Disable Seatbelt Warning Chime
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ClemsonTacoma, May 27, 2009.
  1. Oct 26, 2010 at 5:06 PM
    #101
    gov875
    gov875 WahooTaco
    Pacific Beach, CA
    TRD Sport DCLB
    Wet Okole's (front & rear), Weathertech Floormats (front & rear), cheap tailgate theft mod, extra d-rings, low profile toolbox (flat black), Thule Roof Rack (58" load bars), Thule Ski/Snowboard Roof Rack, Blacked Out Badges, Fishing Bobber Trailer Ball Cover, AVIC-X930BT w/ XM & steering controls, 5100s All Around (front set at .85), Eibach Coils, Rear TSB, rear AAL, LR UCAs, Toytec Diff. Drop, Mudflap Delete, Tailgate Reinforcement, Spidertrax (all 4), 285 Nittos, Rear Diff Breather Extension, TRD Exhaust, Powered Rear Sliding Window, DeeZee Bedmat, rear-view anytime mod, trailer bracket relocate, fog light anytime mod, redline hood struts, Satoshi with Homertaco Custom TRD Mesh, Hella 500s behind the grill, Brighter Reverse Lights
    how did you disable the door open chime??
  2. Dec 20, 2010 at 7:35 AM
    #102
    fredlyzone
    fredlyzone Member
    Fred
    Austin, Texas
    2010 Tacoma PreRunner 4x2 TRD Off Road w/JBL
    Bilstein 5150, Stereo upgrade
    The seat belt chime disable is great. Toyota told me they did not know how to do it. Does anyone know a similar one to get rid of the beeps when you lock/unlock with the keyless remote? My 05 had the premium factory alarm and it was easy to do but on my 2010 I think it is similar to the seat belt mod.
    Thanks!
  3. Jan 4, 2011 at 9:49 PM
    #103
    IrishAmerican
    IrishAmerican Well-Known Member
    Central Louisiana
    09 DC SR5 4x4
    Lift, XD wheels, Tinted, K&N, 285 Cooper STTs
    Thanks for the info....Im not gonna lie, I only wear my seatbelt when I see a cop or if my kids are in the truck, that beep was getting pretty annoying. So glad its gone, thanks again.
  4. Jan 5, 2011 at 3:53 AM
    #104
    jpmorrisvb
    jpmorrisvb Well-Known Member
    Jimmy
    Virginia Beach
    2025 Underground SR5 RWD Double Cab
    Clazzio seat covers,
    Quick and easy.
    Just unplug the "beeper" up by the battery .... I believe that it to the left as you are looking under the hood. Click your key fob and you'll find it. I taped over the wire plug end and removed the beeper.
    Your flashers will still flash.
  5. Jan 5, 2011 at 4:44 AM
    #105
    Mark C.
    Mark C. If you want it bad, you usually get it bad!
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    LED Dome, Reed Switched LEDs in Glove Box and Center Console, Bumper Fogs, Tailgate anti-theft, LEDs over Cig lighter, Back-up camera anytime, Outside Temp add-on, Hidden GPS power, Sockmonkey 3rd Brakelight decal, 4X4 switch illumination, reed switch controlled engine compartment Flood LEDs, Elite Hitch Cover, Plasti-dipped cupholders and door switch control panels, Elite Hitch Cover.
    Try this. I worked on mine.
    http://www.tacomaworld.com/out.php?url=http://www.scribd.com/doc/9766144/TSEL00907
  6. Jan 5, 2011 at 6:43 AM
    #106
    fredlyzone
    fredlyzone Member
    Fred
    Austin, Texas
    Thanks Mark C., that info is helpful but doesn't cover the chime for lock/unlock. I found this on the forum posted by "singlefin" on 2-21-10, it works to enable/disable the keyless remote lock/unlock chime:
    1. CUSTOMIZING FUNCTION
    The following items can be customized.
    NOTICE:
    When the customer requests a change in a function, first make sure that the function can be customized. Record the current settings before customizing. When troubleshooting a function, first make sure that the function is set to the default setting. If the battery is disconnected, the wireless answer-back buzzer will be returned to the default setting.
    Item
    Function
    Default Setting
    Customized Setting
    Wireless remote control
    Operation signal (Buzzer)
    ON
    OFF
    (a) Open the driver side door and insert the key into the ignition cylinder.
    (b) Remove the key from the ignition cylinder and, within 5 seconds, reinsert the key and turn the ignition switch to ON.
    (c) After 10 seconds, the system enters answer-back buzzer switching mode.
    (d) Within 10 seconds after answer-back buzzer switching mode is started, if a transmitter button (the same button) is pressed twice, the answer-back buzzer setting changes (off to on, or on to off) to activate or disable answer-back by buzzer.
    HINT:
    The driver side door is closed.
    The ignition switch is turned off.
    The key is removed from the ignition cylinder.
    A transmitter button is not pressed for 10 seconds after answer-back switching mode is started.
