Disable Seatbelt Warning Chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ClemsonTacoma, May 27, 2009.
  1. Mar 14, 2014 at 10:35 AM
    #481
    669sprink
    669sprink Crazy Cracker
    Bobby
    San Diego
    08 pre runner tacoma
    1.5" Wheel spacers all around, 2.0 fox coil over with foxes in the back to match it up, add a leaf. 285/70/r16 general grabbers. my magnaflow exhaust k&n intake just threw in some maxtrac spindles. Total chaos UPA. Bunch of other little things
    The new 3rd gen I call em do not have the safety belt chime removal. I thought that it was funny as hell you gotta pull the fuse it's really easy
  2. Mar 14, 2014 at 11:28 AM
    #482
    TheDuke0fHurl
    TheDuke0fHurl Well-Known Member
    Boston
    2013 DCLB SR5
    How do you do this?
  3. Mar 14, 2014 at 11:40 AM
    #483
    kaizoku
    kaizoku Active Member
    Oregon
    '08 SWB Acc Cab 4x4 TRD Sport
    Don't know how I never saw this thread.
    Just turned that annoying chime off. Thanks!
  4. Mar 15, 2014 at 5:01 AM
    #484
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Which model year are you describing?
  5. Mar 15, 2014 at 6:45 AM
    #485
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    There is no 3rd Generation Tacoma. Late 2011 and up can be turned off via software.
  6. Mar 16, 2014 at 5:49 AM
    #486
    drewp
    drewp Well-Known Member
    south Jersey
    '14 Sport/DCLB
    Has anyone tried this successfully on a 2014? (The cable and techstream approach to disabling?) I'm gathering from the posts that it should work.
  7. Mar 16, 2014 at 7:48 AM
    #487
    B737
    B737 Throbbing Member
    Kevin
    Jersey Shore
    2015 Tundra Double Cab Limited
    stock
    I don't understand this post ^
  8. Apr 12, 2014 at 10:47 AM
    #488
    andonipatxi
    andonipatxi Well-Known Member
    Andoni
    Idaho
    05 4x4 6speed
    Stock
    The only time I don't wear my seatbelt if I'm up on a mountain road...which is all the time lol So hopefully this works!
  9. May 4, 2014 at 10:31 AM
    #489
    rtkbowhunter
    rtkbowhunter Well-Known Member
    Southeast PA
    2011 Tacoma Quad Cab SR5
    2011 Tacoma 4wd QC, bought new in February of 2011. Tried the mod.....no joy. :mad: Hold the odo button for 12,20,30, 45 seconds. Nothing happens.
  10. May 4, 2014 at 11:23 AM
    #490
    B737
    Kevin
    Jersey Shore
    stock
    U need to use dealer or tech stream software.
  11. May 4, 2014 at 5:07 PM
    #491
    elcompalalo
    elcompalalo Member
    Ed
    Las Vegas
    I also have a 2011, worked for me on the first try.
  12. May 9, 2014 at 5:57 AM
    #492
    TRSAndrew
    TRSAndrew Instagram: @apissues Vendor
    ATL
    ‘22 4Runner, ‘14 F150, and I’ve had 4 Tacomas (‘12, ‘15, ‘16, ‘18), 2 FJs
    Can you not simply disassemble the female seat belt receptacle and put a zip tie on the switch that thinks the seat belt is installed?
    This is how you do it in the Honda Element and I would imagine all seat belts are exactly the same in this regard.
  13. May 9, 2014 at 6:12 AM
    #493
    918LOBO
    918LOBO Well-Known Member
    Mr.
    Maricopa County, AZ
    2014 TRD Offroad 4x4
    Takes a few minutes and works for 2013 and 2014 models... probably works for every year. You do not need to remove the seat. I only did the driver side since that is the only buzzer I wanted off anyway...
  14. May 17, 2014 at 7:38 AM
    #494
    paidfor
    paidfor Well-Known Member
    Austin, TX
    2013 TRD OR 4x4
    Hidden GPS tracking system. Backflip cover, weather techs, bed mat, tailgate lock, OME 885 springs, blistein shocks, 2.5 in AAL/
    Went to the dealership this morning to have my oil changed - under warranty. I ask them if I could have the seat belt chime disabled for when I was driving around on my deer lease. They disabled both passage side and drivers side. No arguments. Happy camper now!!!!:)
  15. Jun 6, 2014 at 2:21 PM
    #495
    eastcoastcowboy
    eastcoastcowboy just sittin' in the corner, havin' a beer
    Brian
    Redneckville, NB
    '15 Skewped!!
    Weathertecs, 265/70/17 Duratracs, Trifecta Tonneau
    Dealer turned mine back on today when they did the seatbelt recall for the access cabs.
  16. Sep 25, 2014 at 3:17 PM
    #496
    Koziki
    Koziki Member
    Tyler
    Coquitlam, BC
    2010 Taco
    Fog light anytime, 4Lo yellow wire mod, OME all around with 886 coils, Icon AAL, LR UCA's, Driver side seat lift, DIY Satoshi, 285/75/16 Duratracs on Pro Comp 7069,
    Just did this on my 2010 sport, works like a charm thanks.
  17. Sep 25, 2014 at 3:57 PM
    #497
    jtweezy
    jtweezy Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Which dealer in Austin? Round Rock Toyota said no, and they also told me that AutoNation (down south) would also say no. I need my beeps gone for the same reason as you!
  18. Sep 25, 2014 at 4:27 PM
    #498
    ole
    ole unproductive
    Rock County Wisconsin
    2025 Tacoma SR Double Cab
    I asked my dealer up here bout two weeks ago when I purchased my 2014 Tacoma. He said no problem takes about 5 minutes on the computer.
    I do wear my seatbelt about half the time. No more chime!
  19. Sep 25, 2014 at 4:37 PM
    #499
    907Yoda
    907Yoda currently trying to get lost...
    Rapid City SD
    2015 TRD Off Road
    13% Tinted, 5000k HID headlights and fogs, Wet Okole Seat Covers, Weathertech wind deflectors, 13" Shorty antenna, PowerAid throttle body spacer, XTP Intake Manafold Spacer, Magnaflow cat back exhaust, grillcraft grill
    sub'd i need to try this out
  20. Sep 25, 2014 at 8:18 PM
    #500
    n.gardner
    n.gardner Spacer Hater
    Nick
    Hawaii
    '13 SR5 4x4
    OME 3" 887s + Dakars 1" 4 Crawler BL Pro-Comp Uniballs Nitrochargers + Super Bumps Diff Drop + Drive Shaft Drop
    I keep seeing these, thinking about picking up a set
