Disable Entune Autoplay When Connected via Bluetooth Audio?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by myoldmantruck, Feb 27, 2019.
  1. Feb 27, 2019 at 4:48 PM
    myoldmantruck
    myoldmantruck [OP] Well-Known Member
    I'm surprised that this is not all over YouTube or the web in general.
    Does anyone have a solution not to have your phone start playing music when connected to Entune audio?
    The default is for it to start playing your music and you have to hit the pause. I only want it connected so I can hear Google Assitant through the speakers.
    Thanks in advance.
    Ben3mar likes this.
  2. Feb 27, 2019 at 4:50 PM
    Ossaris
    Ossaris A Bad Person Doing Good Things
    Aliens
    SoCal
    2016 TRD OR 4x4 w/ 6112s & 5160s
    Lights for days! Sasquachified!
    Likely cause people like their music! :D
    I do not think there is a solution here. One option might be to simply have your music audio level set to zero on bluetooth so you only get assistant - that can be done through settings
  3. Feb 27, 2019 at 6:00 PM
    andrewbrandon19
    andrewbrandon19 Well-Known Member
    More likely a setting on your phone than a setting in the truck. Google play music pisses me off with this as it will override whatever I was doing last (pandora, iheart, youtube, ect) and start playing. The only way to stop it from doing it is to restart my phone. It will not auto play until I open the app again.
    Ben3mar likes this.
  4. Jul 12, 2019 at 12:00 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
    Found this thread, and I'm looking for a fix for this as well.
    Music from my iphone begins to play the moment the phone connects with Entune. It's irritating, and depending on what some comes on, can be jarring.
  5. Jul 12, 2019 at 1:29 PM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    I like hopping into my truck and having the last song I was listening to start playing again. I just wish my phone would do better remembering the bluetooth profile and set the volume where it was. Although, maybe it's Toyota's fault.
    When I use a bluetooth speaker, the phone volume and speaker volume are linked, but in the truck, the phone has to be at maximum for best sound, for whatever reason.
  6. Jul 12, 2019 at 1:41 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Mine will only autoplay bluetooth if that's the last setting it was on. If I for example leave in on XM it will play that and will only start bluetooth if I switch to that source. So just leave the radio on a different setting and it should do what you want?
  7. Jul 12, 2019 at 1:45 PM
    Bunk Moreland
    Bunk
    It's complicated.
    What's truly weird, at least to me, is that I listen to audio books most of the time; yet it's always some random song that begins to play when the phone & truck connect...
    Thanks for this workaround; I will definitely try it!
  8. Jul 12, 2019 at 1:50 PM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    I believe Entune just remembers what you last did when you turned off the truck. So when you restart the truck, it continues... therefore, go to that app and press stop.
    Bunk Moreland likes this.
