Disable door lock "beep" on 2012?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RV7Garage, Nov 21, 2011.
  1. Nov 21, 2011 at 3:23 PM
    RV7Garage
    RV7Garage [OP] R.O.U.S.
    Paul
    Ill Annoy
    2012 DCSB Offroad, Nautical Blue
    Disable DRL, Jailbreak Fog Lights, ARE topper
    HATE the unnecessary (to me) "beep-beep" when using the keyfob to lock or unlock the doors. Anybody know how to turn this off?
    Apologies if this has been discussed already, but the second beer made me lazy:notsure::D
  2. Nov 21, 2011 at 3:25 PM
    Aw9d
    Aw9d That one guy
    I had the dealer shut mine off.. While your in there getting that done don't forget to ask them to turn off the seatbelt beeps too!
  3. Nov 21, 2011 at 3:27 PM
    RV7Garage
    Paul
    Ill Annoy
    Seriously! And the damn DRLs, too:rolleyes:
    It used to be that their business model revolved around keeping you out of the dealer. Guess they figured out that they make more money the other way around... but it is ANNOYING...!
    Thanks guys :cool:
  4. Nov 21, 2011 at 3:30 PM
    RV7Garage
    Paul
    Ill Annoy
    It's just a personal thing for me, whippersnapper. I like to buy a car, do the routine maintenance myself, and go to the dealer as infrequently as possible! I must be getting old... :mad:;)
  5. Nov 21, 2011 at 3:46 PM
    RV7Garage
    Paul
    Ill Annoy
    Damn, lol!
  6. Nov 21, 2011 at 4:20 PM
    JKD
    JKD Well-Known Member
    If you want to reduce the volume significantly, you can roll up an expanding-foam earplug and put it into the beeper hole in the little beeper at the front driver's side corner of the engine compartment.
    I suspect you could just disconnect that if you want it silent, but I can't guarantee that wouldn't have some unintended consequence.
  7. Nov 21, 2011 at 6:00 PM
    RV7Garage
    Paul
    Ill Annoy
    Good idea!
  8. Nov 21, 2011 at 6:27 PM
    Nutn
    Nutn Member
    TRD sport package
    Also wondering if it is possible for dealer to disable chime for leaving the keys in the ignition while opening the door when the engine is off. Thanks in advance.
  9. Nov 21, 2011 at 6:36 PM
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Door unlock/lock "beep" .... lift hood .... mounted towards the right front .... hit your fob .... listen/look for the beeper ... unplug/remove.
    Beeper removed:
    Taped over end:
  10. Nov 21, 2011 at 6:52 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails, RokBlokz mud flaps WANT: Rear Plate Bumper, Steel bed cage
    The problem with having the dealer or a shop do it is that the equipment to perform those functions is very expensive, (to the tune of several thousand dollars a month in subscription/update fees) so just about any time they plug it into a car they will charge a flat fee of $20-$50. This is when it helps to have a friend who works at a shop that can just plug it in and let you play with it :)
  11. Nov 21, 2011 at 6:58 PM
    Deliman619
    Deliman619 No bad days
    New Jersey
    2010 4x4 TRD Off Road
    Extang Tri-Fold Tonneau, WeatherTechs, Borla Exhaust, ICON 2.5s w/resi all four corners, ICON UCAs, ICON AAL, aFe CAI, All-Pro Flip Kit, and CBI sliders
  12. Nov 21, 2011 at 7:33 PM
    RV7Garage
    Paul
    Ill Annoy
    open driver door
    insert key into ign
    remove from ign
    within 5 seconds reinsert key and turn ign switch on
    after 10 seconds MAY give you an answer back buzzer
    within 10 seconds after that hit a transmitter button twice to change the setting.
    I did not get an answer back after 10 seconds but it does work.
    Thanks, Taco Mike! :cheers:
    If only they had made it this easy to disable the seatbelt beep...!
  13. Nov 22, 2011 at 11:37 AM
    three west
    three west Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    whoah, awesome! I searched quite a bit when I first got this truck because I figured there was a way to do this, but I never found an answer. I quit using the keyless because I hated the beeps so much.
    worked on my '09!
  14. Nov 22, 2011 at 4:38 PM
    Nutn
    Nutn Member
    TRD sport package
    Does this work on the 2012?
  15. Nov 22, 2011 at 4:57 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Try it out and let us know.
  16. Nov 22, 2011 at 4:59 PM
    RV7Garage
    Paul
    Ill Annoy
    Did for me! Couldn't be happier
  17. Nov 27, 2011 at 1:50 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    I just did this on my 12 as well...Took me a few times to realize you have to leave the KEY in the Ignition while doing the last step. (press any button on the fob twice)
  18. Nov 27, 2011 at 5:58 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    just did mine, thats awesome! now someone find out how to do the seatbelt without having to go to the dealer!!!
  19. Nov 28, 2011 at 8:09 AM
    RV7Garage
    Paul
    Ill Annoy
  20. Nov 28, 2011 at 3:18 PM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
