Disable passenger side airbag
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mmatheny, Nov 2, 2017.
  1. Nov 2, 2017 at 7:27 PM
    Brenden J
    Brenden J Well-Known Member
    Brenden
    2016 Tacoma TRD sport
    The only time the front airbag will go off is if the light on the dash says the air bag is on. If the light say its off the airbag is off. If there is no light then the airbag is also off. And putting the seat belt on does absolutely nothing to the airbags power. If will deliver the same power if the seat belt is used or not. Two stage air bag only means there is an initial stage to set off the bag at time zero and then (for the Tacoma specifically) 120 msec later the second stage goes off the open up the airbag vents. I know all of the this because I work at a crash test lab and have tested this truck personally.
    la0d0g, digitaLbraVo and Boudreaux like this.
  2. Nov 2, 2017 at 7:41 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    You own a Tacoma which says alot about how safe the truck is.
  3. Nov 2, 2017 at 7:47 PM
    Brenden J
    Brenden
    Thats true but what ive seen is every car is reasonable
    safe as long as you wear your seat belt and dont hit anything going 85mph. Force=Mass x Acceleration pretty much always wins
  4. Nov 2, 2017 at 7:53 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    You can turn the seat belt chime off. Then it never beeps. Airbag still activate based off weight.
    digitaLbraVo likes this.
  5. Nov 3, 2017 at 12:02 AM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    That's why I'd loop the belt behind the dog if he's making it chime. Surprisingly neither (50lb) dog makes the stupid noise but in the Miata they'll make the light annoy me.
  6. Nov 3, 2017 at 5:25 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    I don’t believe it works as a weight sensor anymore. Toyota has moved to an electrical sensor for detection not a weight sensor. I’ve seen it posted somewhere on here and I know a lot of other Toyota models are using the electrical field or whatever type tech.
    Which is why leaving a phone or something in the seat can trigger the sensor in some vehicles.
    Edit: 3rd gen apparently has stress type sensors for weight, at least that’s what Katzkins says in one of their PDFs. Idk what official Toyota docs say.
  7. Nov 3, 2017 at 6:28 AM
    mmatheny
    mmatheny [OP] Well-Known Member
    Dickinson, Tx
    2017 SR5 DCSB Magnetic Gray Metallic
    BakFlip MX4
    How do you disable the chime?
  8. Nov 3, 2017 at 6:57 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
  9. Nov 3, 2017 at 6:57 AM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    Will Techstream also do it?
  10. Nov 3, 2017 at 7:00 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That's pretty cool. Maybe an induction sensor like the ones at stoplights?
  11. Nov 3, 2017 at 7:06 AM
    Xena1
    Xena1 Well-Known Member
    Ron
    2017 Tacoma Access Cab
    I have a seat belt clip in mine that I got from the junk yard. With it in and little weight on the passenger seat, the airbag is turned off. Says so right on the dash.
  12. Nov 3, 2017 at 9:09 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    You right that the newer sensors no longer uses weight. The new sensors actually measure water content.
  13. Nov 3, 2017 at 11:58 AM
    Brenden J
    Brenden
    Tacoma still uses weight. Most OEMs use capacitive systems now but the Tacoma still just used a weight based system. The air bag will turn off if there isnt enough weight in the seat and the seat belt clipped in because the system is assuming you have a small child or car seat sitting in the front seat in which case you would not want to blow off any airbag so the system turns it off
  14. Nov 3, 2017 at 12:01 PM
    mmatheny
    Dickinson, Tx
    BakFlip MX4
    So in theory my pug shouldn't arm the air bag?
  15. Nov 3, 2017 at 12:04 PM
    #35
    la0d0g
    running for the hills
    For crawling not hauling
    A case of beer on the T4R's passenger seat doesn't make it ding but my 60lb dog does. This is scientific!
  16. Nov 3, 2017 at 12:18 PM
    #36
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have no idea. I have the software but have not bought the cable yet.
  17. Nov 3, 2017 at 12:19 PM
    #37
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You just need to look at the light on the dash. If it says, Airbag On, then the airbag might fire in an accident. If it says, Airbag Off, then . . .
  18. Nov 3, 2017 at 12:42 PM
    #38
    Brenden J
    Brenden
    The light tells it all. If the light says airbag on then the airbag is on. If the light says airbag off then the airbag is off. If there is no light on at all then the airbag is off.
    It depends how the truck classifies whats in the seat. If you click the seat belt in the truck will assume there is something in the front seat and will determine if it needs the airbag on or off. If the OCS (occupant classification system), in this case a weight system, determines what is in the front seat by weight then it will turn the airbag on or off. I believe 60lbs is correct. If it is under 60lbs the OCS system will tell the airbag to turn off because there could be a small child or child seat in the front seat and you dont want the airbag hitting them.
    Long story short is look at the light on the dash
  19. Nov 3, 2017 at 1:04 PM
    #39
    la0d0g
    Isn't all this info in the manual? :notsure:
  20. Nov 3, 2017 at 2:22 PM
    #40
    RedBeard1
    RedBeard1 Baby Ruuuuuth!
    Red
    The Republic of Texas
    1985 Hilux Crawler(Pete), 2016 Quicksand TRD OR 6MT (Wombat), 2016 TRD Pro T4R (OVTUNE # 2403)
    Mostly stuff I built.
    Make your dogs stay off the seat. My 80# Heeler stays in the passenger floor board. Not even aloud to put his head in the seat.
