Disable Rear E-Locker?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ukeacreator, Feb 7, 2023.
  1. Feb 7, 2023 at 3:18 PM
    somebody
    somebody GAR-FAB.ca
    Durham ON
    19 DCLB Sport
    Possible the computer would fault out after a few seconds of not detecting an engagement (resistor won't have emf pulse).
    Def worth a test to see if it gets the resistor too hot.
  2. Feb 7, 2023 at 3:19 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    What do you mean by “I swapped axles to an auto LSD”? Do you mean you installed a 3rd gen axle without a locker (ie an axle from a trim other than a OR or Pro)? Auto LSD is not a feature of the axle. It’s a feature of the braking system and all trims have it.
    I’m also curious why you downgraded your axle.
    Speedfreak and Chew like this.
  3. Feb 7, 2023 at 3:37 PM
    Kaptain_02
    Kaptain_02 2019 OR
    gudujarlson likes this.
  4. Feb 7, 2023 at 3:47 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    What LSD did you install, based on my searching, there is no LSD unit available for the 3rd Gen Tacoma 8.75" rear diff. There is only the factory open, factory E-Locker, the ARB airlocker and the Eaton/Harrop E-Locker.
    BigWhiteTRD, Chew and gudujarlson like this.
  5. Feb 7, 2023 at 3:52 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    Yeah, dont do that please.
    The ECU will try to drive that resistor at approx 4amps while the feedback sensor shows 'not locked'...
    Because the diff lock may normally take quite a bit of driving until it locks, the diff lock will not trip an ECU fail-safe for quite a bit of time.
    This is not a good area to push the envelope, unless a 100 w resistor is used, and its positioned to dissipate the heat.
  6. Feb 7, 2023 at 4:44 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    inquiring minds want to know :notsure:
    Speedfreak likes this.
  7. Feb 7, 2023 at 4:48 PM
    gudujarlson
    Minnesota
    If I’m following this saga correctly (and I hope I am not), OP, you damaged the rear locker switch/connector, couldn’t find a way to fix it, so replaced the entire axle with one that doesn’t have a locker (thinking it has a limited slip differential which is likely not true), and now you are inserting a paper clip into the locker connector in order to use 4wd.
    I’m surprised this paper clip idea didn’t result in a blown fuse or damage to your electrical system. Shorting stuff out isn’t generally a good idea.
    BigWhiteTRD, Chew and Speedfreak like this.
  8. Feb 9, 2023 at 12:11 PM
    ukeacreator
    ukeacreator [OP] Well-Known Member
    Nikolas
    BC CANADA
    2016 Grey Tacoma TRD OffRoad
    285/75R16 DURATRACS FUEL VECTOR 16 3 INCH CUSTOM LIFT
    So all this time i could of just disconnected the module in the headliner?
  9. Feb 9, 2023 at 12:13 PM
    ukeacreator
    Nikolas
    BC CANADA
    Paper clip idea isnt good , im aware but i needed 4x4 and needed it fast in northern canada. Where is the fuse located ?
  10. Feb 9, 2023 at 12:18 PM
    ukeacreator
    Nikolas
    BC CANADA
    Im assuming its a auto LSD, was cheaper to buy that than to replace the lock coil in my factory diff. I see someone posted the old thread. Heres the story , after i posted that thread and got nothing but sarcastic and snotty answers i pulled the diff out and soldered the coil wires back onto the passthru where they had come off in the first place. This still did not fix the locker so i brought it to toyota in which they said i needed a new lock coil in the diff.
    Hope that answers all the curious minds
  11. Feb 9, 2023 at 12:22 PM
    ukeacreator
    Nikolas
    BC CANADA
    If i had my time back i would of stuck with a second gen
  12. Feb 9, 2023 at 12:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    The 2nd Gen did have easier mods with straight jumpers and such. I would have been happy with one of the 2nd Gens that I test drove, but I do very much enjoy my 3rd Gen.
    Certainly consider what @BigWhiteTRD posted above. Might be an easy solution for you?
  13. Feb 9, 2023 at 1:16 PM
    Speedfreak
    Dave
    Canada Eh!
    Manual Mall Crawler
    No, that still doesn't answer the question. Was a complete rear axle assembly installed, or just the differential in the third member. The only reason I am curious, is as I stated in my earlier post, I have not found a manufacturer that is currently making an LSD unit for the factory diff that originally came installed in your truck. Since I have a Sport with a manual I have the larger diff and am interested in options. Although I think my preference will be the factory E-locker for my needs.
    Kaptain_02 and Chew like this.
  14. Feb 9, 2023 at 1:17 PM
    ukeacreator
    Nikolas
    BC CANADA
    Update, just unplugged the module in head liner and that did not change anything. Going to look for a fuse and try that but I don’t see one clearly marked locker or diff
  15. Feb 9, 2023 at 1:21 PM
    #35
    ukeacreator
    Nikolas
    BC CANADA
    It is a whole new axle, housing and all. That better ?
  16. Feb 9, 2023 at 1:26 PM
    #36
    dangeroso
    dangeroso Just float along and fill your lungs
    Jon
    Dallas, TX
    2018 Tacoma TRD Sport 4x4
    It looks like you are trying to disable an electronic wheel locker. Would you like some assistance?
  17. Feb 9, 2023 at 1:31 PM
    #37
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Can I have the old one?
  18. Feb 9, 2023 at 1:34 PM
    #38
    TireFire
    Olympic Peninsula
    The only reason to even say “auto LSD” is to imply it is simulated thru the brakes. It’s a bummer nobody makes an LSD or auto locker for your diff yet, maybe in due time. Could always weld it :D
    Speedfreak[QUOTED] likes this.
  19. Feb 9, 2023 at 1:38 PM
    #39
    ukeacreator
    Nikolas
    BC CANADA
    I would love some assistance !!
  20. Feb 9, 2023 at 1:41 PM
    #40
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Since I brought it up...
    No.
    Once you wire in the 3ohm resistor, I asked @BigWhiteTRD if it wouldn be prudent to disconnect the roof switch. If you accidentally pushed said switch, you would send voltage through the said resistor. Bad ju-ju...
    Sorry for the confusion.
