Disable rear diff lock
Discussion in '2nd Gen. Tacomas (2005-2015)' started by fastdave, Sep 18, 2008.
  1. Sep 18, 2008 at 1:11 PM
    fastdave
    fastdave [OP] Member
    The other day my rear diff lock would not disengage. After a little messing with it and turning the steering wheel it finally did disengage. This brought a thought to mind; if I was in the middle of nowhere and it failed in the locked in position how could I disable it? If I remove the power (if it isn't a mechanical problem) would it disengage? Is there a fuse or can I unplug it? Does it need power to ENgage? Also what would happen if I accidently pushed the engage button when I was going down the highway? Is there an interlock to prevent that from happening?
  2. Sep 18, 2008 at 1:14 PM
    CornDog
    CornDog Well-Known Member
    Gallant, Alabama
    2007 SpeedWay Blue Double Cab Tacoma
    12000 lb Milemarker Winch Warn Trans4mer Grille Guard Gear Motorsports Wheels, Pioneer Head Unit w Ipod Interface, 2 Diamond D3 10's in custom box, UWS black tool box. N-fab stepbars, 15% tint, bug deflector,ventvisors, K&N Series 77 Cold air Intake, Hi lift jack mounted, 4D-LED maglite mounted, Lund Grill Screen
    well it wont lock up if you have a 4wd and ur goin down the road til you throw it in 4 low from what ive heard. i have an 07 tacoma and mines hung up engaged b4 while i was workin on the electrical side of it in the cab. the only way i got it to disengage was to get under the truck and unplug it. i fiddled with it for several minutes b4 i finally just unplugged the electrical connection on top of the locker. that did it for me....... i dunno if it would work again tho.............
  3. Sep 18, 2008 at 1:23 PM
    CornDog
    Gallant, Alabama
    yep i got mine modded tooo thats when it locked up and wouldnt unlock...... i finally got the schematics rite on my relay and it worked fine................
  4. Sep 18, 2008 at 7:12 PM
    fastdave
    I don't have a 4WD. The light switch is located right next to the rear diff lock switch. I just I hope I don't accidently hit the wrong one. It would be nice to have a cover that you have to flip up to have access to it.
  5. Sep 18, 2008 at 8:42 PM
    dbbd1
    dbbd1 Well-Known Member
    Is yours a Prerunner?
  6. Sep 18, 2008 at 10:00 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    There shouldn't be any ill affects from driving with it engaged. Back in the day I drove my chevelle like that 24/7 They put those stupid speed limits on there to cover there asses. The only time having your rear locked is a problem is on a hard turn. The inside tire wants to rotate faster that the outer, rough on your tires if you don't take it easy.
    don't turn and let the hammer down or shit will break.
  7. Sep 19, 2008 at 10:31 AM
    fastdave
    My truck is a 2wd Prerunner. I read in the book that you should not go over 5 mph with it engaged. What if I was going down the road at 60 mph and I decided to turn on my lights that are operated by the switch next to the rear diff lock and accidently pushed it instead of the light switch?
