Disable Seat Belt Alarm 2013 - Factory method DIY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by poppeye, Jan 4, 2013.
  1. Jan 4, 2013 at 4:50 AM
    poppeye
    poppeye [OP] Member
    13 Taco TRD
    I know there have been many posts on this topic. But i believe this to be worthy of its own thread as this is the legit 'factory' way of doing this without any wiring changes. This may work on other year models, but has only been confirmed on my 2013 TRD off road Taco.
    First of all, the owners manual lists the seat belt alarm warning as 'customizable' indicating its possible to be normally turned off. it gives no instruction on how to do so, and presumably the dealer can do it for you. methods from earlier model years don't work.
    i did not discover this solution, someone from a scion board posted these instructions which were originally from a prius. but they are confirmed working on the 2013 taco.
    Step one is buy a elm327 obd reader. mine was about 20 bucks, they are all over amazon. you can also use this in the future with your smartphone if you buy a bluetooth model to do all kinds of cool things.
    2nd, plug it in, power up and get a bluetooth laptop/computer something to talk to it. do a normal bluetooth connect, password is 1234. open up hyperterminal, or putty or any basic terminal program. change the com port to your bluetooth serial (mine was com40 as it told me when my bluetooth connected). Connection set to 9600/N/8/1.
    Then basically just plug in the commands below, and your seatbelt alarm will be permanently off. This is basically what the dealer will do if you bring it in, although they may have some fancy tool to do it from toyota.
    Direct Connect CDT
    >LM327 v1.5
    >ath1
    OK
    * Turn on all headers so I can see it
    >atl1
    OK
    * Turn on linefeed so I can read it
    >at sp 6
    OK
    * Set the protocol to ISO 15765-4 CAN 11/500
    >at dp
    ISO 15765-4 (CAN 11/500)
    * Display the protocol (make sure it took it)
    >at caf1
    OK
    * Set auto formatting on so I can read it
    >at sh 7c0
    OK
    * Set header to 7c0, that's where I'm going to send the command to
    >21a7
    7C8 03 61 A7 C0
    * me - What's your seat belt setting?
    * Taco - My seat belt setting is set to annoy you, C0.
    >3ba700
    7C8 03 7F 3B 78
    7C8 02 7B A7
    * me - don't annoy me anymore
    * Taco - processing
    >21a7
    7C8 03 61 A7 00
    * me - did you get that?
    * Taco - yeah I turned it off, don't you see the 00?
    Enjoy, please post and let others know if this works on other years. This is likely to work on any recent toyota or Scion vehicle, but no guarantees.
    TRDTACOTX likes this.
  2. Jan 4, 2013 at 6:54 AM
    obscurotron
    obscurotron Well-Known Member
    N. Nevada
    '14 DCSB 4x4
    Too many to list, and I've probably forgotten a bunch.
    Can you share the original link where you found the info?
  3. Jan 4, 2013 at 8:16 AM
    MountainDog
    MountainDog Well-Known Member
    Aurora, CO
    2012 4x4 Double Cab Off Road
    Vinyl floor; 265/75/16 Duratracs; SnugTop Rebel
    I was able to get the dealer to turn the chime off on my 2012 for free, but someone mentioned that any time the battery's disconnected it will reset to default. So it'd be nice to be able to do this on my own if I want to do any electrical mods. Thanks for the info.
  4. Jan 4, 2013 at 12:12 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    poppeye pops in with a nuclear bomb of a post
    you, sir, win +1 internet
  5. Jan 4, 2013 at 12:49 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I wouldn't go entering commands to unknown address' in the control module via a terminal. Really Bad things can happen if you mistype an address or command.
    No disrespect intended.
    Lord Helmet likes this.
  6. Jan 4, 2013 at 1:11 PM
    Shauncho
    Shauncho Embrace your inner Bro-ness
    Shaun
    Thousand Oaks, CA
    '13 DCLB TRDSport PreRunner & '99 4Runner 4x4
    Tailgate Anti-theft Anytime Foglights Removed/Relocated Badges BHLM Window tint Goodyear Duratracs Satoshi Grill from Customcargrills.com
    so who's gonna try it first? :popcorn:
  7. Jan 4, 2013 at 1:54 PM
    127.0.0.1 AKA ::1
    /etc/hosts
    I am not yet a taco owner but will be soon, this will be my first tweak
    I checked this against what I know about toyota canbus (I have a 2010 yaris and
    have already hacked the bejeezus out of it's electronics using a borrowed Techstream) and this info poppeye posted is solid
    yes you could enable or disable something like VSC by accident doing this, but the header listed above
    07c0, is nowhere near those groups
    I have access to a Techstream yes but reverse engineering it's commands and translating to OBDII is
    still a lot of experimenting, and some stuff is only accessible by a Techstream....but the Prius forums
    already did the hard work in this case
    from scion forums
    http://www.scionlife.com/forums/archive/index.php/t-213304.html
  8. Jan 4, 2013 at 10:46 PM
    Tactical Tacoma
    Tactical Tacoma Well-Known Member
    Seth
    McKinney, TX
    '12 MGM DCSB Sport 4WD
    ARB air compressor, ARB rear air locker, sPOD switch panel in sunglass holder, OME Front & rear shocks, 885x coils, Dakar leaf springs, Icon tubular UCA's, Flowmaster 40 Series Exhaust, aFe Pro Dry, TRD Sport wheels powder coated anthracite, FJ TRD center caps, Thule roof rack, 886 fog lights for reverse light mod, CSjumper LED DTRL's, Nokya Yellow fogs, plastidipped lower valence, Weathertechs, Wet Okoles. And MANY MORE MODS, READ BUILD!
