Disable Seatbelt Warning Chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ClemsonTacoma, May 27, 2009.
  1. Jan 6, 2012 at 4:24 PM
    #301
    Pepe
    Pepe New Member
    Tacoma SR5
    If you have minimal metalworking skills, do what I did for the passenger side: take a piece of 1/8 aluminum and carve a seat belt buckle plug. Works on either side, but I prefer the unplug fix for the driver side.
  2. Jan 6, 2012 at 4:30 PM
    #302
    Faryota
    Faryota Well-Known Member
    Mic
    Ridgefield, WA.
    13, 4x4, long bed, Sport, Debad
    6" BDS lift in front, warn winch, AFE cold air intake & exhaust, Body Armor Rear bumper, Tuffy in bed storage box, DZ bed mat, ARB front bumper & Warn winch w/light kit, Husky floor mats, dash mat,
    It was the first thing I did!!!!
  3. Jan 6, 2012 at 4:40 PM
    #303
    ffbartlett
    ffbartlett Well-Known Member
    southern california
    2011 Reg Cab 4x4
    tint, bfg's, 5100's, tunnel cover.
  4. Jan 6, 2012 at 7:21 PM
    #304
    txduckhunter
    txduckhunter Well-Known Member
    centex
    08 Tacoma DC LB SR5 4x4
    2.5" lift, ARE Shell, Ducks Unlimited Rubber Floor Mats. ROGUE badges,
    Worked on my 08! Awesome that thing was super annoying
  5. Jan 24, 2012 at 5:14 PM
    #305
    S7ICKlVlAN
    S7ICKlVlAN Cpt. Bubbleguts
    Dave
    Hawaii
    2012 TRD Sport DCSB
    TRD badged | Hunting Cage | Smoked Tails | LED Everything | Slim Cubby HID bi-xenon's | Spidertrax 1.25" | BHLM | FLM | S2000 Ant | 20% Shade | PL 8521 | OME 885 | Bilstein 5100's | Toytec 2" AAL | FN 18x9" Bronze BFD's | 275/65-18 Duratrac's | Wrinkle Red Valve Covers | 3M Di-Noc Wrapped Interior | Kode MB Push Button Ignition | Relentless Sliders | URD TCAI | Mr.Marv Enclosure | Arc Audio 10" | Hybrid Audio Clarus F/R | Alpine PDX-5 | Alpine INE-S920HD
    Bummer, just tried it on my 2012 and it didn't work :(
  6. Jan 24, 2012 at 5:41 PM
    #306
    witter beach
    witter beach Active Member
    seattle
    2008 tacoma trd offroad
    thanks it works!!!!!
  7. Jan 30, 2012 at 7:58 AM
    #307
    TACONOLE
    TACONOLE Member
    anyone tried this on a 2011 ?
  8. Jan 30, 2012 at 2:25 PM
    #308
    Bosmob
    Bosmob Well-Known Member
    Kevin
    San Diego, CA
    '11 Access Cab SR5 I4 4AT
    Fat Bob's 2.75" front spacers Magnaflow Muffler Doug Thorley Header ImMrYo Mirror Bracket
    If you have white gauge faces, it will not work. Bummer I know
  9. Jan 30, 2012 at 5:43 PM
    #309
    Goldstar225
    Goldstar225 Well-Known Member
    Tom
    Central Arkansas
    2011 Pre-runner SR5 4X2
    That explains why it didn't work for me:mad: Oh well, I was begining to think I was retarded.
  10. Jan 30, 2012 at 6:32 PM
    #310
    TACONOLE
    TACONOLE Member
    I don't have white gauges or at least I don't think I do. 2011 DC SR5 4X4 is what I have. I tried it and it didn't work unless I'm doing something wrong ??
  11. Jan 30, 2012 at 9:48 PM
    #311
    Bosmob
    Kevin
    San Diego, CA
    I don't know what to say to that...
    The gauges are either white, or they're not. hehe
    If you really are having difficulty determining the color of your gauges you can look at the build date that is located on the sticker in you drivers side door jamb. If the year is 11 then you cannot disable the seatbelt warning chime.
  12. Jan 31, 2012 at 10:35 AM
    #312
    TACONOLE
    TACONOLE Member
    HAHA, I do have the white gauges i just never noticed. So is there any new codes for those of us that have 2011's with white gauges?
  13. Feb 1, 2012 at 7:45 AM
    #313
    ronmow
    ronmow New Member
    Wyoming
    2011 Tacoma TRD/TX Pro
    I know it's tough to read all the posts in this thread, but everything has been discussed before...
    See post #260 for my solution.
  14. Feb 4, 2012 at 7:00 PM
    #314
    Hayes
    Hayes Well-Known Member
    Brandon
    Denver, CO
    2011 Regular Cab Tacoma 4x4
    Is this considered white faced or is the inverse considered white faced?
  15. Feb 5, 2012 at 6:58 AM
    #315
    bethes
    bethes Señorita Member
    Beth
    Tulsa/Sand Springs, OK
    2011 V6 TRD Off Road
    ^ Hayes, that's not the white gauge face. Not going to lie, if I'd known they'd have more awesome gauge faces 2 months after I bought my Tacoma, I might have waited. Ah well, I still love my Tacoma.
    So the point of my post: I had trouble with the procedure posted by the OP, I did it about a gazillion times and no dice. This one has a couple extra details that may have been the problem. Worked the first time on my 2011 (with the black gauge face):
    1. Turn the ignition switch on (without starting).
    2. Press the ODO/TRIP switch until the odometer displays "ODO"
    3. Turn the ignition switch off
    4. Turn the ignition switch on
    5. Press ODO/TRIP switch immediately, within 6 seconds of turning the ignition to ON, and hold it down for 10 seconds or more.
    6. Continue holding the ODO/TRIP switch and fasten the front drivers's side seat belt.
    7. Check that the odometer displays "b-on." Release the button.
    8. Press the ODO/TRIP button to change the display to "b-off".
    9. Turn the ignition switch off.
    10. Turn the ignition switch on while depressing the brake pedal.
    11. Check that no buzzer sounds when sitting on the front passenger seat.
    The chime still dings for about 5 seconds at startup, but stops after that.
    Also, to facilitate buckling the seatbelt, I pulled it across my lap and under my right leg to keep it from retracting before I started the above steps, then I was able to just buckle it without trying to pull it across my lap while holding the odometer button. Good luck.
    zomg likes this.
  16. Feb 6, 2012 at 10:40 AM
    #316
    ottonavigps
    ottonavigps Well-Known Member
    NICE....
  17. Feb 6, 2012 at 12:13 PM
    #317
    wlowe
    wlowe Well-Known Member
    Bill
    High Sierras, California
    2011 DC OR V6 AUTO JBL
    Good job!! I'll give this a try when I get the time, too busy lately.
  18. Mar 31, 2012 at 9:05 AM
    #318
    MUDFISH
    MUDFISH Well-Known Member
    Syracuse
    12 Double Cab SR5
    Someone needs to find a tweek for the '11-'12... This was the first mod I did on my 09, and totally forgot how great it was until I got my '12...
  19. Mar 31, 2012 at 11:47 AM
    #319
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    unless you want to disconnect stuff, you have to go to the dealer for the 12's :(
  20. Apr 8, 2012 at 5:15 AM
    #320
    Tacoma Mike
    Southern Maine
    nut posted just above you. And it's been posted here.
    Scan tool disable. Ask the dealer. If they won't find another.
    Or get a seat belt extender and plug it in.
