dirty exhaust?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mgrande, Feb 21, 2010.
  1. Feb 21, 2010 at 7:15 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Kings, AP 3" leaf pack, timbrens front and rear, TC UCA's, pro comp 7189's, baja ATZ's, CBI sliders and rear, relentless front, dynomax catback
    After moving to miami I have started to get a lot of black, spots from my exhaust on my paint. I took a look at it while it was running and I had a lot of condensation. Is that the cause this? I do a lot more small trips now, which would explain the condensation.
    Here's a picture of it. I just want to make sure it's not a fuel or oil problem.
  2. Feb 21, 2010 at 7:17 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Alot of short trips, mean the truck is running more in open loop, so its going to run more rich. Soot around the pipe is normal.
  3. Feb 21, 2010 at 7:19 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Thanks chris! What is "open loop" mean?
  4. Feb 21, 2010 at 7:38 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    All of those black spots/splatter is from the exhaust?! That doesnt even seem like it could do that. Doesnt really make sense to me. Some black discoloration would be normal, but not that splatter imo.
  5. Feb 21, 2010 at 7:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Open loop, is when the enigne ECU (when cold/not up to operating temp), ignors the signal from the O2 sensors, and gets its Air/ Fuel data from the Coolant sensor, and/or the MAF, or a pre programmed MAP. Closed loop is when the engine is up to temp, and the ECU is getting its Air/Fuel data from the O2 sensors. When in Open Loop, the engine runs rich, to aid in warm up.
  6. Feb 21, 2010 at 7:42 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Yeah, that's all from the exhaust. Makes a real mess...
  7. Feb 21, 2010 at 7:48 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    Got it, basically I'm going to run rich and burn more fuel while running around. :mad:
  8. Feb 21, 2010 at 8:08 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If all the trips are short, yes.
  9. Feb 24, 2010 at 5:47 PM
    wnealw
    wnealw Active Member
    Fredericksburg,Va.
    08 tacoma 2wd
    scanguage,thrush turbo muffler wellded in.
    over filled crank case will do the same thing
  10. Feb 24, 2010 at 6:19 PM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
  11. Feb 24, 2010 at 9:52 PM
    mgrande
    mgrande [OP] iKill
    Raleigh
    2011 TRD off road
    You mean too much oil?
    I have the stock air setup right now.
  12. Feb 28, 2010 at 5:43 AM
    wnealw
    Fredericksburg,Va.
    08 tacoma 2wd
    Had mine changed at a dealer once. They did not drain the old oil. mpg went down and had the same oilly specks on the side of my fender. When i drained my oil it over filled a 10 qt pan all over the driveway. After that all was good once again
