DISABLE SEATBELT CHIME...??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mater5, Mar 28, 2013.
  1. Mar 28, 2013 at 11:15 AM
    Mater5
    Mater5 [OP] Active Member
    M
    Ridgecrest Ca
    2012 TRD SPORT
    NONE YET... TO BE CONTINUED ...
    :p
    HOW DO I DISABLE THE DARN SEATBELT CHIME...??
  2. Mar 28, 2013 at 12:51 PM
    scottw1
    scottw1 Well-Known Member
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Lighted 4wd dial, Sirus XM radio
  3. Mar 28, 2013 at 12:51 PM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Here, this is easier than pulling it up.
    1) Turn the Car 'ON', but do not start the engine (Leave your foot off the brake). Cycle your trip reset knob until it reads ODO. Turn the ignition back off. Wait a couple of seconds.
    2) Make sure seat belt is not fastened
    3) Turn the ignition back on, do not start the car (Leave you foot off the break) As soon as you see everything light up, press and hold the trip reset knob and do a long 12 second count.
    4) Keep your finger on the trip reset knob. Fasten your seat belt, as soon as you fasten your seat belt, you should see the ODO display go from XXXX miles to "b-on". At that time take your finger off the trip reset knob and press it again. It should cycle to "b-off". You should be all set and turn the ignition off and unfasten your seat belt.
    kneisska likes this.
  4. Mar 28, 2013 at 8:41 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    This does NOT work on late 2011 - 2013 Tacomas.
    You can only turn it off with the Techstrean software that the dealer uses.
    Take it to the dealer and request they turn it off.
  5. Mar 28, 2013 at 8:43 PM
    CrAiG
    CrAiG Well-Known Member
    Tacoma889
    2010 toyota tacoma TRD
    Three inch spacer lift
    Take out the gauge cluster and pull little speaker off!!!:)
  6. Mar 29, 2013 at 3:17 AM
    scottw1
    Scott
    Norfolk, VA
    2010 SR5 Tacoma 4x4
    Didn't know that. Guess it's Toyota's way to make sure you pay more at the stealership than doing something easy yourself.
  7. Mar 29, 2013 at 7:39 AM
    12DblCab
    12DblCab I don't know what to write here
    South
    2012 DCSB TRD Sport "Pyrite Mica"
    Step 1: Sit in vehicle, start engine.
    Step 2: Fasten seat belt.
    Done.
    :D
    I'm about to take mine in for an oil change, and I'm going to ask them to do it then.
  8. Mar 29, 2013 at 7:47 AM
    ckeene9
    ckeene9 Well-Known Member
    Chesterfield, VA
    '12 DCSB Supercharged 4x4 TRD Sport
    See Build Thread
    Had the dealer do it for me. Beeps 3 times when I first start up then nothing.
  9. Mar 29, 2013 at 8:33 AM
    Buff
    Buff Well-Known Member
    Buff
    NEPA
    V6 TRD Sport 4x4
    Removed the damn stickers!
    You can also go to the dealer and ask for seat belt extenders for fat people. They are for free! Cut the webbing off them and stick them in the buckle. Problem solved. If you want to wear your seat belt just remove them and buckle up as normal.
    If you can get your dealer to remove chime via programming (some refuse) be aware that if you disconnect the battery it may revert back to default and you would need to get the dealer to remove it again. 2011 1/2 -2013 vehicles (white faced gauges) only. Early vehicles can be done via the user programming in previous post.
  10. Mar 29, 2013 at 8:35 AM
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    This.
  11. Mar 29, 2013 at 8:56 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Haven't had an issue with disconnecting my battery yet.
  12. Mar 29, 2013 at 9:08 AM
    bowzerdoo77
    bowzerdoo77 U.S.M.C.
    North Ogden Utah
    1997 REG CAB 4x4
    None
    Just wear it why wouldn't you?
  13. Mar 29, 2013 at 9:19 AM
    shbaskin
    shbaskin Taco Newbie
    Shaun
    Plano, TX
    2009 PreRunner V6 DC
    Custom painted grille, flowmaster 40, debadging
    This is great! Thanks guys! My dog makes it go off non-stop so this will be great
  14. Mar 29, 2013 at 9:23 AM
    ckeene9
    Chesterfield, VA
    See Build Thread
    Light trail riding, going down to the mailbox, etc
  15. Mar 29, 2013 at 1:26 PM
    Sparky73
    Sparky73 Well-Known Member
    Drew
    Washington
    13 DCLB 4x4
    Famous Fabrication Sliders, Duratracs, Painted Grill, BHLM, Devil's Horns Emblem, Derp'd Badges, Wet Okole Covers
  16. Mar 29, 2013 at 2:00 PM
    Agro
    Agro Well-Known Member
    San Diego
    2015 Ford F-150 XLT 3.5L Ecoboost!
    Could you just unplug the sensor thingee under the seats? or perhaps complete the circuit for it so it thinks they are in? I should read up, I'm sure that's been covered.
  17. Mar 29, 2013 at 11:09 PM
    Agro
    San Diego
    I finally decided to try a clean setup of Techstream. Perfect, super easy.
    1. Install VirtualPC.
    2. Install Windows XP mode
    3. Install Java 1.6 update 7
    4. Install Techstream
    5. Copy the cracked MainMenu.exe over
    6. Install MVCI driver
    Finally customization worked. Awesome
  18. Mar 30, 2013 at 2:21 PM
    zonataco
    zonataco Well-Known Member
    Cost??
  19. Mar 30, 2013 at 2:53 PM
    Farfal
    Farfal Member
    Kevin
    Massachusetts
    '12 DCSB 4WD
    Less than $30 delivered. You need a laptop running XP.
    Win 7 will not work- - that's why the poster above installed XP in a virtual machine.
    Techstream MiniVci has limited ability to configure the vehicle. Limited changes including seat belt chimes are available.
    It's a good reporting tool, however. It will give you lots of operational info down to the PSI in each tire.
  20. Mar 30, 2013 at 6:31 PM
    ckeene9
    Chesterfield, VA
    See Build Thread
    They did it during my charger install so don't know. Have heard of it being free during one of the 5k services.
