Disable ABS for heavy snow
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 12tinker, Oct 24, 2009.
  1. Apr 27, 2014 at 2:33 PM
    #81
    Infmous89
    Infmous89 Infamous89
    Glenwood spring CO
    05 tacoma sr5 sport
    Im sorry im curently on the road goin tords were thiers gna be some snow.just had a quick question i have a 2005 tacoma was wondaring wich abs fuse to take out i hsve 2 of them i bealive ......
  2. Apr 27, 2014 at 3:38 PM
    #82
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Did you post that while you were driving ?
  3. Apr 27, 2014 at 4:14 PM
    #83
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Looks like it or the spell check doesn't work or both.:rolleyes:
  4. Apr 28, 2014 at 4:20 AM
    #84
    HankB
    HankB Well-Known Member
    Hank
    near Chicago
    06 Preruner TRD Off Road
    bone stock
    I have to admit that my thinking has turned around on this. This last winter I did some tests with just a little snow on the pavement. I had much better braking ability with the diff locked (which disables ABS.) Under those conditions braking benefits if the tire can slide a little and build up a wedge of snow. Unfortunately ABS detects that and releases the brakes just enough to roll over the wedge and that results in reduced braking. Under those conditions braking is compromised by ABS and that's unfortunate as it is when ABS could be most beneficial. (Also unfortunately it does not benefit to drive with the diff locked under those conditions as it makes cornering a little too exciting.)