    The transmitter is operated but the second button pressed is different from the first.
    Answer-back starts.
  7. Jan 5, 2011 at 7:23 AM
    #107
    Mark C.
    Mark
    Connecticut
    2010 MGM SR5 4WD AC
    Sorry ....I gave you the wrong link. I have reprogrammed mine to eliminate lock/unlock chirp, seat belt alarm, and reset the maintenance required light.
    Good luck.
  8. Jan 5, 2011 at 10:25 AM
    #108
    ericb
    ericb I'm a very neat monster
    Dexter
    surface of the sun
    Truck So Good
    The trip reset button fix worked on my 10 thanks
  9. Jan 5, 2011 at 1:27 PM
    #109
    Tepidy
    Tepidy Well-Known Member
    Ted
    upstate NY
    11 tacoma 4x4
    Toytec Coil Overs 3.00" DSM UCA's (Desert Products) TSB 4 Leaf w/AAL by Pro Comp Bilstein 5100 rear 1"ToyTec SwayBar Drops 1" diff drop Detroit Trutrac Rear Diff Nitro 4.56 Gears Doug Thornley Header MagnaFlow Cat Back Exhaust Custom Built Rear Plate Bumper Custom Built Front Plate Bumper 4X Innovations Rock Sliders ATO Front Skid BAMF Rear Diff Skid Uniden 510XL Pro CB Raceline Renegades BF Goodrich Mud Terrains KM2's 265x75x16 WeatherTechs Rear Diff breather Relocate Intake Resonator Removed Yellow Wire Mod
    2011 SR5 4x4 2.7ltr. Worked like a charm. Great tip thanks brother.
  10. Jan 5, 2011 at 3:20 PM
    #110
    jkcb2011
    jkcb2011 Well-Known Member
    Eastern Ontario, Canada
    2011 TRD Sport 4x4
    2011 DC TRD Sport, worked like a charm. Thanks!
  11. Jan 5, 2011 at 9:13 PM
    #111
    jimmygle
    jimmygle Well-Known Member
    Jimmy
    Spokane, WA
    2011 Tacoma SR5 DC
    2011-01-06: Disabled seat belt beep -- 2011-01-12: Installed Aries Bull Bar -- 2011-01-28: WeatherTech Digitals Front & Back -- 2011-02-05: 30% Front Window Tint -- 2011-03-29: Wet Okole's Front Seats
    Just did this on my 2011. Great thread - thank you!
  12. Jan 17, 2011 at 5:07 AM
    #112
    1FSTLS1
    1FSTLS1 Well-Known Member
    Got to love the internet. Thanks,
  13. Jan 17, 2011 at 8:42 AM
    #113
    JacksonRollins
    JacksonRollins New Member
    Just did my 2011 DC 4x4. My wife accidentally put her seatbelt on during the process and it worked. So you can buckle the driver or passenger belt for this to work.
  14. Jan 17, 2011 at 8:59 AM
    #114
    steved411
    steved411 I came. I saw. I conquered.
    Clayton, NC
    2008 DC TRD Off-Road
    Or a case of beer ;)
  15. Jan 17, 2011 at 9:36 AM
    #115
    steved411
    Clayton, NC
    Worked on my 08 4x4 DC. Thanks!
  16. Jan 17, 2011 at 11:43 AM
    #116
    HogTaco
    HogTaco Well-Known Member
    Northwest Arkansas
    2011 Access Cab 2.7 2WD AT
    Bed Mat, OEM Running Boards, Ultra-Gauge.
    I tried this on my 2011 Access Cab and was not able to get it to work. I did follow the instructions exactly. Mine has the newer gauge clusters, however, so I wonder if the electronics are not different, too?
  17. Jan 17, 2011 at 1:03 PM
    #117
    moe1967
    moe1967 Well-Known Member
    2010 TRD DC Off-Road PreRunner
    Outfuckingstanding!!!
    Thanks
    2010 Tacoma TRD Prerunner
  18. Jan 18, 2011 at 3:32 AM
    #118
    ruslanus
    ruslanus Well-Known Member
    Rus
    Wasilla, AK
    Worked on my 2010. Great mod!
  19. Jan 19, 2011 at 6:12 AM
    #119
    jtice
    jtice Well-Known Member
    West Virginia
    2011 TRD Off-Road
    Pioneer P4100DVD, 10" Pioneer Shallow Mount Sub
    I have a 2011 and cant seem to get this to work.
    I actually get it to say the b-on, press the button again, and it says b-off
    but the truck will beep several times right after I start it if I dont have my seatbelt on before I start the truck.
    Any tips?
    Thanks
    ~John
  20. Jan 19, 2011 at 6:27 AM
    #120
    fredlyzone
    fredlyzone Member
    Fred
    Austin, Texas
    Even with B-OFF set the seat belt warning will chime a few times when you first insert the key. After that it will not make a sound...
