Disable Rear E-Locker?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ukeacreator, Feb 7, 2023.
  1. Feb 7, 2023 at 12:53 PM
    ukeacreator
    ukeacreator [OP] Well-Known Member
    Nikolas
    BC CANADA
    2016 Grey Tacoma TRD OffRoad
    285/75R16 DURATRACS FUEL VECTOR 16 3 INCH CUSTOM LIFT
    I swapped axles to an auto LSD on my trd off road because thats all i could find at wrecker and I could care less about the locker, mine took forever to engage and disengage anyway. I cant find a Fuse for for the diff lock.
    Aside from putting a paper clip in the connector at the diff (this works for a few days at a time but fails after a while resulting in the 4x4 light flashing while its in 2wd out of the blue), is there any other way to make the truck think the locker is there so i can use my 4x4 again or disable it?
    Right now without the locker my ABS light is on 4X4 light and diff lock light are all flashing unless i put a clip in the connector.
    Yes my 4x4 works if i put paper clip in connector but im looking for something more reliable
  2. Feb 7, 2023 at 1:07 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're kind of in unknown territory. I'm not sure that there is an easy solution.
    Chew likes this.
  3. Feb 7, 2023 at 1:43 PM
    caribe makaira
    Caribbean, Puerto Rico
  4. Feb 7, 2023 at 1:47 PM
    ukeacreator
    Nikolas
    BC CANADA
    Amazing what a paperclip can do lol
  5. Feb 7, 2023 at 1:47 PM
    ukeacreator
    Nikolas
    BC CANADA
    I kind of figured, thanks anyway. It was worth a shot
    tonered[QUOTED] likes this.
  6. Feb 7, 2023 at 1:49 PM
    caribe makaira
    Which connector are you inserting clippy?
  7. Feb 7, 2023 at 1:50 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    If the paper clip works, just build a connector that does the same, so it’s not coming loose and gets element protection
    Kaptain_02 and jmneill like this.
  8. Feb 7, 2023 at 1:52 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    The 4wd ECU expects the correct resistance.
    Just need the correct resistor and correct wiring skills
    (Think both may need some work here)
    Skydvrr, hiPSI, na8rboy and 2 others like this.
  9. Feb 7, 2023 at 1:53 PM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    In another thread about a locker anytime harness the computer looks for a few things with actuating.
    When turning on the computer applies power to the elocker. When the elocker engages a voltage spike is detected and this is how the computer knows the locker is done actuating. After this the current is reduced to the coul to limit heating.
    The closest proxy you could put in to dummy the locker would be a big relay or a contractor as they are both coil based. The contractor is probably closer to the 2A or so the elocker takes. Hopefully not too quick (compared to locker) to be detected too.
    Jumping to solutions, yes a resistor would work. Would strat with 10ohm and parallel another if that doesn't work. Check for heating but if not actuating it's probably low current through it.[/S]
  10. Feb 7, 2023 at 1:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I took the locker out of my 2015 2nd Gen and the truck wasn't any wiser. 4wd worked fine, no dash lights or errors. So this seems unique to updates in 3rd Gen ECU.
    BigWhiteTRD likes this.
  11. Feb 7, 2023 at 1:57 PM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    If you are never actuating the locker then this would be correct. Disregard my previous post needing another coil to dummy.
    BigWhiteTRD[QUOTED] likes this.
  12. Feb 7, 2023 at 1:57 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Can you cannibalize the old rear end with parts from the newish and create one proper unit? What the heck happened in the first place where you needed an entire new rear axle?
  13. Feb 7, 2023 at 2:01 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome.
    Good luck!
  14. Feb 7, 2023 at 2:03 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Welcome to the 3rd Gen where angry pixie mods are rarely easy.
    SR-71A, ukeacreator[OP] and Squirt like this.
  15. Feb 7, 2023 at 2:06 PM
    BigWhiteTRD
    Ted
    ~3 ohms is what we wrote down in the anytime-lock-dev thread for approximate coil resistance.
    Note, 4wd ecu is also checking for current leakage per my memory, you cant let your resistor have any ground faults, so good sealing will be important... (per my memory)
    somebody and tonered like this.
  16. Feb 7, 2023 at 2:08 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
    I would buy a spare connector that matches it and just jump the wire from one side to another or with the appropriate resistor.
  17. Feb 7, 2023 at 2:31 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    3'ish ohm resistor should do it. Just know it's as much as 50W if you ever actuate the resistor as though it's the locker.
  18. Feb 7, 2023 at 2:35 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    2nd gen (and earlier Toyotas) had a motor actuating the locker. 3rd gen uses a solenoid. It's intended to be a more robust design.
    SR-71A and crashnburn80[QUOTED] like this.
  19. Feb 7, 2023 at 2:37 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Wouldn't it be a good idea to also disconnect the locker switch at the roof console, in case it is inadvertently pushed "ON"?
  20. Feb 7, 2023 at 3:14 PM
    BigWhiteTRD
    Ted
    Absolutely, and disconnecting the roof console switch will not throw any codes, etc...
    Otherwise you will burn up the resistor... (and all the wiring, truck, gas tank, etc)
    splitbolt[QUOTED] likes this.
