Disable cluster lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rtadams89, Aug 3, 2020.
  1. Aug 3, 2020 at 11:36 PM
    jmauvais
    jmauvais Received 2 votes in a poll one time.
    NorCal
    2018 TRD OR 4x4 DCSB
    ...stuff
    Man of my word.
    Photo from the site, not mine, so ignore the arrow. This is fuse box in driver footwell, second from the bottom on the right side, D/L (dash lights). Not sure if that’ll disable the led screen though, and not sure if anything else in that circuit is required to drive the vehicle, but that is the dash light fuse.
  2. Aug 3, 2020 at 11:37 PM
    Fatback17
    Fatback17 Masshole
    Billy
    South of Boston, Massachusetts
    2020 TRD Pro MGM
    Tell us damnit! Why NVG's??
  3. Aug 3, 2020 at 11:41 PM
    rtadams89
    rtadams89 [OP] Well-Known Member
    Phoenix, AZ
    2017 Tacoma Limited
    That's not it. Pulled that one earlier and all the dash lighting stayed on.
  4. Aug 3, 2020 at 11:46 PM
    jmauvais
    NorCal
    ...stuff
    interesting. I’m assuming the engineers never imagined a situation where a driver would be using nvgs and want the dash lights disabled, so it may not be possible.
    @caribe makaira Any idea sir?
    I’m thinking if you’re really motivated, you could pull the cluster to inspect the illumination bulbs, if they are all wired up with a common power line connecting them all, you could probably add in a simple switch somewhere on the power line. I’m assuming it’s already fused and relayed, so a simple switch somewhere on the power line with that switch mounted somewhere under the dash would be a relatively easy mod.
  5. Aug 4, 2020 at 2:27 AM
    GunstarHero
    GunstarHero Active Member
    2018 Cement TRD Off-Road
    i have wondered this same thing but have yet to thoroughly find a fix. I attempted to run it with the lcd screen off and with a shirt over it but it’s still extremely bright under nods. I saw a while back that Lucas from Trex Arms had a blackout switch installed into his 4Runner for use with driving under nods. From his description at the time he claimed he was able to kill all the lights in the vehicle at once? Might be worth reaching out if you can get an answer.
  6. Aug 4, 2020 at 2:41 AM
    GunstarHero
    Edit: I found the post where he discusses the mod on his personal IG page. Work completed by High Country Cruisers, he says it kills the brake lights and interior lights but not the main HUD, I’m assuming he means the dash and not the lcd head unit? His fix for the dash was to cut a piece of opaque plastic to fit over the cluster so he can still see the gauges under nods, not a bad idea.
  7. Aug 4, 2020 at 3:34 AM
    Gregw138
    Gregw138 Well-Known Member
    Greg
    NY
    2019 TRD Off Road DCSB 2016 Lexus ES350 2009 Lexus ES350
    WAY TOO MANY
    Maybe a ninja ??:anonymous:
  8. Aug 4, 2020 at 8:22 AM
    caribe makaira
    Caribbean, Puerto Rico
    D/L - door lock
    hodo_taco and jmauvais[QUOTED] like this.
  9. Aug 4, 2020 at 8:23 AM
    caribe makaira
    OP, didya see this and tried it?
    Bleep100 and jmauvais like this.
  10. Aug 4, 2020 at 8:26 AM
    CrazyAirborne
    CrazyAirborne Who jumps out of perfectly good airplanes?
    Central Wisconsin
    2017 TRD Sport
    Obviously drug running for mexican cartels...
  11. Aug 4, 2020 at 9:49 PM
    jmauvais
    NorCal
    ...stuff
    ahhh makes sense thank you!
  12. Aug 4, 2020 at 10:08 PM
    CdnDave20
    CdnDave20 Active Member
    Stock
    <FBI Enters the chat>
    Skydvrr likes this.
  13. Aug 4, 2020 at 10:15 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    He might be the FBI .