    Yeah this sounds simple and safe,.... :crazy:
    I think it would be easier to use TechStream
  9. Jan 5, 2013 at 5:45 AM
    poppeye
    poppeye [OP] Member
    13 Taco TRD
    Just a bit of additional information for those squeamish about this technique.
    >ath1
    OK
    -- This command is to the ELM327 chip directly, it gives instructions on how to format the serial terminal, not to your vehicle
    >atl1
    OK
    >at sp 6
    OK
    -- This command is to the ELM327 chip directly, it gives instruction to the chip on 'what language' to use when speaking to your vehicle. but still to this point, no commands have been sent to your vehicle.
    >at dp
    --this is talking to the ELM327 chip again, just making sure it took the last command.
    >at caf1
    OK
    again, formatting to the ELM327 chip
    >at sh 7c0
    OK
    this instruction is setting up communication to your vehicle, but not actually sending anything to it. its telling the elm327 what part of the controller you are about to talk to.
    >21a7
    7C8 03 61 A7 C0
    This is your first command that actually goes to the vehicle, and its a request for information.
    >3ba700
    7C8 03 7F 3B 78
    7C8 02 7B A7
    * Taco - processing
    this is the only command being sent that changes anything. care should be taken when keying this in, but in most cases you can simply revert anything you do. I believe the command 3ba7c0 will revert your seat belt to being on again (for example).
    And to be clear, i did do this on my vehicle already
  10. Jan 5, 2013 at 11:08 AM
    Jimmyh
    SC
    2012 Prerunner SR5
    This + a lot safer + you can get the setup for Techstream and the adapter for about 35$.
  11. Jan 25, 2013 at 5:55 PM
    espy
    espy Active Member
    I also did this and it worked perfectly - Thanks.
  12. Jan 25, 2013 at 6:28 PM
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    If you order on eBay from china and wait a week or two you can get for around $25. I just got mine just don't have a PC to use yet(have Mac).
  13. Feb 2, 2013 at 7:51 PM
    Exxon
    Exxon New Member
    2013 DC TRD 4x4 V6 6sp
  14. Feb 24, 2013 at 3:56 PM
    Flynn Diesel
    Flynn Diesel Well-Known Member
    Phoenix, AZ
    2010 PreRunner SR5 Double Cab
    •BFG AT KO 285/70/17, XD Addict 17x9, Light Racing UCA’s, Billstein 5100’s, OME 885’s, Toytec AAL, Seat Belt warning disable, Grill Craft Black MX Upper & Lower Grill, VisionX 55/65 watt xenon Low/High Beam lights. FOG Light only Mod. Tailgate theft prevention mod. Wet Okole armrest mod. Redline Hood Struts, Weathertech floor liners. AMP Bed Extender. Wet Okole Seat Covers. Pioneer P4200DVD
  15. Feb 24, 2013 at 4:00 PM
    jrogers329
    jrogers329 Well-Known Member
    Huntsville, AL
    2011 Prerunner TRD DCLB-TRADED!
    ^^ that had to hurt like hell
  16. Feb 24, 2013 at 7:15 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    holy shit. It's like his facial expression from the moment of the crash was saved in face oil on the back of a headrest. Crazy
    charliealvarez1 likes this.
  17. Feb 24, 2013 at 9:41 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
  18. Apr 5, 2013 at 4:48 AM
    poppeye
    poppeye [OP] Member
    13 Taco TRD
    The fact my tool was bluetooth is almost irrelevant. bluetooth is a serial connection just like USB, and the software interaction with it through the terminal is identical.
  19. Nov 10, 2013 at 5:37 AM
    rinconmike
    rinconmike New Member
    http://www.amazon.com/ELM327-Bluetooth-Diagnostic-Scanner-Scantool/dp/B0051CAE1C
    I am looking to turn off the seatbelt chime, on a new 2014 Sequoia (on construction sites and in and out of truck).
    Will this work with the sequoia and does it come with the techstream software?
    Or will this one work? It says it comes with the latest techstream.
    http://www.eobd2.net/wholesale/mini-vci-for-toyota-tis-techstream-single-cable.html
    thanks.
  20. Nov 10, 2013 at 1:29 PM
    Bobcape
    Bobcape Well-Known Member
    Bob
    Black Hills, SD
    2013 DCLB SR-5
    Interested to hear the answer to rinconmike's question. I need to turn that damn chime off.
    Bob
