 or 6 just to get 2.5/2.75". i might go back through/pick up where i left off later on..... but i will recommend you to go through it; being that you have a access cab, it will be different for you anyway.
  4. Apr 22, 2020 at 12:10 PM
    #7864
    dirty deeds
    Nick
    Eastern KY
    I've browsed it a bit too, lots of conflicting info. Made my head hurt like reading the ebay bumper thread.
    11TRDTX[QUOTED] likes this.
  5. Apr 30, 2020 at 1:15 PM
    #7865
    dirty deeds
    Nick
    Eastern KY
    Thanks for ideas with that poll, but I just got a good deal on new 5100s.
    Now to decide if I switch to Headstrong coils or get OME, again. Leaning toward the HS coils and see how they run, hoping they have a better (more comfortable) spring compression. The OME work and they're good, but they are a touch harsh on compression and rebound both on and off road, IMO.
    My Name is Rahl likes this.
  6. Apr 30, 2020 at 2:31 PM
    #7866
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Wouldn't this mean you need a longer, but lighter spring?
  7. Apr 30, 2020 at 3:41 PM
    #7867
    dirty deeds
    Nick
    Eastern KY
    I dunno you tell me lol
  8. Apr 30, 2020 at 4:33 PM
    #7868
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
  9. May 1, 2020 at 5:28 AM
    #7869
    dirty deeds
    Nick
    Eastern KY
    I think I'm gonna try the HS 2" coil and see how I like them. I should get right around 2 since that's rated for a DC 4x4 taco, assuming the weight difference isn't much greater due to bumper, skids, and winch.
  10. May 1, 2020 at 6:10 AM
    #7870
    dirty deeds
    Nick
    Eastern KY
    Anyone up for a 'Rona build day in the coming weeks?
    Rear diff.
    Pull a leaf out.
    Adjust parking brake and bleed/flush all 4.
    Install the LCE short shifter I've had for MONTHS while the console is out to adjust brake.
    Probably more I could dream up.
    I've got meat I can smoke now that I got a side fire box for the Char Griller, and maybe I'll even buy ronas :)
  11. May 1, 2020 at 7:09 AM
    #7871
    JohnnyRed
    JohnnyRed Well-Known Member
    Northern Kentucky
    2008 DCLB TRD Sport
    You're pullin leaves, I'm adding leaves. What's your leaf setup again? I'm installing a Dakar el95r with a EL46XL added to them. If I don't do it this weekend/week I'd be up for a mod day.
    Why you taking a leaf out anyway? Too harsh?
    dirty deeds[OP] likes this.
  12. May 1, 2020 at 7:22 AM
    #7872
    dirty deeds
    Nick
    Eastern KY
    I've got Dakar HD and it's almost too much lift/stiff ride/not enough flex.
    I also should weld my cam tabs. Currently starting a tool box project and fabbing some brackets for it since it's a bit narrow to sit on the bed rails, it was a killer deal. The tool box, when loaded might help chill the leafs though.
  13. May 1, 2020 at 7:50 AM
    #7873
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    From what I've read, my 95R with the AAL should be the same as the HD. (I thought I read it was a little less stiff, but can't find that source). Maybe my added weight of the DC & v6 will work out well for me. The HDs do seem like they'd be overkill for your truck.
    Do your leaves have the yellow greasable anti friction pads? If not, you can have mine if you want them. I replaced mine with the Dorman ones.
  14. May 1, 2020 at 8:05 AM
    #7874
    dirty deeds
    Nick
    Eastern KY
    Not sure on the pads, think they're just black or opaque plastic looking things iirc when I installed them. Brent or Everett may or may not remember.
    We did replace all the bushings, however. I just deal with the squeak and creak and lube with Fluid Film when I get tired of it.
  15. May 1, 2020 at 9:46 AM
    #7875
    dirty deeds
    Nick
    Eastern KY
    ...not anymore chief :rofl:
    Just took a quick measure. Driver ~21.25", Pass ~ 21.75". Almost a 2" loss from the bumper/winch/skids and worn front bouncy things.
  16. May 1, 2020 at 9:46 AM
    #7876
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    put a few zipties around the ends of one of the leafs, I forget which one, but that solved my squeak on Dakar pack.
  17. May 1, 2020 at 9:47 AM
    #7877
    dirty deeds
    Nick
    Eastern KY
    Really, though, I just turn the radio up or throttle more :lalala:
  18. May 1, 2020 at 10:08 AM
    #7878
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Lol. I always heard it going slow in parking lot and speedbumps at work so your method wouldn't have been good for me there.
  19. May 1, 2020 at 10:23 AM
    #7879
    dirty deeds
    Nick
    Eastern KY
    Neutral bombs ftmfwaf
    totmacher[QUOTED] likes this.
  20. May 2, 2020 at 2:24 PM
    #7880
    JohnnyRed
    Northern Kentucky
    2008 DCLB TRD Sport
    Well, my dakars are in. Can't say I enjoyed it. Had a siezed bolt on the front side of each pack. Luckily I was already planning on replacing those with a greaseable bolt. If you do a mod day I'll take the role of the gringo and supervise while sharing my new found tips and tricks.
